Hey Guys
I have a problem, i cant find the bluetooth device on my Handy to connect it.
In the balena Dashboard i also can not see the “bluetooth-audio” in the service
Thanks for helping.
Kind Regards
Hi
Are you sure you have pushed your local balenaSound application to the right application on balenaCloud?
Also, if you just pushed, then it’ll take some time for the supervisor to download and install the application on the device
Regards
ZubairLK
Thanks ZubairLK for your answer.
I used this video guide to set it up.
it should be fine with this video??
Video Guide
Regards
This guide is called “Installing Balena-CLI on Windows”.
It shows how to install balena cli and push an example application.
It is not related to bluetooth in any way.
If you want to try the balenaSound project, please follow this guide: https://www.balena.io/blog/turn-your-old-speakers-or-hi-fi-into-bluetooth-receivers-using-only-a-raspberry-pi/
