Hi, I’m trying to try out the Go Docker image for the VAB-820, and run into the issue of not being able to push to it.
I’m using the resin-golang-seed project with the only change of setting the base image explicitely as
FROM resin/vab820-quad-golang:latest
Unfortunately it looks like I cannot push to it. If I git push to the master branch, I have this log:
$git push resin master
Counting objects: 44, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (34/34), done.
Writing objects: 100% (44/44), 29.16 KiB | 0 bytes/s, done.
Total 44 (delta 4), reused 0 (delta 0)
Starting build for imrehg/gotest
Building on 'local'
-----> Dockerfile application detected
Step 0 : FROM resin/vab820-quad-golang:latest
---> ccb7a5b8ee0e
Step 1 : ENV INITSYSTEM on
---> Running in 9dcf60617fd6
---> c3dab334c80f
Removing intermediate container 9dcf60617fd6
Step 2 : COPY src/ $GOPATH/src
---> a542b4d6f235
Removing intermediate container 9ece5112e5c3
Step 3 : COPY vendor $GOPATH/vendor
---> f31f53a77245
Removing intermediate container ce8cb20fcc4a
Step 4 : RUN cd $GOPATH
---> Running in b6c27c493f98
---> c688db9be3a6
Removing intermediate container b6c27c493f98
Step 5 : RUN go get github.com/constabulary/gb
---> Running in ecf48e4c9b06
fatal error: rt_sigaction failure
runtime stack:
runtime.throw(0x485f20, 0x14)
/go/src/runtime/panic.go:527 +0x78
runtime.setsigstack(0x21)
/go/src/runtime/os1_linux.go:311 +0xf8
runtime.initsig()
/go/src/runtime/signal1_unix.go:62 +0x114
runtime.mstart1()
/go/src/runtime/proc1.go:717 +0xd4
runtime.mstart()
/go/src/runtime/proc1.go:691 +0x84
goroutine 1 [runnable]:
runtime.main()
/go/src/runtime/proc.go:28
runtime.goexit()
/go/src/runtime/asm_arm.s:1036 +0x4
goroutine 17 [syscall, locked to thread]:
runtime.goexit()
Removing intermediate container ecf48e4c9b06
Error while processing push: Error: The command [/bin/sh -c go get github.com/constabulary/gb] returned a non-zero code: 2
To imrehg@git.resin.io:imrehg/gotest.git
! [remote rejected] master -> master (hook declined)
Quick google suggest that fatal error: rt_sigaction failure is a QEMU-related failure. Based on this I tried to push to master-arm, as I remember that was supposed to address the QEMU’s issues for builds. I know that the VAB-820 wasn’t in the list where I could do that, just gave it a try to see what happens. It got further in the process and then died differently:
$git push resin master:master-arm
Building on 'arm.builders.resin.io'
Still working...
Still working...
---> ccb7a5b8ee0e
---> Running in 882da729b846
Still working...
---> 2a83a88edefe
Removing intermediate container 882da729b846
Still working...
---> 92b57cb94bd9
Removing intermediate container a6034f01b37d
Still working...
Still working...
---> 7aa0cabcb55b
Removing intermediate container 155d2c940647
---> Running in bb906e57830b
Removing intermediate container bb906e57830b
Error while processing push: Error: [8] System error: mountpoint for blkio not found
remote: error: hook declined to update refs/heads/master-arm
! [remote rejected] master -> master-arm (hook declined)
Any suggestions? Just probing things, so I know that this is all very experimental (the hardware, Go support, and ARM builders).
Cheers!
Just FYI.
