Which image to use with Nvidia Orin NX 8GB 256GB SSD
Which image to use for Nvidia Jetson Orin NX 8GB 256GB SSD?
Hi @haytham-amin,
Thanks for contacting us. Which carrier board are you using with the Orin NX 8GB module?
Hello @rosswesleyporter,
Appreciate your response. I am using Jetson Xavier NX Carrier board with the Orin NX 8GB module.
Hello @Haytham_Amin first of all welcome to the balena community!
At the moment the 8GB Orin NX module isn’t supported by balena with any carrier board. I believe that the image we provide in the dashboard for the 16G module will not work for your setup. We only have the hardware and support the 16GB RAM Orin NX module in the NVIDIA Xavier NX Devkit.
Do you use the 8GB Orin NX for any specific reason?
Hey @mpous, appreciate your warm welcome.
I am trying to test use the device with Lumeo software. Will stick to the 16GB Orin NX for now.
Much thanks.
Let us know if you have any questions with the 16GB Orin NX @Haytham_Amin
Hello @Haytham_Amin do you have any problem configuring the 16GB Orin NX?
Let us know if we can help you more!
