xinit: giving up - balenalabs/browser-aarch64 with balenaOS 3.0
Hello all,
After the new 3.0 update of BalenaOs, I’m struggling with the balena browser. It has worked for many months with the old BalenaOs versions. (< 3.0)
It seams that something is wrong with the X11 server.
2023-07-12T13:18:23+02:00  browser  user.max_user_namespaces = 10000
2023-07-12T13:18:24+02:00  browser  umount: /dev: target is busy.
2023-07-12T13:18:24+02:00  browser  mount: /sys/kernel/debug: nodev already mounted on /sys/kernel/debug.
2023-07-12T13:18:24+02:00  browser  Running balena base image entrypoint...
2023-07-12T13:18:26+02:00  browser  setting xserver-xorg-legacy/xwrapper/allowed_users from configuration file
2023-07-12T13:18:26+02:00  browser  balenaLabs browser version: 2.4.6
2023-07-12T13:18:26+02:00  browser  Setting CPU Scaling Governor to 'performance'
2023-07-12T13:18:26+02:00  browser  Enabling cursor
2023-07-12T13:18:27+02:00  browser  hostname: No address associated with hostname
2023-07-12T13:18:27+02:00  browser  xauth:  file /home/chromium/.Xauthority does not exist
2023-07-12T13:18:27+02:00  browser  xauth: (stdin):1:  bad display name "22c2181:0" in "add" command
2023-07-12T13:18:27+02:00  browser  X.Org X Server 1.20.4
2023-07-12T13:18:27+02:00  browser  X Protocol Version 11, Revision 0
2023-07-12T13:18:27+02:00  browser  Build Operating System: Linux 5.10.0-19-arm64 aarch64 Debian
2023-07-12T13:18:27+02:00  browser  Current Operating System: Linux 22c2181 5.15.92-v8 #1 SMP PREEMPT Wed Feb 8 16:47:50 UTC 2023 aarch64
2023-07-12T13:18:27+02:00  browser  Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:A2:3F:D1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 rootfstype=ext4 rootwait dwc_otg.lpm_enable=0 rootwait vt.global_cursor_default=0 console=null cgroup_enable=memory root=UUID=ba1eadef-7af0-4586-abc8-05230b1db89a rootwait
2023-07-12T13:18:27+02:00  browser  Build Date: 08 November 2022  12:39:13PM
2023-07-12T13:18:27+02:00  browser  xorg-server 2:1.20.4-1+deb10u6 (https://www.debian.org/support)
2023-07-12T13:18:27+02:00  browser  Current version of pixman: 0.36.0
2023-07-12T13:18:27+02:00  browser      Before reporting problems, check http://wiki.x.org
2023-07-12T13:18:27+02:00  browser      to make sure that you have the latest version.
2023-07-12T13:18:27+02:00  browser  Markers: (--) probed, (**) from config file, (==) default setting,
2023-07-12T13:18:27+02:00  browser      (++) from command line, (!!) notice, (II) informational,
2023-07-12T13:18:27+02:00  browser      (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
2023-07-12T13:18:27+02:00  browser  (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 12 11:18:27 2023
2023-07-12T13:18:27+02:00  browser  (==) Using system config directory "/usr/share/X11/xorg.conf.d"
2023-07-12T13:18:27+02:00  browser  (EE)
2023-07-12T13:18:27+02:00  browser  Fatal server error:
2023-07-12T13:18:27+02:00  browser  (EE) AddScreen/ScreenInit failed for driver 0
2023-07-12T13:18:27+02:00  browser  Please consult the The X.Org Foundation support
2023-07-12T13:18:27+02:00  browser       at http://wiki.x.org
2023-07-12T13:18:27+02:00  browser   for help.
2023-07-12T13:18:27+02:00  browser  (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
2023-07-12T13:18:27+02:00  browser  (EE) Server terminated with error (1). Closing log file.
