This worked for me: Connection successfully activated (D-Bus active path: /org/freedesktop/NetworkManager/ActiveConnection/5)
What are the last journal logs after you bring the connection up with nmcli?
journalctl -n 100 will give the last 100 for example.
Also in case of connection to OpenWRT_home_1_5G, looks like there is absence of MIMO support, because 400Mbit/s shows that it use only one band.
root@b2b50cd:/# nmcli con add type wifi ifname wlan0 con-name SecSpot5 autoconnect yes ssid SecSpot5
Connection ‘SecSpot5’ (aada0bea-0398-4684-9d42-160a7cc6d0b6) successfully added.
root@b2b50cd:/# nmcli con modify SecSpot5 802-11-wireless.mode ap 802-11-wireless.band a ipv4.method shared
root@b2b50cd:/# nmcli con modify SecSpot5 wifi-sec.key-mgmt wpa-psk
root@b2b50cd:/# nmcli con modify SecSpot5 wifi-sec.psk “12345678”
root@b2b50cd:/# nmcli con up SecSpot5
Error: Connection activation failed: 802.1X supplicant took too long to authenticate
Jan 22 13:25:18 b2b50cd NetworkManager[1214]: [1579699518.8959] Config: added ‘mode’ value ‘2’
Jan 22 13:25:18 b2b50cd NetworkManager[1214]: [1579699518.8959] Config: added ‘frequency’ value ‘5180’
Jan 22 13:25:18 b2b50cd NetworkManager[1214]: [1579699518.8960] Config: added ‘freq_list’ value '5035 5040 5045 5055 5060 5080 5170 5180 5190 5200 5210 5220 5230 5240>
Jan 22 13:25:18 b2b50cd NetworkManager[1214]: [1579699518.8960] Config: added ‘key_mgmt’ value ‘WPA-PSK’
Jan 22 13:25:18 b2b50cd NetworkManager[1214]: [1579699518.8961] Config: added ‘psk’ value ‘’
Jan 22 13:25:18 b2b50cd wpa_supplicant[3633]: Note: nl80211 driver interface is not designed to be used with ap_scan=2; this can result in connection failures
Jan 22 13:25:18 b2b50cd NetworkManager[1214]: [1579699518.8975] device (wlan0): supplicant interface state: disabled → inactive
Jan 22 13:25:18 b2b50cd kernel: iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:18 b2b50cd kernel[1134]: [ 3307.761075] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:18 b2b50cd kernel[1134]: [ 3307.767759] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel: iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel[1134]: [ 3307.893661] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel[1134]: [ 3307.900241] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:19 b2b50cd kernel[1134]: [ 3307.986969] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:19 b2b5cd kernel: iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel[1134]: [ 3308.018964] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel[1134]: [ 3308.025817] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel[1134]: [ 3308.151546] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel[1134]: [ 3308.157746] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:19 b2b50cd kernel[1134]: [ 3308.249615] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:19 b2b50cd wpa_supplicant[3633]: wlan0: Failed to start AP functionality
Jan 22 13:25:19 b2b50cd NetworkManager[1214]: [1579699519.4394] device (wlan0): supplicant interface state: inactive → disconnected
Jan 22 13:25:43 b2b50cd NetworkManager[1214]: [1579699543.9029] device (wlan0): Activation: (wifi) Hotspot network creation took too long, failing activation
Jan 22 13:25:43 b2b50cd NetworkManager[1214]: [1579699543.9034] device (wlan0): state change: config → failed (reason ‘supplicant-timeout’, sys-iface-state: 'managed>
Jan 22 13:25:43 b2b50cd NetworkManager[1214]: [1579699543.9121] device (wlan0): Activation: failed for connection ‘SecSpot5’
Jan 22 13:25:43 b2b50cd NetworkManager[1214]: [1579699543.9136] device (wlan0): state change: failed → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
Jan 22 13:25:43 b2b50cd kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:43 b2b50cd kernel[1134]: [ 3332.735069] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:43 b2b50cd NetworkManager[1214]: [1579699543.9435] device (wlan0): set-hw-addr: set MAC address to B2:70:2F:F3:ED:14 (scanning)
Jan 22 13:25:43 b2b50cd kernel: iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:43 b2b50cd kernel[1134]: [ 3332.767140] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:43 b2b50cd kernel[1134]: [ 3332.773929] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:44 b2b50cd kernel: iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:44 b2b50cd kernel[1134]: [ 3332.902178] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:44 b2b50cd kernel[1134]: [ 3332.909063] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:44 b2b50cd kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:44 b2b50cd kernel[1134]: [ 3333.004704] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:44 b2b50cd NetworkManager[1214]: [1579699544.2042] device (wlan0): supplicant interface state: disconnected → disabled
Jan 22 13:25:44 b2b50cd NetworkManager[1214]: [1579699544.2205] device (wlan0): supplicant interface state: disabled → inactive
Jan 22 13:25:44 b2b50cd wpa_supplicant[3633]: wlan0: Reject scan trigger since one is already pending
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.6723] policy: auto-activating connection ‘SecSpot5’ (aada0bea-0398-4684-9d42-160a7cc6d0b6)
