I am trying to get running my Jetson Nano with AC8265. AC8265 is visible in “main” container, where I installed network-manager. Using nmcli it is possible to connect to 802.11n networks, but if I do a scan, then it is not possible to see any 5GHz networks. Does it mean that driver installed in BalenaOS for AC8265 doesn’t support 5GHz networks? I am also not able to create a hotspot on 5GHz. If it is a problem in a driver, is there any way how to add it?
Hello, I have a couple of questions to confirm before diving into the firmware realm:
are you using external antennas?
how far away are you from the wifi router? Are there multiple walls in between?
Also, if possible can you provide relevant output of dmesg?
You will need to:
ssh into the host
Run dmesg | grep iwl
Yes I use external antennas, that were included in package with AC8265. Jetson is about 4 meters away from router.
Here is output of dmesg | grep iwl command:
[ 13.755984] iwlwifi 0000:01:00.0: enabling device (0000 → 0002)
[ 13.773641] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 13.790399] iwlwifi 0000:01:00.0: Falling back to user helper
[ 75.016146] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 75.025378] iwlwifi 0000:01:00.0: Falling back to user helper
[ 136.455592] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 136.464816] iwlwifi 0000:01:00.0: Falling back to user helper
[ 197.894952] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 197.904184] iwlwifi 0000:01:00.0: Falling back to user helper
[ 259.357428] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 259.437373] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 259.450303] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 259.456736] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 259.584581] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 259.592018] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 259.656630] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 259.663071] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 259.788401] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 259.794782] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 259.878282] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 259.884734] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 260.010115] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 260.016037] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 263.640698] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 263.648000] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 263.774060] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 263.779978] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 263.937375] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 263.943816] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 264.070058] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 264.075978] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
jimsynz
January 20, 2020, 10:43pm
8
Hi there.
Thanks for that. Can you please also send us the output of iwlist scan?
James.
Output of ls /lib/firmware/iwlwifi-*:
iwlwifi-135-6.ucode
iwlwifi-3160-9.ucode
iwlwifi-6000g2a-6.ucode
iwlwifi-6050-4.ucode
iwlwifi-7265-17.ucode
iwlwifi-8000C-36.ucode
iwlwifi-8265-31.ucode
iwlwifi-3160-7.ucode
iwlwifi-6000-4.ucode
iwlwifi-6000g2b-5.ucode
iwlwifi-6050-5.ucode
iwlwifi-7265D-29.ucode
iwlwifi-8265-22.ucode
iwlwifi-8265-34.ucode
iwlwifi-3160-8.ucode
iwlwifi-6000g2a-5.ucode
iwlwifi-6000g2b-6.ucode
iwlwifi-7260-17.ucode
iwlwifi-8000C-34.ucode
iwlwifi-8265-27.ucode
iwlwifi-8265-36.ucode
Looks like there is newer version of iwlwifi-8265. It tries to load iwlwifi-8265-26, but its not there. Could it be because of using iwlwifi-8265-22?
Output of modinfo iwlwifi:
filename: /lib/modules/4.9.140-l4t-r32.2/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Copyright(c) 2003- 2015 Intel Corporation linuxwifi@intel.com
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-26.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-26.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-26.ucode
