G’day
I have a ‘display’ service that drives a tablet screen that is started as part of the service stack on my edge device (Dell 7212 tablet) running the NUC BOS variant. This container takes ~3m to ‘boot’, all other services work fine
[Logs] [12/23/2019, 8:56:57 AM] [display] ..
[Logs] [12/23/2019, 8:56:59 AM] [display] ..
[Logs] [12/23/2019, 8:57:01 AM] [display] ..
[Logs] [12/23/2019, 8:57:03 AM] [display] ..
[Logs] [12/23/2019, 8:57:05 AM] [display] ..
[Logs] [12/23/2019, 8:57:07 AM] [display] ..
[Logs] [12/23/2019, 8:57:09 AM] [display] ..
[Logs] [12/23/2019, 8:57:11 AM] [display] ..
[Logs] [12/23/2019, 8:57:13 AM] [display] ..
[Logs] [12/23/2019, 8:57:13 AM] [display] xinit: giving up
[Logs] [12/23/2019, 8:57:13 AM] [display] xinit: unable to connect to X server: Cannot assign requested address
[Logs] [12/23/2019, 8:57:13 AM] [display] waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
[Logs] [12/23/2019, 8:57:14 AM] [display] xinit: server error
[Logs] [12/23/2019, 8:57:14 AM] Service exited 'display sha256:eb7576d8cccac59c4bb6c8aec537c01bb9910a8c672d2fcf9f089eff2d4d0601'
[Logs] [12/23/2019, 8:57:16 AM] Restarting service 'display sha256:eb7576d8cccac59c4bb6c8aec537c01bb9910a8c672d2fcf9f089eff2d4d0601'
[Logs] [12/23/2019, 8:57:17 AM] [display]
[Logs] [12/23/2019, 8:57:17 AM] [display] X.Org X Server 1.20.4
[Logs] [12/23/2019, 8:57:17 AM] [display] X Protocol Version 11, Revision 0
[Logs] [12/23/2019, 8:57:17 AM] [display] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[Logs] [12/23/2019, 8:57:17 AM] [display] Current Operating System: Linux dce3584ab089 5.2.10-yocto-standard #1 SMP PREEMPT Fri Oct 4 11:58:01 UTC 2019 x86_64
[Logs] [12/23/2019, 8:57:17 AM] [display] Kernel command line: BOOT_IMAGE=/boot/bzImage root=LABEL=resin-rootA rootwait intel_idle.max_cstate=1
[Logs] [12/23/2019, 8:57:17 AM] [display] Build Date: 05 March 2019 08:11:12PM
[Logs] [12/23/2019, 8:57:17 AM] [display] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[Logs] [12/23/2019, 8:57:17 AM] [display] Current version of pixman: 0.36.0
[Logs] [12/23/2019, 8:57:17 AM] [display] Before reporting problems, check http://wiki.x.org
[Logs] [12/23/2019, 8:57:17 AM] [display] to make sure that you have the latest version.
[Logs] [12/23/2019, 8:57:17 AM] [display] Markers: (--) probed, (**) from config file, (==) default setting,
[Logs] [12/23/2019, 8:57:17 AM] [display] (++) from command line, (!!) notice, (II) informational,
[Logs] [12/23/2019, 8:57:17 AM] [display] (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[Logs] [12/23/2019, 8:57:17 AM] [display] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 23 00:57:17 2019
[Logs] [12/23/2019, 8:57:17 AM] [display] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[Logs] [12/23/2019, 8:57:17 AM] [display] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
Once it timeouts, it loads fine. Seems I have to make the container start dependent on some other system service perhaps ?
The salient parts of my run script:
#!/usr/bin/bash
export DISPLAY=:0.0
export DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket
startx /usr/local/bin/display
The Dockerfile
FROM balenalib/%%BALENA_ARCH%%-debian-python:3.7-buster-build
RUN install_packages \
dbus-x11 \
libsm6 \
libxext6 \
libxrender-dev \
matchbox-keyboard \
x11-xserver-utils \
xinit \
xserver-xorg \
xserver-xorg-input-evdev
ENV UDEV=on
RUN pip install display
COPY xserverrc /etc/X11/xinit/xserverrc
WORKDIR /root/
COPY start.sh .
CMD ["bash", "start.sh"]