2023-07-12T13:18:42+02:00  browser  xinit: giving up
2023-07-12T13:18:42+02:00  browser  xinit: unable to connect to X server: Connection refused
2023-07-12T13:18:42+02:00  browser  xinit: server error
2023-07-12T13:18:42+02:00  browser  xauth: (argv):1:  bad display name "22c2181:0" in "remove" command
2023-07-12T13:18:42+02:00  browser  Idling...
after a bit of research, I found this:
I keep getting the message: "AddScreen/ScreenInit failed for driver 0"
You get an error message like:
(EE) R128(0): (Ron = 12288) + (Rloop = 17) >= (Roff = 12012)
Fatal server error:
This kind of problem typically occurs when you're using a big monitor with an old graphics card. You can solve it by deleting some of the highest resolutions of the deepest colour mode in the Screen section of your xorg.conf, or even the whole last Display subsection.
But I have no idea how to fix this or how to check if this is the problem.
Searching for the Xorg.conf, I only find some files, but no one contains any screen information
> find /  | grep  xorg.conf
/usr/share/X11/xorg.conf.d/10-quirks.conf
/usr/share/X11/xorg.conf.d/10-evdev.conf
I hope someone can help me out.
best regards
Alex
Ok, it turnes out, that it is noat an balena 3.0 issue.
I got the same problem with balena 2.115.18-rev2.
Did anybody experienced the same or similar issue?
One of our engineers has updated the browser block today - could you please try the latest version of the block (2.5.0) and see if it solves this issue for you? Thanks
I am having this exact same problem on a fresh RPI4, with no other modifications, just tried to deploy balenaDash with default settings and I get:
 kiosk  (EE)
 kiosk  Fatal server error:
 kiosk  (EE) AddScreen/ScreenInit failed for driver 0
 kiosk  (EE)
 kiosk  (EE)
 kiosk  Please consult the The X.Org Foundation support
 kiosk           at http://wiki.x.org
 kiosk   for help.
 kiosk  (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
 kiosk  (EE)
 kiosk  (EE) Server terminated with error (1). Closing log file.
This is a bummer, was hoping this would work out of the box.
Here’s the full log.
I wonder if it’s not working because the resolution is supposed to be 1920x1200, but I am not sure if that would be the case.
@rcooke-warwick any ideas?
root@8c2d91250cd3:/usr/src/app# cat /var/log/Xorg.0.log
[   731.393]
[   731.394] Build Operating System: Linux 5.10.0-10-arm64 aarch64 Debian
[   731.394] Current Operating System: Linux 8c2d91250cd3 5.15.92-v8 #1 SMP PREEMPT Wed Feb 8 16:47:50 UTC 2023 aarch64
[   731.394] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1200M@75 smsc95xx.macaddr=D8:3A:DD:2E:46:3D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 rootfstype=ext4 rootwait dwc_otg.lpm_enable=0 rootwait vt.global_cursor_default=0 console=null cgroup_enable=memory root=UUID=ba1eadef-bfc9-459e-b565-3311855314f1 rootwait
[   731.394] Build Date: 18 December 2021  09:05:36AM
[   731.394] xorg-server 2:1.20.4-1+deb10u4 (https://www.debian.org/support)
[   731.394] Current version of pixman: 0.36.0
[   731.394]    Before reporting problems, check http://wiki.x.org
[   731.394] Markers: (--) probed, (**) from config file, (==) default setting,
[   731.395] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Aug 20 18:43:26 2023
[   731.396] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   731.397] (==) No Layout section.  Using the first Screen section.
[   731.397] (==) No screen section available. Using defaults.
[   731.397] (**) |-->Screen "Default Screen Section" (0)
[   731.397] (**) |   |-->Monitor "<default monitor>"
[   731.398] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[   731.398] (==) Automatically adding devices
[   731.398] (==) Automatically enabling devices
[   731.398] (==) Automatically adding GPU devices
[   731.398] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   731.398] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[   731.398]    Entry deleted from font path.
[   731.398] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   731.398] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   731.398] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   731.398] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[   731.399] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   731.399]    Entry deleted from font path.