firmware: iwlwifi-8000C-26.ucode
firmware: iwlwifi-9000-pu-a0-lc-a0–26.ucode
firmware: iwlwifi-9260-th-a0-jf-a0–26.ucode
firmware: iwlwifi-9000-pu-a0-jf-a0–26.ucode
firmware: iwlwifi-Qu-a0-jf-b0–26.ucode
alias: pci:v00008086d00002720svsd00000A10bc sci
alias: pci:v00008086d0000A370svsd00001030bc sci
alias: pci:v00008086d00002526svsd00001030bc sci
alias: pci:v00008086d000031DCsvsd00000030bc sci
alias: pci:v00008086d0000A370svsd00000030bc sci
alias: pci:v00008086d00009DF0svsd00000030bc sci
alias: pci:v00008086d00002526svsd00000030bc sci
alias: pci:v00008086d000031DCsvsd00000060bc sci
alias: pci:v00008086d0000A370svsd00000060bc sci
alias: pci:v00008086d00009DF0svsd00000060bc sci
alias: pci:v00008086d00002526svsd00000060bc sci
alias: pci:v00008086d000030DCsvsd00000060bc sci
alias: pci:v00008086d00009DF0svsd00002A10bc sci
alias: pci:v00008086d00009DF0svsd00000710bc sci
alias: pci:v00008086d00002526svsd00001420bc sci
alias: pci:v00008086d00009DF0svsd00002010bc sci
alias: pci:v00008086d00009DF0svsd00000510bc sci
alias: pci:v00008086d00009DF0svsd00000000bc sci
alias: pci:v00008086d00009DF0svsd00000310bc sci
alias: pci:v00008086d00009DF0svsd00000610bc sci
alias: pci:v00008086d00009DF0svsd00000410bc sci
alias: pci:v00008086d00009DF0svsd00000210bc sci
alias: pci:v00008086d00009DF0svsd00000010bc sci
alias: pci:v00008086d00009DF0svsd00000A10bc sci
alias: pci:v00008086d00002526svsd00001410bc sci
alias: pci:v00008086d00002526svsd00000010bc sci
alias: pci:v00008086d00002526svsd00000000bc sci
alias: pci:v00008086d0000271Bsvsd00000010bc sci
alias: pci:v00008086d000024FDsvsd00000012bc sci
alias: pci:v00008086d000024FDsvsd00000850bc sci
alias: pci:v00008086d000024FDsvsd00000950bc sci
alias: pci:v00008086d000024FDsvsd00000930bc sci
alias: pci:v00008086d000024FDsvsd00000910bc sci
alias: pci:v00008086d000024FDsvsd00008130bc sci
alias: pci:v00008086d000024FDsvsd00009110bc sci
alias: pci:v00008086d000024FDsvsd00000810bc sci
alias: pci:v00008086d000024FDsvsd00008010bc sci
alias: pci:v00008086d000024FDsvsd00008050bc sci
alias: pci:v00008086d000024FDsvsd00008110bc sci
alias: pci:v00008086d000024FDsvsd00009010bc sci
alias: pci:v00008086d000024FDsvsd00000150bc sci
alias: pci:v00008086d000024FDsvsd00000050bc sci
alias: pci:v00008086d000024FDsvsd000010D0bc sci
alias: pci:v00008086d000024FDsvsd00001010bc sci
alias: pci:v00008086d000024FDsvsd00000130bc sci
alias: pci:v00008086d000024FDsvsd00001130bc sci
alias: pci:v00008086d000024FDsvsd00001110bc sci
alias: pci:v00008086d000024FDsvsd00000110bc sci
alias: pci:v00008086d000024FDsvsd00000010bc sci
alias: pci:v00008086d000024F3svsd00000000bc sci
alias: pci:v00008086d000024F3svsd00000930bc sci
alias: pci:v00008086d000024F3svsd00000950bc sci
alias: pci:v00008086d000024F3svsd00000850bc sci
alias: pci:v00008086d000024F3svsd00000910bc sci
alias: pci:v00008086d000024F3svsd00000810bc sci
alias: pci:v00008086d000024F6svsd00000030bc sci
alias: pci:v00008086d000024F5svsd00000010bc sci
alias: pci:v00008086d000024F3svsd00000044bc sci
alias: pci:v00008086d000024F3svsd00000004bc sci
alias: pci:v00008086d000024F3svsd00009150bc sci
alias: pci:v00008086d000024F3svsd00009050bc sci
alias: pci:v00008086d000024F3svsd00008150bc sci
alias: pci:v00008086d000024F3svsd00008050bc sci
alias: pci:v00008086d000024F3svsd00009132bc sci
alias: pci:v00008086d000024F3svsd00008132bc sci
alias: pci:v00008086d000024F3svsd00009130bc sci
alias: pci:v00008086d000024F3svsd00008130bc sci
alias: pci:v00008086d000024F4svsd00009030bc sci
alias: pci:v00008086d000024F4svsd00008030bc sci
alias: pci:v00008086d000024F3svsd00009110bc sci
alias: pci:v00008086d000024F3svsd00009010bc sci
alias: pci:v00008086d000024F3svsd00008110bc sci
alias: pci:v00008086d000024F3svsd00008010bc sci
alias: pci:v00008086d000024F3svsd0000B0B0bc sci
alias: pci:v00008086d000024F3svsd0000D0B0bc sci
alias: pci:v00008086d000024F3svsd0000D050bc sci
alias: pci:v00008086d000024F3svsd0000C050bc sci
alias: pci:v00008086d000024F3svsd0000D010bc sci
alias: pci:v00008086d000024F3svsd0000C110bc sci
