See the 2 pictures above and this https://paste.ubuntu.com/p/SWXZpDJHR2/
I have recreated the whole stack, with the newer balena-sound.
Setup the Region AU so wifi connectton went smoothly.
But still no sound
Hi Pierre, examining the logs you shared I don’t see anything particularly wrong. I’ll ask you to provide a few more diagnostics to proceed troubleshooting. You’ll need to access the following URL with your browser and share the results you get http://<DEVICE_IP>:3000/support (where <DEVICE_IP> is the IP address of your device, you can check the value using balenaCloud dashboard).
Hi Pierre, sorry for the delay we had our annual team summit last week and things were a bit hectic
Did you manage to solve this problem? Checking the support logs you sent I still don’t see anything suspicious. This might sound silly, but did you try power cycling the device?
Next steps if you still have trouble would be for you to provide us with support access to your device. This would allow me to take a look at the device remotely. If you are OK with that here is a quick guide on how to do it. Once you enable support access (please allow it for a couple of days) you will also need to provide us with the UUID of the device. Feel free to PM me with the UUID so that we don’t make it public.