[   731.399] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   731.399] (==) FontPath set to:
        built-ins
[   731.399] (==) ModulePath set to "/usr/lib/xorg/modules"
[   731.399] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[   731.399] (II) Loader magic: 0x555dd9ae08
[   731.399] (II) Module ABI versions:
[   731.399]    X.Org ANSI C Emulation: 0.4
[   731.399]    X.Org Video Driver: 24.0
[   731.399]    X.Org XInput driver : 24.1
[   731.399]    X.Org Server Extension : 10.0
[   731.400] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[   731.400] (--) using VT number 2
[   731.400] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   731.403] (II) xfree86: Adding drm device (/dev/dri/card0)
[   731.412] (II) xfree86: Adding drm device (/dev/dri/card1)
[   731.414] (II) no primary bus or device found
[   731.414]    falling back to /sys/devices/platform/gpu/drm/card0
[   731.414] (II) LoadModule: "glx"
[   731.415] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   731.420] (II) Module glx: vendor="X.Org Foundation"
[   731.420]    compiled for 1.20.4, module version = 1.0.0
[   731.420]    ABI class: X.Org Server Extension, version 10.0
[   731.421] (==) Matched modesetting as autoconfigured driver 0
[   731.421] (==) Matched fbdev as autoconfigured driver 1
[   731.421] (==) Assigned the driver to the xf86ConfigLayout
[   731.421] (II) LoadModule: "modesetting"
[   731.421] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   731.422] (II) Module modesetting: vendor="X.Org Foundation"
[   731.422]    compiled for 1.20.4, module version = 1.20.4
[   731.422]    Module class: X.Org Video Driver
[   731.422]    ABI class: X.Org Video Driver, version 24.0
[   731.422] (II) LoadModule: "fbdev"
[   731.423] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[   731.423] (II) Module fbdev: vendor="X.Org Foundation"
[   731.423]    compiled for 1.20.0, module version = 0.5.0
[   731.423]    Module class: X.Org Video Driver
[   731.423]    ABI class: X.Org Video Driver, version 24.0
[   731.423] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   731.423] (II) FBDEV: driver for framebuffer: fbdev
[   731.477] (II) modeset(0): using drv /dev/dri/card0
[   731.477] (WW) Falling back to old probe method for fbdev
[   731.477] (II) Loading sub module "fbdevhw"
[   731.477] (II) LoadModule: "fbdevhw"
[   731.478] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   731.478] (II) Module fbdevhw: vendor="X.Org Foundation"
[   731.478]    compiled for 1.20.4, module version = 0.0.2
[   731.478]    ABI class: X.Org Video Driver, version 24.0
[   731.479] (II) modeset(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[   731.479] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[   731.479] (==) modeset(0): RGB weight 888
[   731.479] (==) modeset(0): Default visual is TrueColor
[   731.479] (II) Loading sub module "glamoregl"
[   731.479] (II) LoadModule: "glamoregl"
[   731.480] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[   731.501] (II) Module glamoregl: vendor="X.Org Foundation"
[   731.501]    compiled for 1.20.4, module version = 1.0.1
[   731.501]    ABI class: X.Org ANSI C Emulation, version 0.4
[   731.826] (II) modeset(0): glamor X acceleration enabled on VC4 V3D 2.1
[   731.826] (II) modeset(0): glamor initialized
[   731.877] (II) modeset(0): Output HDMI-1 has no monitor section
[   731.930] (II) modeset(0): EDID for output HDMI-1
[   731.930] (II) modeset(0): Manufacturer: ACR  Model: 6e4  Serial#: 60272067
[   731.930] (II) modeset(0): Year: 2020  Week: 39
[   731.930] (II) modeset(0): EDID Version: 1.3
[   731.931] (II) modeset(0): Digital Display Input
[   731.931] (II) modeset(0): Max Image Size [cm]: horiz.: 54  vert.: 34
[   731.931] (II) modeset(0): Gamma: 2.20
[   731.931] (II) modeset(0): DPMS capabilities: Off
[   731.931] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[   731.931] (II) modeset(0): First detailed timing is preferred mode
[   731.931] (II) modeset(0): redX: 0.663 redY: 0.328   greenX: 0.300 greenY: 0.610
[   731.931] (II) modeset(0): blueX: 0.150 blueY: 0.063   whiteX: 0.313 whiteY: 0.329
[   731.931] (II) modeset(0): Supported established timings:
[   731.931] (II) modeset(0): 720x400@70Hz
[   731.931] (II) modeset(0): 640x480@60Hz
[   731.931] (II) modeset(0): 640x480@67Hz
[   731.931] (II) modeset(0): 640x480@75Hz
[   731.931] (II) modeset(0): 800x600@56Hz
[   731.931] (II) modeset(0): 800x600@60Hz
[   731.931] (II) modeset(0): 800x600@75Hz