alias: pci:v00008086d000024F3svsd0000C010bc sci
alias: pci:v00008086d000024F4svsd00001030bc sci
alias: pci:v00008086d000024F4svsd00000030bc sci
alias: pci:v00008086d000024F3svsd00001150bc sci
alias: pci:v00008086d000024F3svsd00000150bc sci
alias: pci:v00008086d000024F3svsd00001050bc sci
alias: pci:v00008086d000024F3svsd00000250bc sci
alias: pci:v00008086d000024F3svsd00000050bc sci
alias: pci:v00008086d000024F3svsd00001110bc sci
alias: pci:v00008086d000024F3svsd00001012bc sci
alias: pci:v00008086d000024F3svsd00000012bc sci
alias: pci:v00008086d000024F3svsd000001F0bc sci
alias: pci:v00008086d000024F3svsd00000110bc sci
alias: pci:v00008086d000024F3svsd00001132bc sci
alias: pci:v00008086d000024F3svsd00000132bc sci
alias: pci:v00008086d000024F3svsd00001130bc sci
alias: pci:v00008086d000024F3svsd00000130bc sci
alias: pci:v00008086d000024F3svsd000010B0bc sci
alias: pci:v00008086d000024F3svsd00001010bc sci
alias: pci:v00008086d000024F3svsd00000010bc sci
alias: pci:v00008086d0000095Asvsd00009E10bc sci
alias: pci:v00008086d0000095Asvsd00009400bc sci
alias: pci:v00008086d0000095Asvsd00009000bc sci
alias: pci:v00008086d0000095Bsvsd0000520Abc sci
alias: pci:v00008086d0000095Bsvsd00005212bc sci
alias: pci:v00008086d0000095Asvsd00005F10bc sci
alias: pci:v00008086d0000095Asvsd00005490bc sci
alias: pci:v00008086d0000095Bsvsd00005290bc sci
alias: pci:v00008086d0000095Asvsd00005590bc sci
alias: pci:v00008086d0000095Asvsd00005190bc sci
alias: pci:v00008086d0000095Asvsd00005090bc sci
alias: pci:v00008086d0000095Asvsd00005420bc sci
alias: pci:v00008086d0000095Asvsd0000502Abc sci
alias: pci:v00008086d0000095Asvsd00005020bc sci
alias: pci:v00008086d0000095Asvsd00009410bc sci
alias: pci:v00008086d0000095Bsvsd00009310bc sci
alias: pci:v00008086d0000095Asvsd00009510bc sci
alias: pci:v00008086d0000095Bsvsd00009200bc sci
alias: pci:v00008086d0000095Bsvsd00009210bc sci
alias: pci:v00008086d0000095Asvsd00009112bc sci
alias: pci:v00008086d0000095Asvsd00009110bc sci
alias: pci:v00008086d0000095Asvsd0000900Abc sci
alias: pci:v00008086d0000095Asvsd00009012bc sci
alias: pci:v00008086d0000095Asvsd00009010bc sci
alias: pci:v00008086d0000095Bsvsd00005202bc sci
alias: pci:v00008086d0000095Asvsd00005102bc sci
alias: pci:v00008086d0000095Asvsd00005002bc sci
alias: pci:v00008086d0000095Bsvsd00005200bc sci
alias: pci:v00008086d0000095Asvsd0000500Abc sci
alias: pci:v00008086d0000095Asvsd00005000bc sci
alias: pci:v00008086d0000095Asvsd00001010bc sci
alias: pci:v00008086d0000095Asvsd00005400bc sci
alias: pci:v00008086d0000095Asvsd00005510bc sci
alias: pci:v00008086d0000095Asvsd00005410bc sci
alias: pci:v00008086d0000095Asvsd00005412bc sci
alias: pci:v00008086d0000095Asvsd00005012bc sci
alias: pci:v00008086d0000095Asvsd00005C10bc sci
alias: pci:v00008086d0000095Bsvsd00005210bc sci
alias: pci:v00008086d0000095Bsvsd00005302bc sci
alias: pci:v00008086d0000095Bsvsd00005310bc sci
alias: pci:v00008086d0000095Asvsd00005100bc sci
alias: pci:v00008086d0000095Asvsd00005110bc sci
alias: pci:v00008086d0000095Asvsd00005010bc sci
alias: pci:v00008086d000024FBsvsd00000000bc sci
alias: pci:v00008086d000024FBsvsd00002150bc sci
alias: pci:v00008086d000024FBsvsd00002050bc sci
alias: pci:v00008086d000024FBsvsd00002110bc sci
alias: pci:v00008086d000024FBsvsd00002010bc sci
alias: pci:v00008086d00003165svsd00008110bc sci
alias: pci:v00008086d00003165svsd00008010bc sci
alias: pci:v00008086d00003166svsd00004210bc sci
alias: pci:v00008086d00003166svsd00004310bc sci
alias: pci:v00008086d00003165svsd00004110bc sci
alias: pci:v00008086d00003165svsd00004510bc sci
alias: pci:v00008086d00003165svsd00004410bc sci
alias: pci:v00008086d00003166svsd00004212bc sci
alias: pci:v00008086d00003165svsd00004012bc sci
alias: pci:v00008086d00003165svsd00004010bc sci
alias: pci:v00008086d000008B3svsd00001170bc sci
alias: pci:v00008086d000008B3svsd00001070bc sci
alias: pci:v00008086d000008B3svsd00008570bc sci
alias: pci:v00008086d000008B3svsd00008470bc sci
alias: pci:v00008086d000008B4svsd00008272bc sci
alias: pci:v00008086d000008B4svsd00008370bc sci
