wifi-connect wont install on Raspberry PI 4
Trying to install wifi-connect on a Raspberry PI 4 and cannot get any further than the “bash <(curl -L https://github.com/balena-io/wifi-connect/raw/master/scripts/raspbian-install.sh)” command.
I get: “wifi-connect: error while loading shared libraries: ld-linux.so.3: cannot open shared object file: No such file or directory”
I loaded Raspberry PI OS Like (32-bit)
This is probably a basic issue, nbut could not find any help in the forum on this.
It looks like there’s an open issue for what you are describing: error during installation · Issue #573 · balena-os/wifi-connect · GitHub
It’s more commonly used in a container, and the Docker image works well: GitHub - balena-io-experimental/wifi-connect: Easy WiFi setup for Linux devices from your mobile phone or laptop
