I am trying to convert a docker based product to Resin but as I push to resin I get he normal “starting build for x” and then immediately an exception is thrown:
$ git push resin combine-all:master
Counting objects: 1343, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (1175/1175), done.
Writing objects: 100% (1343/1343), 2.01 MiB | 0 bytes/s, done.
Total 1343 (delta 433), reused 153 (delta 78)
Starting build for user_name/app_name
remote: events.js:141
remote: throw er; // Unhandled 'error' event
remote: ^
remote:
remote: Error: read ECONNRESET
remote: at exports._errnoException (util.js:837:11)
remote: at Pipe.onread (net.js:544:26)
remote:
To user_name@git.resin.io:user_name/app_name.git
! [remote rejected] combine-all -> master (hook declined)
error: failed to push some refs to 'user_name@git.resin.io:user_name/app_name.git'
I have been able to build the project locally on a Raspberry Pi 2 running docker directly. So it doesn’t appear to be an issue with the Dockerfile itself.
I’ve also tried both master and master-arm. The error message doesn’t give much to go on so does anyone have suggestions for how I can debug what is going on here?
It works fine if I use a test project ( used the simple python project). It is just this specific project fails in the same manner every time I push it to Resin.
Can you give me your resin username and application name? Afterwards I can check my admin panel for errors. If this is also private, you can use the little question mark at the bottom right corner of the dashboard to have a private conversation with us
Just to add some closure to the thread, we’ve followed up over intercom and resolved this issue, and also fixed a bug with weird filenames. Thanks @moose!
Yes - all good now. I just had some oddly encoded example files in my repo. @petrosagg was able to locate the issue and resolve it in short order. In fact he already had a fix in the pipeline for dpeloyment
