Hi all,
I have a RPi4 4gb that is running balenaOS 2.83.10+rev1 and is on the 3.6.9 balena-sound release.
Spotify Connect works fine, and I can get audio from the onboard 3.5mm. However, even when I reboot with a USB soundcard plugged in (I have tried both an SMSL SU-9 and an Audioengine D1), it does not find the USB soundcard.
I have not changed DT overlay, since I have read that versions 3.0 and up should not require any changes to variables and should default to USB sound on boot up.
alsamixer does not show the USB soundcards as an output option.
Here’s what I get when I list sinks:
bash-5.0# pactl list sinks
Sink #0
State: RUNNING
Description: Built-in Audio Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 6
Mute: no
Volume: front-left: 49152 / 75% / -7.50 dB, front-right: 49152 / 75% / -7.50 dB
balance 0.00
Base Volume: 56210 / 86% / -4.00 dB
Monitor Source: alsa_output.bcm2835-jack.stereo-fallback.monitor
Latency: 64705 usec, configured 66666 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = “16”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “bcm2835 Headphones”
alsa.id = “bcm2835 Headphones”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0”
alsa.device = “0”
alsa.card = “0”
alsa.card_name = “bcm2835 Headphones”
alsa.long_card_name = “bcm2835 Headphones”
alsa.driver_name = “snd_bcm2835”
device.bus_path = “/devices/platform/soc/fe00b840.mailbox/bcm2835_audio/sound/card0”
sysfs.path = “/devices/platform/soc/fe00b840.mailbox/bcm2835_audio/sound/card0”
device.form_factor = “internal”
device.string = “hw:0”
device.buffering.buffer_size = “131072”
device.buffering.fragment_size = “131072”
device.access_mode = “mmap+timer”
device.profile.name = “stereo-fallback”
device.profile.description = “Stereo”
device.description = “Built-in Audio Stereo”
alsa.mixer_name = “Broadcom Mixer”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card”
Ports:
analog-output-headphones: Headphones (priority: 9900)
Active Port: analog-output-headphones
Formats:
pcm
Sink #1
State: RUNNING
Description: Null Output
Driver: module-null-sink.c
Owner Module: 23
Mute: no
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: balena-sound.input.monitor
Latency: 10808 usec, configured 66666 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = “Null Output”
device.class = “abstract”
Formats:
pcm
Sink #2
State: RUNNING
Owner Module: 24
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor Source: balena-sound.output.monitor
Latency: 3831 usec, configured 20000 usec
Properties:
Formats:
pcm
Sink #3
State: RUNNING
Owner Module: 25
Mute: no
balance 0.00
Monitor Source: snapcast.monitor
Latency: 6945 usec, configured 23219 usec
Properties:
Formats:
Any help would be much appreciated! Thanks all.