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.6737] device (wlan0): Activation: starting connection ‘SecSpot5’ (aada0bea-0398-4684-9d42-160a7cc6d0b6)
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.6740] device (wlan0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘managed’)
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.6947] device (wlan0): set-hw-addr: reset MAC address to 4C:1D:96:FF:2F:DF (preserve)
Jan 22 13:25:47 b2b50cd kernel: iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:47 b2b50cd kernel[1134]: [ 3336.518366] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:47 b2b50cd kernel[1134]: [ 3336.525022] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:47 b2b50cd kernel[1134]: [ 3336.650139] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:47 b2b50cd kernel[1134]: [ 3336.656642] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:47 b2b50cd kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:47 b2b50cd kernel[1134]: [ 3336.730226] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9222] device (wlan0): supplicant interface state: inactive → disabled
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9230] device (wlan0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9252] device (wlan0): Activation: (wifi) access point ‘SecSpot5’ has security, but secrets are required.
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9253] device (wlan0): state change: config → need-auth (reason ‘none’, sys-iface-state: ‘managed’)
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9316] device (wlan0): state change: need-auth → prepare (reason ‘none’, sys-iface-state: ‘managed’)
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9338] device (wlan0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9352] device (wlan0): Activation: (wifi) connection ‘SecSpot5’ has security, and secrets exist. No new secr>
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9355] Config: added ‘ssid’ value ‘SecSpot5’
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9355] Config: added ‘mode’ value ‘2’
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9356] Config: added ‘frequency’ value ‘5180’
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9357] Config: added ‘freq_list’ value '5035 5040 5045 5055 5060 5080 5170 5180 5190 5200 5210 5220 5230 5240>
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9357] Config: added ‘key_mgmt’ value ‘WPA-PSK’
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9358] Config: added ‘psk’ value ‘’
Jan 22 13:25:47 b2b50cd wpa_supplicant[3633]: Note: nl80211 driver interface is not designed to be used with ap_scan=2; this can result in connection failures
Jan 22 13:25:47 b2b50cd NetworkManager[1214]: [1579699547.9378] device (wlan0): supplicant interface state: disabled → inactive
Jan 22 13:25:47 b2b50cd kernel[1134]: [ 3336.798995] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:47 b2b50cd kernel[1134]: [ 3336.805788] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:48 b2b50cd kernel: iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:48 b2b50cd kernel[1134]: [ 3336.931564] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:48 b2b50cd kernel[1134]: [ 3336.938078] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:48 b2b50cd kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:48 b2b50cd kernel[1134]: [ 3337.029577] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:48 b2b50cd kernel[1134]: [ 3337.061802] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:48 b2b50cd kernel[1134]: [ 3337.068292] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:48 b2b50cd kernel[1134]: [ 3337.200763] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:48 b2b50cd kernel[1134]: [ 3337.207239] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
Jan 22 13:25:48 b2b50cd kernel[1134]: [ 3337.304630] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 22 13:25:48 b2b50cd wpa_supplicant[3633]: wlan0: Failed to start AP functionality
Jan 22 13:25:48 b2b50cd NetworkManager[1214]: [1579699548.4942] device (wlan0): supplicant interface state: inactive → disconnected
I found something: https://devtalk.nvidia.com/default/topic/1056122/jetson-nano/802-1x-supplicant-issues-with-intel-8265ngw/2
It is not the same use case exactly as it is about adhoc mode, but involves the Nano and a card with the same chipset. The error is also the same. This will definitely need more investigation. One option is for me to pass this issue to our devices team to investigate whenever this reaches the top of their queue, the other one is for you to try out some other card options with high speed support. What do you think?
I think, that if you want to support Jetson Nano, you should find and fix problem with AC8265, because it is officially supported wifi card by nvidia. Lot of users that will switch to balena will have AC8265.
Also because I need to get it working ASAP, than I will try different card. Maybe AC7265 will work.
We are planning on providing a more extensive list with tested WiFi chips that work well under our OS. More often than not there are different issues with them as chip makers do not put a strong focus on their Linux support unfortunately.