alias: pci:v00008086d000008B4svsd00008270bc sci
alias: pci:v00008086d000008B3svsd00008062bc sci
alias: pci:v00008086d000008B3svsd00008060bc sci
alias: pci:v00008086d000008B3svsd00008172bc sci
alias: pci:v00008086d000008B3svsd00008170bc sci
alias: pci:v00008086d000008B3svsd00008072bc sci
alias: pci:v00008086d000008B3svsd00008070bc sci
alias: pci:v00008086d000008B4svsd00000370bc sci
alias: pci:v00008086d000008B3svsd00000472bc sci
alias: pci:v00008086d000008B3svsd00000470bc sci
alias: pci:v00008086d000008B4svsd00000272bc sci
alias: pci:v00008086d000008B4svsd00000270bc sci
alias: pci:v00008086d000008B3svsd00000062bc sci
alias: pci:v00008086d000008B3svsd00000060bc sci
alias: pci:v00008086d000008B3svsd00000172bc sci
alias: pci:v00008086d000008B3svsd00000170bc sci
alias: pci:v00008086d000008B3svsd00000072bc sci
alias: pci:v00008086d000008B3svsd00000070bc sci
alias: pci:v00008086d000008B1svsd0000C420bc sci
alias: pci:v00008086d000008B2svsd0000C220bc sci
alias: pci:v00008086d000008B1svsd0000C02Abc sci
alias: pci:v00008086d000008B1svsd0000C020bc sci
alias: pci:v00008086d000008B1svsd0000C360bc sci
alias: pci:v00008086d000008B2svsd0000C370bc sci
alias: pci:v00008086d000008B1svsd0000C560bc sci
alias: pci:v00008086d000008B1svsd0000C570bc sci
alias: pci:v00008086d000008B1svsd0000C462bc sci
alias: pci:v00008086d000008B1svsd0000C460bc sci
alias: pci:v00008086d000008B1svsd0000C472bc sci
alias: pci:v00008086d000008B1svsd0000C470bc sci
alias: pci:v00008086d000008B2svsd0000C262bc sci
alias: pci:v00008086d000008B2svsd0000C26Abc sci
alias: pci:v00008086d000008B2svsd0000C260bc sci
alias: pci:v00008086d000008B2svsd0000C272bc sci
alias: pci:v00008086d000008B1svsd0000CC60bc sci
alias: pci:v00008086d000008B1svsd0000CC70bc sci
alias: pci:v00008086d000008B2svsd0000C270bc sci
alias: pci:v00008086d000008B1svsd0000C760bc sci
alias: pci:v00008086d000008B1svsd0000C770bc sci
alias: pci:v00008086d000008B1svsd0000C162bc sci
alias: pci:v00008086d000008B1svsd0000C062bc sci
alias: pci:v00008086d000008B1svsd0000C160bc sci
alias: pci:v00008086d000008B1svsd0000C06Abc sci
alias: pci:v00008086d000008B1svsd0000C060bc sci
alias: pci:v00008086d000008B1svsd0000C170bc sci
alias: pci:v00008086d000008B1svsd0000C072bc sci
alias: pci:v00008086d000008B1svsd0000C070bc sci
alias: pci:v00008086d000008B1svsd00004420bc sci
alias: pci:v00008086d000008B2svsd00004220bc sci
alias: pci:v00008086d000008B1svsd0000402Abc sci
alias: pci:v00008086d000008B1svsd00004020bc sci
alias: pci:v00008086d000008B1svsd00005770bc sci
alias: pci:v00008086d000008B1svsd00005170bc sci
alias: pci:v00008086d000008B1svsd00005072bc sci
alias: pci:v00008086d000008B1svsd00005070bc sci
alias: pci:v00008086d000008B2svsd00004360bc sci
alias: pci:v00008086d000008B2svsd00004370bc sci
alias: pci:v00008086d000008B1svsd00004560bc sci
alias: pci:v00008086d000008B1svsd00004570bc sci
alias: pci:v00008086d000008B1svsd00004A6Cbc sci
alias: pci:v00008086d000008B1svsd00004A6Ebc sci
alias: pci:v00008086d000008B1svsd00004A70bc sci
alias: pci:v00008086d000008B1svsd0000486Ebc sci
alias: pci:v00008086d000008B1svsd00004870bc sci
alias: pci:v00008086d000008B1svsd00004462bc sci
alias: pci:v00008086d000008B1svsd0000446Abc sci
alias: pci:v00008086d000008B1svsd00004460bc sci
alias: pci:v00008086d000008B1svsd00004472bc sci
alias: pci:v00008086d000008B1svsd00004470bc sci
alias: pci:v00008086d000008B2svsd00004262bc sci
alias: pci:v00008086d000008B2svsd0000426Abc sci
alias: pci:v00008086d000008B2svsd00004260bc sci
alias: pci:v00008086d000008B2svsd00004272bc sci
alias: pci:v00008086d000008B2svsd00004270bc sci
alias: pci:v00008086d000008B1svsd00004162bc sci
alias: pci:v00008086d000008B1svsd00004062bc sci
alias: pci:v00008086d000008B1svsd00004160bc sci
alias: pci:v00008086d000008B1svsd0000406Abc sci
alias: pci:v00008086d000008B1svsd00004060bc sci
alias: pci:v00008086d000008B1svsd00004C70bc sci
alias: pci:v00008086d000008B1svsd00004C60bc sci
alias: pci:v00008086d000008B1svsd00004170bc sci
alias: pci:v00008086d000008B1svsd00004072bc sci
alias: pci:v00008086d000008B1svsd00004070bc sci