[   731.931] (II) modeset(0): 832x624@75Hz
[   731.931] (II) modeset(0): 1024x768@60Hz
[   731.931] (II) modeset(0): 1024x768@70Hz
[   731.931] (II) modeset(0): 1024x768@75Hz
[   731.931] (II) modeset(0): 1280x1024@75Hz
[   731.931] (II) modeset(0): Manufacturer's mask: 0
[   731.931] (II) modeset(0): Supported standard timings:
[   731.931] (II) modeset(0): #0: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[   731.931] (II) modeset(0): #1: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[   731.931] (II) modeset(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[   731.931] (II) modeset(0): #3: hsize: 1440  vsize 900  refresh: 60  vid: 149
[   731.932] (II) modeset(0): #4: hsize: 1280  vsize 800  refresh: 60  vid: 129
[   731.932] (II) modeset(0): #5: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[   731.932] (II) modeset(0): #6: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[   731.932] (II) modeset(0): #7: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[   731.932] (II) modeset(0): Supported detailed timing:
[   731.932] (II) modeset(0): clock: 193.8 MHz   Image Size:  535 x 339 mm
[   731.932] (II) modeset(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[   731.932] (II) modeset(0): v_active: 1200  v_sync: 1203  v_sync_end 1209 v_blanking: 1243 v_border: 0
[   731.932] (II) modeset(0): clock: 154.0 MHz   Image Size:  535 x 339 mm
[   731.932] (II) modeset(0): v_active: 1200  v_sync: 1203  v_sync_end 1209 v_blanking: 1235 v_border: 0
[   731.932] (II) modeset(0): Ranges: V min: 48 V max: 75 Hz, H min: 30 H max: 95 kHz, PixClock max 205 MHz
[   731.932] (II) modeset(0): Monitor name: Acer BW257
[   731.932] (II) modeset(0): clock: 148.5 MHz   Image Size:  535 x 339 mm
[   731.932] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[   731.932] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[   731.933] (II) modeset(0): Supported detailed timing:
[   731.933] (II) modeset(0): clock: 74.2 MHz   Image Size:  535 x 339 mm
[   731.933] (II) modeset(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[   731.933] (II) modeset(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[   731.933] (II) modeset(0): clock: 27.0 MHz   Image Size:  535 x 339 mm
[   731.933] (II) modeset(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[   731.933] (II) modeset(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[   731.933] (II) modeset(0): h_active: 720  h_sync: 732  h_sync_end 796 h_blank_end 864 h_border: 0
[   731.933] (II) modeset(0): v_active: 576  v_sync: 581  v_sync_end 586 v_blanking: 625 v_border: 0
[   731.933] (II) modeset(0): Number of EDID sections to follow: 1
[   731.933] (II) modeset(0): EDID (in hex):
[   731.933] (II) modeset(0):   00ffffffffffff000472e406c3ad9703
[   731.933] (II) modeset(0):   271e0103803622782acd95a9544c9c26
[   731.933] (II) modeset(0):   105054b76f00d1c081c0818095008100
[   731.933] (II) modeset(0):   b300714f8140af4b80a070b02b403020
[   731.933] (II) modeset(0):   360017532100001a283c80a070b02340
[   731.933] (II) modeset(0):   3020360017532100001e000000fd0030
[   731.933] (II) modeset(0):   4b1e5f14000a202020202020000000fc
[   731.933] (II) modeset(0):   00416365722042573235370a20200183
[   731.933] (II) modeset(0):   020327f14b901f051404130312021101
[   731.933] (II) modeset(0):   230907078301000065030c001000681a
[   731.934] (II) modeset(0):   00000101304be6023a801871382d4058
[   731.934] (II) modeset(0):   2c450017532100001e011d007251d01e
[   731.934] (II) modeset(0):   206e28550017532100001e8c0ad08a20
[   731.934] (II) modeset(0):   e02d10103e96001753210000188c0ad0
[   731.934] (II) modeset(0):   90204031200c40550017532100001800
[   731.934] (II) modeset(0):   000000000000000000000000000000eb
[   731.934] (II) modeset(0): Printing probed modes for output HDMI-1
[   731.934] (II) modeset(0): Modeline "1920x1200"x74.9  193.75  1920 1968 2000 2080  1200 1203 1209 1243 +hsync -vsync (93.1 kHz eP)
[   731.934] (II) modeset(0): Modeline "1920x1200"x60.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync +vsync (74.0 kHz e)
