version 1.5.79 tried the portable and the app, The look is great but it does not work I always get the message: writer program ended unexpectedly try again or if the error persist contact the etcher team. It happened about after 1 or maximum 2 minutes, als the usb then is complety unusable have to reformat with a tool like minitool or kingston format
and yes i tried several usb sticks. I try to write a windows 10 pro lite content in a xz image. what can I do ? im running windows 10 pro
Hi there,
Thanks for the report. Would you be able to open a logs console of Etcher (with ctrl + shift + i) and provide the logs (and error messages) you see there? It will help us to identify the root cause.