alias: pci:v00008086d00000892svsd00000462bc sci
alias: pci:v00008086d00000893svsd00000262bc sci
alias: pci:v00008086d00000892svsd00000062bc sci
alias: pci:v00008086d00000894svsd00000822bc sci
alias: pci:v00008086d00000894svsd00000422bc sci
alias: pci:v00008086d00000895svsd00000222bc sci
alias: pci:v00008086d00000894svsd00000022bc sci
alias: pci:v00008086d0000088Fsvsd00005260bc sci
alias: pci:v00008086d0000088Esvsd00004860bc sci
alias: pci:v00008086d0000088Esvsd0000446Abc sci
alias: pci:v00008086d0000088Esvsd00004460bc sci
alias: pci:v00008086d0000088Fsvsd0000426Abc sci
alias: pci:v00008086d0000088Fsvsd00004260bc sci
alias: pci:v00008086d0000088Esvsd0000406Abc sci
alias: pci:v00008086d0000088Esvsd00004060bc sci
alias: pci:v00008086d00000887svsd00004462bc sci
alias: pci:v00008086d00000888svsd00004262bc sci
alias: pci:v00008086d00000887svsd00004062bc sci
alias: pci:v00008086d00000890svsd00004822bc sci
alias: pci:v00008086d00000890svsd00004422bc sci
alias: pci:v00008086d00000891svsd00004222bc sci
alias: pci:v00008086d00000890svsd00004022bc sci
alias: pci:v00008086d00000896svsd00005027bc sci
alias: pci:v00008086d00000896svsd00005025bc sci
alias: pci:v00008086d00000897svsd00005017bc sci
alias: pci:v00008086d00000897svsd00005015bc sci
alias: pci:v00008086d00000896svsd00005007bc sci
alias: pci:v00008086d00000896svsd00005005bc sci
alias: pci:v00008086d000008AEsvsd00001027bc sci
alias: pci:v00008086d000008AEsvsd00001025bc sci
alias: pci:v00008086d000008AFsvsd00001017bc sci
alias: pci:v00008086d000008AFsvsd00001015bc sci
alias: pci:v00008086d000008AEsvsd00001007bc sci
alias: pci:v00008086d000008AEsvsd00001005bc sci
alias: pci:v00008086d00000084svsd00001316bc sci
alias: pci:v00008086d00000084svsd00001216bc sci
alias: pci:v00008086d00000083svsd00001326bc sci
alias: pci:v00008086d00000083svsd00001226bc sci
alias: pci:v00008086d00000083svsd00001306bc sci
alias: pci:v00008086d00000083svsd00001206bc sci
alias: pci:v00008086d00000084svsd00001315bc sci
alias: pci:v00008086d00000084svsd00001215bc sci
alias: pci:v00008086d00000083svsd00001325bc sci
alias: pci:v00008086d00000083svsd00001225bc sci
alias: pci:v00008086d00000083svsd00001305bc sci
alias: pci:v00008086d00000083svsd00001205bc sci
alias: pci:v00008086d00000886svsd00001317bc sci
alias: pci:v00008086d00000886svsd00001315bc sci
alias: pci:v00008086d00000885svsd00001327bc sci
alias: pci:v00008086d00000885svsd00001325bc sci
alias: pci:v00008086d00000885svsd00001307bc sci
alias: pci:v00008086d00000885svsd00001305bc sci
alias: pci:v00008086d00000089svsd00001316bc sci
alias: pci:v00008086d00000089svsd00001311bc sci
alias: pci:v00008086d00000087svsd00001326bc sci
alias: pci:v00008086d00000087svsd00001321bc sci
alias: pci:v00008086d00000087svsd00001306bc sci
alias: pci:v00008086d00000087svsd00001301bc sci
alias: pci:v00008086d00000091svsd00005226bc sci
alias: pci:v00008086d00000091svsd00005225bc sci
alias: pci:v00008086d00000091svsd00005221bc sci
alias: pci:v00008086d00000091svsd00005207bc sci
alias: pci:v00008086d00000091svsd00005206bc sci
alias: pci:v00008086d00000091svsd00005205bc sci
alias: pci:v00008086d00000091svsd00005201bc sci
alias: pci:v00008086d00000090svsd00005216bc sci
alias: pci:v00008086d00000090svsd00005215bc sci
alias: pci:v00008086d00000090svsd00005211bc sci
alias: pci:v00008086d0000008Bsvsd00005317bc sci
alias: pci:v00008086d0000008Bsvsd00005315bc sci
alias: pci:v00008086d0000008Asvsd00005327bc sci
alias: pci:v00008086d0000008Asvsd00005325bc sci
alias: pci:v00008086d0000008Asvsd00005307bc sci
alias: pci:v00008086d0000008Asvsd00005305bc sci
alias: pci:v00008086d00000082svsd00001305bc sci
alias: pci:v00008086d00000082svsd00001304bc sci
alias: pci:v00008086d00000082svsd00004820bc sci
alias: pci:v00008086d00000085svsd0000C228bc sci
alias: pci:v00008086d00000085svsd0000C220bc sci
alias: pci:v00008086d00000082svsd0000C020bc sci
alias: pci:v00008086d00000085svsd00001316bc sci
alias: pci:v00008086d00000085svsd00001318bc sci
alias: pci:v00008086d00000085svsd00001311bc sci
