This project is using an old URL.
Several of my RPi are showing this message:
"This project is using an old URL. When convenient, remove the project, then add https://boinc.bakerlab.org/rosetta/
They are continuing to run as far as I can tell.
All my rpis are showing that same message, but when I did what they said, detach the project then re-attach, nothing changed.
I checked the config, and my rpi were already using the recommended URL.
I have stopped investigating.
Cheers,
G
I think the error/warning is being caused as the URL in the image is http:// and the new/current project url is now https://
I’m running the https://foldforcovid.io/ image, so I can’t remove/re-add the project as I don’t know the user credentials. Will need the Balena team to push out an update AFAIK.
Hope this helps
Martin
we need 2 things
a) a PR to change URL in ACCOUNT* file from http to https
then
b) git pull | balena push to every node
or some way to auto update every node in the network
