So I installed balenaOS 2.47.0 on RPi2 (with WiFi-Dongle) and on RPi3 but can only get them online via LAN. Rebooting them or disconnecting from ethernet will let the ACT LED show connection error.
When connected via LAN and starting a Host OS terminal in balenaCloud I tried various checks.
ifconfig not returning any wlan nmcli d wifi list returns nothing (not even headings) nmcli device status also doesn’t show any wlan
Tried also to run those commands with my RPi3 and the WiFi Dongle installed to check if maybe the onboard wifi is broken but returns same results. The RPi3 running raspbian connects to wifi without any hassle.
root@35584d7:~# lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=, Driver=smsc95xx, 480M
|__ Port 2: Dev 4, If 0, Class=, Driver=, 480M
But since I’m using a RPi3 I shouldn’t need the WiFi Dongle because there is a built in WiFi.
Hello, can you check dmesg on the host for errors related to nm and/or wlan interfaces? Feel free to post the logs in here if not sure what to search for. nmcli device status not showing the interface is what is troubling to me.
Hi, thanks for providing those logs, which don’t indicate any issues. Can you paste the output of nmcli device status - I appreciate you previously said wlan isn’t showing but it’d help to see the output. Also, just ruling out you haven’t disabled the wifi e.g. via the dtoverlay in config.txt or via a configuration variable in balenaCloud?
That is strange and I guess we can rule out a hardware issue if working with Raspbian. Can you confirm the host OS version you used for the Pi3 as in did you choose the Raspberry Pi 3 device type or Raspberry Pi 3 (using 64bit OS)? Is it a development or production version? Did you download the image for each device from the balenaCloud dashboard?
I chose Raspberry Pi 3 as device type (not 64bit) and it is production version. (Also tried development and 64bit but neither worked.) Furthermore I installed balenaSound if that can may be an issue? For the RPi2 I created a new device in balenaCloud and set it to use the Raspberry Pi 2 as device type when downloading the image.
Atm I’m only running this one RPi3 with latest balenaOS version and connected via ethernet.
Thanks for confirming, can you send the output of the command cat /mnt/boot/config.txt. You can run this from the host OS. Just want to ensure some accidental config variable isn’t the root issue.
Thanks, that rules that out. I’m at a bit of loss what else to suggest other than defective hardware. Perhaps as one final try you could create a new empty application, download the image and reflash the device and do not push anything to it and see the output of nmcli device status when the device is in this fresh state?
So created a new application and flashed it on my sd card. Started the RPi3 at first boot without ethernet connected. After some short time the ACT LED shows again no connection. Pluged the ethernet cable in and let the RPi3 boot again. Now he shows up in balenaCloud. Output of Network Manager:
root@20986c0:~# nmcli device status
DEVICE TYPE STATE CONNECTION
eth0 ethernet connected Wired connection 1
supervisor0 bridge connected supervisor0
balena0 bridge unmanaged --
br-ead835d0f90b bridge unmanaged --
resin-dns bridge unmanaged --
lo loopback unmanaged --
resin-vpn tun unmanaged --
Well I think I’m now running balenaSound via ethernet since it’s the only way I can get it working. Thanks for your support anyway.
I know this might be asking the obvious, but I don’t see it mentioned anywhere – when downloading the image from the dashboard, did you tell the device to use WiFi and provide the network SSID and passphrase? Without those settings, the interface will not be configured.
Yes sure I did. I even checked manually the resin-wifi-01 file if it was correctly configured. I also tested to rename the resin-wifi-01 to resin-wifi because the file is named that way in the documentation / guide.
If I didn’t tell the device to use WiFi when downloading the image from BalenaCloud, which based on your response means the interface won’t be configured, how can I manually configured it ? Maybe using nmcli
By the way, I’m running a RPi3 Model B with BalenaOS 2.113.18, development version and in local mode.
