Hi all,
After some time, I was finally able to create an access point for my device.
But after some tweaking with the settings, after some disconnection and activation of the Wi-Fi device, it’s stuck in some sort of loop.
I get the following errors while diagnosing via nmcli dev:
(process:365): GLib-GIO-WARNING **: ../../glib-2.54.3/gio/gdbusobjectmanagerclient.c:1585: Processing InterfaceRemoved signal for path /org/freedesktop/NetworkManager/ActiveConnection/2542 but no object proxy exists
(process:365): GLib-GIO-WARNING **: ../../glib-2.54.3/gio/gdbusobjectmanagerclient.c:1585: Processing InterfaceRemoved signal for path /org/freedesktop/NetworkManager/AccessPoint/2574 but no object proxy exists
I don’t know where the ActiveConnection/2542 or AccessPoint/2574 are coming from, because I haven’t created that many connections. But these are the errors/warnings that are visible when the wlp4s0 is stuck in a loop.
The loop is the following while using nmcli dev monitor wlp4s0:
(process:32051): GLib-GIO-WARNING **: ../../glib-2.54.3/gio/gdbusobjectmanagerclient.c:1585: Processing InterfaceRemoved signal for path /org/freedesktop/NetworkManager/ActiveConnection/509 but no object proxy exists
(process:32051): GLib-GIO-WARNING **: ../../glib-2.54.3/gio/gdbusobjectmanagerclient.c:1585: Processing InterfaceRemoved signal for path /org/freedesktop/NetworkManager/AccessPoint/541 but no object proxy exists
wlp4s0: disconnected
wlp4s0: connecting (prepare)
wlp4s0: using connection 'AP.7E332M010186A55D79'
wlp4s0: connecting (configuring)
wlp4s0: connection failed
And it continues to do that on and on.
Some information:
Hardware: UP Squared
BalenaOS: 2.39.0+rev1 (Development)
Supervisor: 10.1.5
When a container starts, it forces to update the current connection file (because there might be changes), then disconnects wlp4s0 and activates the connection. So maybe this is causing problems, but if somebody has a suggestion to push changes to the connection, I’ll be all ears.
Thanks in advance!
