Help! noob here has RaspPi1 w/ DAC and can’t get it set up. Also, will this support PlexAmp? Thanks!
@christopher-rivera,
Hey there! Thanks for reaching out. ![]()
You mentioned that you can’t get your DAC setup - can you share a bit more about how far you’ve gotten? A few questions to help us get started:
- Just to make sure you’re using the
raspberry-pidevice-type when you create your device in balenaCloud - What DAC are you trying to install and what process did you use to do so?
- Are you having trouble with configuration? Is the audio not coming through? Please share a bit more about the exact problem you’re experience in your process of getting it started.
Meanwhile, I see Linux installers for PlexAmp, but I don’t see them containerized. balenaOS is built on containers, particularly dockerfiles, so it would need to be containerized first to work.
Anyway, let us know a bit more about your situation and we’ll do what we can to help get you started. ![]()
Thank you so much for getting back to me, but I abandoned the project in favor of Plex. Thanks, and happy holidays!
