Hi all,
I’m thinking I might have a look at adding board support for Freescale’s SoloLite (imx6slevk) as we may be using a variant of this for an upcoming project.
Has anybody already looked at this? Don’t want to re-invent the wheel.
Alex
Hi all,
Alex
Hey Alex,
I haven’t heard of anyone working on that board. But I do know @andrei has some updated instructions for how to add a device to resin, so if you can ping him, he can show you the way
Hi Alex,
The first source of documentation I want to mention is http://docs.resin.io/#/pages/hardware/meta-resin.md . After you have your resin layer ready:
Right now your image is almost complete. The only thing it lacks is a resin configuration file. So you have two ways of doing this:
This should be a temporary trick until you get all the support submitted to resin and we will create you an entry in UI along with an icon.
Hope this is clear.
Here are some additional links:
Thanks @alexandros, @andrei. That looks like just what I need.
I have the Freescale SoloLite EVK on the way to take a look at next week, but in the meantime I thought I’d have a look at building for the Boundary Devices Nitrogen6 Lite (somewhat counter-intuitively based on the Solo part) as I have one to hand.
Unfortunately I seem to be failing at the first hurdle as both my own builds and the downloadable image from BD seem to block on u-boot startup with a spinner (pic attached). I may need to go back to Boundary Devices about this but wondered if you’d seen anything similar?
Cheers, Alex
Hi @ajlennon,
Does uboot have any timeout so you can get into prompt? I suspect they are trying to boot from tftp or similar by default.
Andrei
Yes I started having a look at that. I can break into the boot sequence and started having a look at the scripting. It seems as though it should be trying to boot from the uSD but for some reason isn’t. I was going to have a look at hand-rolling the load of the DTB and the kernel next… The documentation states it should just load from uSD though so I think there’s something strange going on.
Can you share a pastebin of uboot’s printenv?
And this is the 6x_bootscript it is trying to load and run from the FAT partition
[Edit: It looks as though it is dropping through to run “ums” which seems to be something that exposes the drive over the USB OTG port. Nice idea. So I guess something somewhere earlier on in the script is failing for some reason]
[Edit #2: It looks as though if I break into u-boot and explicitly set the dtbname environment variable to im6dl-nit6xlite.dtb then it all boots up]
I had to make some changes to get meta-resin to build against the latest Fido commit #fa55b8e5.
I’ve put the changes in a fork here: https://github.com/DynamicDevices/meta-resin/commits/master
If you think these looks sensible I can submit a pullreq.
That gets me a resin-image built which boots on the Nitrogen6-lite. It seemed to need a few boots to sort itself out, and was displaying time-outs and such, but seems OK now.
I built for staging so now I’m trying to create an application on the Resin staging server to try to grab the configuration but it’s giving me ETIMEDOUT errors.