alias: pci:v00008086d00000082svsd00001328bc sci
alias: pci:v00008086d00000082svsd00001326bc sci
alias: pci:v00008086d00000082svsd00001321bc sci
alias: pci:v00008086d00000082svsd00001308bc sci
alias: pci:v00008086d00000082svsd00001307bc sci
alias: pci:v00008086d00000082svsd00001306bc sci
alias: pci:v00008086d00000082svsd00001301bc sci
alias: pci:v00008086d00004239svsd00001316bc sci
alias: pci:v00008086d00004239svsd00001311bc sci
alias: pci:v00008086d00004238svsd00001118bc sci
alias: pci:v00008086d00004238svsd00001111bc sci
alias: pci:v00008086d0000422Csvsd00001326bc sci
alias: pci:v00008086d0000422Csvsd00001321bc sci
alias: pci:v00008086d0000422Csvsd00001307bc sci
alias: pci:v00008086d0000422Csvsd00001306bc sci
alias: pci:v00008086d0000422Csvsd00001301bc sci
alias: pci:v00008086d0000422Bsvsd00001128bc sci
alias: pci:v00008086d0000422Bsvsd00001121bc sci
alias: pci:v00008086d0000422Bsvsd00001108bc sci
alias: pci:v00008086d0000422Bsvsd00001101bc sci
alias: pci:v00008086d0000423Dsvsd00001316bc sci
alias: pci:v00008086d0000423Dsvsd00001216bc sci
alias: pci:v00008086d0000423Dsvsd00001311bc sci
alias: pci:v00008086d0000423Dsvsd00001211bc sci
alias: pci:v00008086d0000423Csvsd00001326bc sci
alias: pci:v00008086d0000423Csvsd00001321bc sci
alias: pci:v00008086d0000423Csvsd00001221bc sci
alias: pci:v00008086d0000423Csvsd00001306bc sci
alias: pci:v00008086d0000423Csvsd00001206bc sci
alias: pci:v00008086d0000423Csvsd00001301bc sci
alias: pci:v00008086d0000423Csvsd00001201bc sci
alias: pci:v00008086d0000423Bsvsd00001011bc sci
alias: pci:v00008086d0000423Asvsd00001021bc sci
alias: pci:v00008086d0000423Asvsd00001001bc sci
alias: pci:v00008086d00004236svsd00001114bc sci
alias: pci:v00008086d00004236svsd00001014bc sci
alias: pci:v00008086d00004236svsd00001111bc sci
alias: pci:v00008086d00004236svsd00001011bc sci
alias: pci:v00008086d00004235svsd00001104bc sci
alias: pci:v00008086d00004235svsd00001004bc sci
alias: pci:v00008086d00004235svsd00001101bc sci
alias: pci:v00008086d00004235svsd00001001bc sci
alias: pci:v00008086d00004235svsd00001124bc sci
alias: pci:v00008086d00004235svsd00001024bc sci
alias: pci:v00008086d00004235svsd00001121bc sci
alias: pci:v00008086d00004235svsd00001021bc sci
alias: pci:v00008086d00004237svsd00001316bc sci
alias: pci:v00008086d00004237svsd00001216bc sci
alias: pci:v00008086d00004237svsd00001315bc sci
alias: pci:v00008086d00004237svsd00001215bc sci
alias: pci:v00008086d00004237svsd00001314bc sci
alias: pci:v00008086d00004237svsd00001214bc sci
alias: pci:v00008086d00004237svsd00001311bc sci
alias: pci:v00008086d00004237svsd00001211bc sci
alias: pci:v00008086d00004232svsd00001326bc sci
alias: pci:v00008086d00004232svsd00001226bc sci
alias: pci:v00008086d00004232svsd00001325bc sci
alias: pci:v00008086d00004232svsd00001225bc sci
alias: pci:v00008086d00004232svsd00001324bc sci
alias: pci:v00008086d00004232svsd00001224bc sci
alias: pci:v00008086d00004232svsd00001321bc sci
alias: pci:v00008086d00004232svsd00001221bc sci
alias: pci:v00008086d00004232svsd00001306bc sci
alias: pci:v00008086d00004232svsd00001206bc sci
alias: pci:v00008086d00004232svsd00001305bc sci
alias: pci:v00008086d00004232svsd00001205bc sci
alias: pci:v00008086d00004232svsd00001304bc sci
alias: pci:v00008086d00004232svsd00001204bc sci
alias: pci:v00008086d00004232svsd00001301bc sci
alias: pci:v00008086d00004232svsd00001201bc sci
depends: cfg80211
intree: Y
vermagic: 4.9.140-l4t-r32.2 SMP preempt mod_unload modversions aarch64
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 4K for other devices 1:4K 2:8K 3:12K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: antenna_coupling:specify antenna coupling in dB (default: 0 dB) (int)
parm: nvm_file:NVM file name (charp)
parm: d0i3_disable:disable d0i3 functionality (default: Y) (bool)
parm: lar_disable:disable LAR functionality (default: N) (bool)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
parm: d0i3_timeout:Timeout to D0i3 entry when idle (ms) (uint)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
This should provide another information.
