Hey,
I run a Pi5 with Bookworm 12 (32Bit) and don’t get it working.
May some faced similar issues and found a worksround? It seems the problem is the library ld-linux.so.3 which is missing.
Looking forward to your answers.
Regards
Hey,
Regards
Hello @kuenger first of all welcome to the balena community!
Could you please share more logs of the issues that you found and the workarounds that you are using?
Hey Mpous,
I was trying to install wifi-connect on my raspi5 with bookworm 12 (32-bit). I got it from github - GitHub - balena-os/wifi-connect: Easy WiFi setup for Linux devices from your mobile phone or laptop
I think the problem is the architecture, because I got the following error message:
error while loading shared libraries: ld-linux.so.3
Btw, I got it running on 64Bit Bookworm 12.
