Use balena sound
Hello, i need help with installing balena sound i have an image running on raspberry pi i dont understand how balena-cli works and i want to use the raspberry as bleutooth audio receiver. i granted support acces can someone help?
Hi @ryan Have you downloaded balenaSound from the GitHub or are you trying to join the Open Fleet? For a beginner you might find joining the open fleet a lot easier. Also can I check which version of the Raspberry Pi are you using?
In case you hadn’t seen it the open fleet is on balenaHub here: balenaHub: an easier way to find and publish fleets, projects, and blocks for edge devices