[   731.934] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   731.934] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   731.934] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[   731.934] (II) modeset(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[   731.934] (II) modeset(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[   731.935] (II) modeset(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[   731.935] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[   731.935] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   731.935] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   731.935] (II) modeset(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[   731.935] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   731.935] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[   731.935] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   731.935] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   731.935] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[   731.935] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   731.935] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   731.935] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   731.935] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   731.935] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   731.935] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   731.935] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   731.935] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   731.935] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   731.935] (II) modeset(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   731.935] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   731.935] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   731.935] (II) modeset(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   731.935] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   731.935] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   731.935] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   731.935] (II) modeset(0): Output HDMI-1 connected
[   731.936] (II) modeset(0): Using exact sizes for initial modes
[   731.936] (II) modeset(0): Output HDMI-1 using initial mode 1920x1200 +0+0
[   731.936] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[   731.936] (==) modeset(0): DPI set to (96, 96)
[   731.936] (II) Loading sub module "fb"
[   731.936] (II) LoadModule: "fb"
[   731.936] (II) Loading /usr/lib/xorg/modules/libfb.so
[   731.937] (II) Module fb: vendor="X.Org Foundation"
[   731.937]    compiled for 1.20.4, module version = 1.0.0
[   731.937]    ABI class: X.Org ANSI C Emulation, version 0.4
[   731.937] (II) UnloadModule: "fbdev"
[   731.937] (II) Unloading fbdev
[   731.937] (II) UnloadSubModule: "fbdevhw"
[   731.938] (II) Unloading fbdevhw
[   731.938] (EE)
Fatal server error:
[   731.938] (EE) AddScreen/ScreenInit failed for driver 0
[   731.938] (EE)
[   731.939] (EE)
 for help.
[   731.939] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   731.941] (EE)
[   731.952] (EE) Server terminated with error (1). Closing log file.
I’m also having the same issue with the latest build 2.7.1 on a PI 4
Any ideas?
 browser  xauth: (stdin):1:  bad display name "7df6c5e:0" in "add" command
I realize that this is a pretty old issue, but there seem to be a few around like this, and I have an idea about what the problem is.
The reported error message makes it clear that the problem is arising because the xauth executable doesn’t regard the value of the $DISPLAY environment variable including the hostname as valid. I’m guessing this is because the 7-character device UUID prefix is not resolving. ‘xauth --help’ reveals that there is a ‘-n’ option which can be used to prevent xauth resolving host names, so it would be possible to fix this by applying this option wherever xauth is being invoked in the startup of the X server session - but as this is deep in platform code (possibly in a compiled rather than scripted component), it’s not easy to modify a Dockerfile to do this. Because xauth regards the parameters as invalid, it fails to complete its duty to insert a secret into /root/.Xauthority which the X server can use to challenge clients for their right to connect.
A simple workaround which seems to be working for me is to simply add an extra call to xauth to insert a secret manually, using “:0” instead of “$hostname:0” as the display parameter, for example:
export DISPLAY=:0
xauth add $DISPLAY MIT-MAGIC-COOKIE-1 00000000000000000000000000000000
After hours struggling with this issue today, inserting those two lines into my start.sh directly before ‘startx’ enables me to start an lxterminal in the background under the control of my start.sh.
(Obviously, in any but the most casual environment, a less predictable secret value would be preferred - but I’m guessing any string of hex containing 16 bytes will do).
