I currently try to reuse an old project that I worked on quite 4(?) years ago. I made in that time a dashboard based on an Electron + React combination and I wanted to reuse that for a current project, but somehow I have problems to get it back on track (I didn’t do much raspberry things lately).
The good news is: I can build from the old files (tho with old versions, I have also a few warnings) but I don’t get any picture (I connected a full HD Dell Monitor with HDMI).
Originally I used this repo as the base: GitHub - balenalabs/balena-electronjs: electronJS-based resin application template (When it was still resin).
When I build and run it I get the following logs, now I don’t know if I just have to update the Electron version or this the problem is somewhere else. If someone would have a hint for me that would be great.
main hostname: No address associated with hostname
main xauth: (stdin):1: bad display name "991f0f5:1" in "add" command
main
main
main X.Org X Server 1.19.2
main Release Date: 2017-03-02
main X Protocol Version 11, Revision 0
main Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
main Current Operating System: Linux 991f0f5 5.10.31-v7 #1 SMP Fri Apr 23 15:16:49 UTC 2021 armv7l
main Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 dwc_otg.lpm_enable=0 console=null rootwait vt.global_cursor_default=0 cgroup_enable=memory root=UUID=ba1eadef-0566-41f4-bce6-38ccd0b27031 rootwait
main Build Date: 18 October 2017 04:55:30PM
main xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
main Current version of pixman: 0.34.0
main Before reporting problems, check http://wiki.x.org
main to make sure that you have the latest version.
main Markers: (--) probed, (**) from config file, (==) default setting,
main (++) from command line, (!!) notice, (II) informational,
main (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
main (==) Log file: "/var/log/Xorg.1.log", Time: Mon Jul 25 13:17:56 2022
main (==) Using system config directory "/usr/share/X11/xorg.conf.d"
main Electron 1.6.x has reached the end of its support cycle.
main Developers are encouraged to upgrade their applications to a newer series.
main Read about newer series at https://electronjs.org/releases .
main Read about Electron support at https://electronjs.org/docs/tutorial/support#supported-versions .
main [44:0725/131827.706944:ERROR:bus.cc(427)] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
main [44:0725/131827.952040:WARNING:audio_manager.cc(317)] Multiple instances of AudioManager detected
main [44:0725/131827.952317:WARNING:audio_manager.cc(278)] Multiple instances of AudioManager detected
main [44:0725/131828.592040:ERROR:bus.cc(427)] Failed to connect to the bus: /usr/bin/dbus-launch terminated abnormally without any error message
main listing on 80
main show window of electron
