tts v3 basic station
Good to hear @kilnageer i used to restart it in the past to get the certificates downloaded, but since last PR it worked great.
I will try to reproduce this error and check if this is a problem of the pi 3.
Let us know if we can help you with anything else!
Hi
Another one with TTS V3 SX1301 concentrator problem.
I have iC880A-SPI on RPI 3B+ with ttn Zurich backplane. SD card with packet forwarder and V3 link is working on the same hardware(with TTN Zurich script) . SD card with Balena Basic Station is another story. I’m no expert in programming, just read and assemble :slight_smile: I attach the log file if someone can pull something out of it.
Best regards,
Miha
basicstation_artsy-dawn-14.11.21_10_44_27_(+0000).txt (107.4 KB)
Yes! I can see the error
14.11.21 10:41:31 (+0000) <main> 2021-11-14 10:41:31.323 [RAL:ERRO] Concentrator start failed: lgw_start
14.11.21 10:41:31 (+0000) <main> 2021-11-14 10:41:31.323 [RAL:ERRO] ral_config failed with status 0x08
14.11.21 10:41:31 (+0000) <main> 2021-11-14 10:41:31.323 [any:ERRO] Closing connection to muxs - error in s2e_onMsg
I don’t have a iC880A-SPI myself, so let me ping @xoseperez in case he can help on this.
OK
Is that mean that there is no working installation at all?
Hello @fontane thank you for your question!
That means the number of devices that the fleet of the fleet owner (creators of the Projects on balenaHub) on balenaCloud have.
In my case, I created the fleet, tested with devices, published on Hub and the devices are now running other projects. But installation may work on most of them.
Did you have any issue installing any?
Let’s stay connected
My RPI3+iC880A-SPI is not working. I’m interested if anyone has a working installation with RPI3b+ & ic880.
The only one i know running basicstation with IC880A-SPI is @xoseperez @fontane
Let’s see if he can help :slight_smile:
Usually the problem is the RESET GPIO and it depends on the hat/adapter you are using to connect the iC880A to the Raspberry. If the concentrator is not porperly reset before stablishing the connection via SPI it will probably fail (concentrator not found).
Check what GPIO is using the ā€œold packet forwarderā€, if it’s Gonzalo Casas’ backplane it uses GPIO25 (physical pin #22).