alexgg
January 21, 2020, 5:20pm
12
Hi, could you try to setup the correct regulatory domain for your country that allows 5G channels? See instructions at https://www.balena.io/docs/reference/OS/network/2.x/#regulatory-domain . What can happen is that the default world wide regulatory domain does not allow to irradiate on the 5G band unless it knows it is allowed in your country.
After I add currect regulatory domain of country it is possible to see and to connect to 5GHz networks. Also AC is supported because rate of 5GHz network is about 400Mbit/s. Next question is why I am not able to create 5GHz AC hotspot during runtime.
majorz
January 22, 2020, 12:22pm
17
Hi, the iw phy command will list the bands supported by the loaded driver and firmware. Can you please paste its output?
Zahari
Output of iw phy command:
Wiphy phy0
max # scan SSIDs: 20
max scan IEs length: 422 bytes
max # sched scan SSIDs: 20
max # match sets: 11
max # scan plans: 2
max scan plan interval: 65535
max scan plan iterations: 254
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports RSN-IBSS.
Device supports AP-side u-APSD.
Device supports T-DLS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP-128 (00-0f-ac:4)
* CMAC (00-0f-ac:6)
Available Antennas: TX 0 RX 0
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* P2P-client
* P2P-GO
* P2P-device
Band 1:
Capabilities: 0x11ef
RX LDPC
HT20/HT40
SM Power Save disabled
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 3839 bytes
DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 4 usec (0x05)
HT Max RX data rate: 300 Mbps
HT TX/RX MCS rate indexes supported: 0-15
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412 MHz [1] (22.0 dBm)
* 2417 MHz [2] (22.0 dBm)
* 2422 MHz [3] (22.0 dBm)
* 2427 MHz [4] (22.0 dBm)
* 2432 MHz [5] (22.0 dBm)
* 2437 MHz [6] (22.0 dBm)
* 2442 MHz [7] (22.0 dBm)
* 2447 MHz [8] (22.0 dBm)
* 2452 MHz [9] (22.0 dBm)
* 2457 MHz [10] (22.0 dBm)
* 2462 MHz [11] (22.0 dBm)
* 2467 MHz [12] (22.0 dBm)
* 2472 MHz [13] (22.0 dBm)
* 2484 MHz [14] (disabled)
Band 2:
RX LDPC
HT20/HT40
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
DSSS/CCK HT40
VHT Capabilities (0x039071b0):
Max MPDU length: 3895
Supported Channel Width: neither 160 nor 80+80
RX LDPC
short GI (80 MHz)
TX STBC
SU Beamformee
MU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5180 MHz [36] (22.0 dBm) (no IR)
* 5200 MHz [40] (22.0 dBm) (no IR)
* 5220 MHz [44] (22.0 dBm) (no IR)
* 5240 MHz [48] (22.0 dBm) (no IR)
* 5260 MHz [52] (22.0 dBm) (no IR, radar detection)
* 5280 MHz [56] (22.0 dBm) (no IR, radar detection)
* 5300 MHz [60] (22.0 dBm) (no IR, radar detection)
* 5320 MHz [64] (22.0 dBm) (no IR, radar detection)
* 5340 MHz [68] (disabled)
* 5360 MHz [72] (disabled)
* 5380 MHz [76] (disabled)
* 5400 MHz [80] (disabled)
* 5420 MHz [84] (disabled)
* 5440 MHz [88] (disabled)
* 5460 MHz [92] (disabled)
* 5480 MHz [96] (disabled)
* 5500 MHz [100] (22.0 dBm) (no IR, radar detection)
* 5520 MHz [104] (22.0 dBm) (no IR, radar detection)
* 5540 MHz [108] (22.0 dBm) (no IR, radar detection)
* 5560 MHz [112] (22.0 dBm) (no IR, radar detection)
* 5580 MHz [116] (22.0 dBm) (no IR, radar detection)
* 5600 MHz [120] (22.0 dBm) (no IR, radar detection)
* 5620 MHz [124] (22.0 dBm) (no IR, radar detection)
* 5640 MHz [128] (22.0 dBm) (no IR, radar detection)
* 5660 MHz [132] (22.0 dBm) (no IR, radar detection)
* 5680 MHz [136] (22.0 dBm) (no IR, radar detection)
* 5700 MHz [140] (22.0 dBm) (no IR, radar detection)
* 5720 MHz [144] (22.0 dBm) (no IR, radar detection)
* 5745 MHz [149] (22.0 dBm) (no IR)
* 5765 MHz [153] (22.0 dBm) (no IR)
* 5785 MHz [157] (22.0 dBm) (no IR)
* 5805 MHz [161] (22.0 dBm) (no IR)
* 5825 MHz [165] (22.0 dBm) (no IR)
* 5845 MHz [169] (disabled)
* 5865 MHz [173] (disabled)
* 5885 MHz [177] (disabled)
* 5905 MHz [181] (disabled)
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* remain_on_channel
* set_tx_bitrate_mask
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* set_wds_peer
* tdls_mgmt
