I'm using Balena Etcher Version 1.5.33 Keeps getting stuck at starting
I was trying to flash 2019-04-08-raspbian-stretch.img to my sd card size 64Gb but I get “The writer process ended unexpectedly. Please try again, and contact Etcher team if the problem persists.” whenever I try to flash it. I tried several times giving it administrator to flash I even tried running it as administrator please help. OS Windows 10
Which version of balenaEtcher are you running and what OS+version are you using?
This started happening to me as well after updating it to the last version. I installed the 1.4.6 version and it works fine
@gurbey, which OS are you running on? P.S. welcome to the forums!
I am using Windows 10 laptop. Thank you
Do you see any information in the devtools console when this happens? You can open it with ctrl + shift + i
windows 10
@Greysilly7
Can you check and post in here the console output when this happens?
You can open it by hitting ctrl + shift + i.
