Writing to drive ends during end of verification on Windows 11
Hi lovely people,
I’m running balenaEtcher-2.1.4 as Administrator on Windows 11 Pro version 10.0.26100.
I’m trying to make a bootable drive with linuxmint-22.2-cinnamon-64bit.iso on a 16 GB Transcend SD-card. I have formatted the drive to exFat using Diskpart.
“Something went wrong. If it is a compressed image, please check that the archive is not corrupted.
The writer process ended unexpectedly.”
Multiple attempts end with the same error message, always at the end of the verification process. Different iso from earlier releases or distributions gives the same result.
Any idea? Thanks in advance.
Verifying 1 device, 99% at 17.00 MB/s (total 17.00 MB/s) eta in 1s with 0 failed devices
index.js:2 fail event
index.js:2 ObjectblockSize: 512busType: "USB"busVersion: "2.0"description: "USB Mass Storage Device USB Device"device: "\\\\.\\PhysicalDrive1"devicePath: nulldisplayName: "D:\\"enumerator: "USBSTOR"error: nullisCard: falseisReadOnly: falseisRemovable: trueisSCSI: falseisSystem: falseisUAS: falseisUSB: trueisVirtual: falselogicalBlockSize: 512mountpoints: [{…}]partitionTableType: "mbr"raw: "\\\\.\\PhysicalDrive1"size: 15811477504[[Prototype]]: Object
index.js:2 Objectcode: "EVALIDATION"message: "Source and destination checksums do not match: 77c5a939a369bf8c !== cc7719bf7bc9206e"name: "Error"stack: "Error: Source and destination checksums do not match: 77c5a939a369bf8c !== cc7719bf7bc9206e\n    at CountingHashStream.<anonymous> (C:\\snapshot\\etcher\\node_modules\\etcher-sdk\\build\\source-destination\\source-destination.js:158:36)\n    at CountingHashStream.emit (node:events:518:28)\n    at CountingHashStream.<anonymous> (C:\\snapshot\\etcher\\node_modules\\etcher-sdk\\build\\source-destination\\source-destination.js:78:16)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"[[Prototype]]: Object
index.js:2 Flash results Object
index.js:2 Object
index.js:2 Error: The writer process ended unexpectedly
    at i (index.js:353:5238)
    at t.createUserError (index.js:353:6464)
    at p (index.js:140:43913)
    at index.js:140:44229
    at I.<anonymous> (index.js:140:41218)
    at I.emit (node:events:518:28)
    at e.exports.W (index.js:2:2198728)
    at e.exports.emit (node:events:518:28)
    at index.js:2:2174548
    at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
(anonymous) @ index.js:2
media/icon.png:1  Failed to load resource: net::ERR_FILE_NOT_FOUND
index.js:2 Verifying 1 device, 100% at 17.20 MB/s (total 17.20 MB/s) eta in 0s with 0 failed devices
index.js:2 Objectmessage: "Unmount failed"name: "Error"stack: "Error: Unmount failed"[[Prototype]]: Object
index.js:2 Objectresults: {bytesWritten: 3055239168, devices: {…}, errors: Array(1), sourceMetadata: {…}}[[Prototype]]: Object
index.js:2 CHILD: flash done Objectresults: {bytesWritten: 3055239168, devices: {…}, errors: Array(1), sourceMetadata: {…}}[[Prototype]]: Object
index.js:2 Flash results Objectresults: {bytesWritten: 3055239168, devices: {…}, errors: Array(1), sourceMetadata: {…}}[[Prototype]]: Object
Bump