* tdls_oper
* start_sched_scan
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* channel_switch
* set_qos_map
* add_tx_ts
* connect
* disconnect
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0x40 0xb0 0xc0 0xd0
* managed: 0x40 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* mesh point: 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* P2P-device: 0x40 0xd0
WoWLAN support:
* wake up on disconnect
* wake up on magic packet
* wake up on pattern match, up to 20 patterns of 16-128 bytes,
maximum packet offset 0 bytes
* can do GTK rekeying
* wake up on GTK rekey failure
* wake up on EAP identity request
* wake up on 4-way handshake
* wake up on rfkill release
* wake up on network detection, up to 11 match sets
* wake up on TCP connection
software interface modes (can always be added):
* AP/VLAN
* monitor
valid interface combinations:
* #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1,
total <= 3, #channels <= 2
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
Device supports TX status socket option.
Device supports HT-IBSS.
Device supports SAE with AUTHENTICATE command
Device supports low priority scan.
Device supports scan flush.
Device supports per-vif TX power setting
P2P GO supports CT window setting
P2P GO supports opportunistic powersave setting
Driver supports full state transitions for AP/GO clients
Driver supports a userspace MPM
Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
Device adds DS IE to probe requests
Device adds WFA TPC Report IE to probe requests
Device can update TPC Report IE
Device supports static SMPS
Device supports dynamic SMPS
Device supports WMM-AC admission (TSPECs)
Device supports configuring vdev MAC-addr on create.
Device supports TDLS channel switching
Device supports randomizing MAC-addr in scans.
Device supports randomizing MAC-addr in sched scans.
Device supports randomizing MAC-addr in net-detect scans.
Supported extended features:
* [ RRM ]: RRM
* [ MU_MIMO_AIR_SNIFFER ]: MU-MIMO sniffer
majorz
January 22, 2020, 1:03pm
20
Nothing sticks out as a problem from the iw phy command.
iwlist uses the older wireless extensions for Linux. Can you check with iw dev wlan0 scan, which uses the newer subsystem? Also can you please paste the output of iw dev as well.
Also how do you try to create the access point more specifically?
Zahari
To create hotspot I used these commands:
nmcli con add type wifi ifname wlan0 con-name SecSpot5 autoconnect yes ssid SecSpot5
nmcli con modify SecSpot5 802-11-wireless.mode ap 802-11-wireless.band a ipv4.method shared
nmcli con modify SecSpot5 wifi-sec.key-mgmt wpa-psk
nmcli con modify SecSpot5 wifi-sec.psk "12345678"
nmcli con up SecSpot5
But still, I search better solution to create hotspot or connect to another network during runtime.
majorz
January 22, 2020, 1:13pm
24
There are a couple of 5GHz networks returned by the iw scan. Can you please share the output of nmcli d wifi so that we see whether they reach NetworkManager as well?
root@b2b50cd:/# nmcli d wifi
IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY
OpenWRT_home_1 Infra 13 195 Mbit/s 89 ▂▄▆█ WPA2
OpenWRT_home_1_5G Infra 44 405 Mbit/s 70 ▂▄▆_ WPA2
OpenWRT_home_1 Infra 10 130 Mbit/s 52 ▂▄__ WPA2
chotnet8r Infra 140 130 Mbit/s 35 ▂▄__ WPA2
OpenWRT_WDS Infra 11 65 Mbit/s 30 ▂___ WPA1 WPA2
vlnenka Infra 2 135 Mbit/s 29 ▂___ WPA2
OpenWRT_WDS2 Infra 11 65 Mbit/s 29 ▂___ WPA2
majorz
January 22, 2020, 1:15pm
26
Those networks are OpenWRT_home_1_5G and chotnet8r.
majorz
January 22, 2020, 1:16pm
27
So it sees them. Is the network you are looking for not among them?
Main problem is that I need to create high speed hotspot. Connection to other network could be slower. I was trying to search why I am not able to create 5GHz AC hotspot through diagnosis of connection to other network. First I was not able to connect to other 5GHz network, but still there is problem with creating 5GHz AC hotspot
majorz
January 22, 2020, 1:18pm
29
Yes, let me check the snippet you provided here on my side.
