I’m trying to flash a tinypilot image. The flash fails but I have to other error message. It is about an 3G image on a 64G SD card. Also, after flashing the SD card shows 248M free. Any way to get more information as to why it failed?
hi, you might want to check if the FS on the card is corrupt. This post Etcher broke my USB stick … or did it? provides some insights.
I did a reformat on the card as well as tried multiple cards. Same result.
Gave up on Balena and used Rufus instead. Working fine.
