Is it possible to set device environment variables via the CLI or SDK in openBalena in the same way as balenaCloud? I’ve tried the CLI but without much luck so far.
Edit: using the SDK is currently returning an SSL cert error due to self-signed cert so may work once tweaked
@WillFG the SSL error is caused when you are trying to control your openBalena install which has a self-signed CA certificate. This is how it is setup by default, so I would expect that this is the case here.
To circumvent this, you need to export the variable NODE_EXTRA_CA_CERTS with the path to the CA certificate generated during the openBalena setup; usually in the ./open-balena/config/certs/ca directory.
@richbayliss - I fixed the error using the same method as described but with Python via REQUESTS_CA_BUNDLE
However, getting a 404 using the Python SDK at /v4/device so I’ll try using the CLI again as @imrehg described, having checked I’m using the correct version.
@imrehg - getting the below using the CLI - can confirm version is 9.0.2
balena env add WIBBLE 1 --device xxxxx
BalenaRequestError: Request error: Database error
I will update to 9.0.3 and also see if I can dig up some logs on the server and report back.
@WillFG you should be good only exposing 443 for now. Note that we’ll soon require 3128 as well for device SSH.
The Python SDK currently cannot target an open-balena instance – it still assumes the full balenaCloud API.
Regarding the env vars issue you’re seeing, can you please make sure you completely remove previous CLI versions before updating – NPM might not pick up new versions of dependencies.
@dfunckt I have tried on a few different machines and get the same result, including standalone installs.
I’m wondering whether the api_version in ~/.resin/resin.cfg should still be v4?
I took the cfg file from previous install of CLI when working against balenaCloud and just updated URLs, so wondering if that could be an issue.
@dfunckt I just looked at env-vars.ts and thought maybe it was a whitelisting problem.
I then tried BALENA_SOMETHING and RESIN_SOMETHING and it worked
Nov 09 14:51:14 dad477126c02 api[862]: resin: INSERT INTO “device config variable” (“device”, “name”, “value”)
Nov 09 14:51:14 dad477126c02 api[862]: VALUES ($1, $2, $3) [ 1, ‘BALENA_NAME’, ‘TEST’ ]
Nov 09 14:51:14 dad477126c02 api[862]: resin: Parsing GET /resin/device?$select=id&$filter=((is_connected_to_vpn eq true) and (vpn_address ne null)) and (id in (1))
Nov 09 14:51:14 dad477126c02 api[862]: resin: Running GET /resin/device?$select=id&$filter=((is_connected_to_vpn eq true) and (vpn_address ne null)) and (id in (1))
Edit: just realised that’s adding into config variables rather than device environment variables but it is passing it through in the POST at least.
Edit2: I removed the resin.cfg so will reinstate and set to v5 to see if that helps
Tried setting with reserved names, which appeared to work, although I have not checked whether they are retrievable
reinstated resin.cfg with explicit api_version = v5 and the behaviour is the same
I expect it is something obvious that I am doing wrong…will look into env-vars.ts and see how it handles the POSTS. Apologies for the very long thread, I think I will have it figured out reasonably soon!
Try removing the whole ~/.resin and ~/.balena folders to start fresh. Then login again with the CLI and try setting a non-reserved env var – i.e. something not prefixed with RESIN_ or BALENA_ (I think these are automatically saved as config vars as you found out).
Please ignore my comment below if it is clearly wrong. I will fork and see if I can fix it.
This is a complete stab in the dark but I’m wondering whether this method should not have name rather than env_var_name in it:
addEnvHooks(
‘device_environment_variable’, ’env_var_name’,
checkEnvVarValidity,
args: sbvrUtils.HookArgs & {
tx: Tx;
if (args.req.body.device != null) {
// If we have a device passed in the body (ie POST) then we can use that as ID filter.
return Promise.resolve({ id: args.req.body.device });
will@MAVEN-MINT:~$ npm -g ls | grep balena-sdk
│ │ └─┬ balena-sdk@11.0.0
│ ├─┬ balena-sdk@11.1.0
npm ERR! peer dep missing: balena-auth@^2.0.0, required by balena-request@10.0.0
npm ERR! error in /usr/local/lib/node_modules/resin-cli: ENOENT: no such file or directory, open '/usr/local/lib/node_modules/resin-cli/package.json'
npm ERR! extraneous: aws-sdk /usr/local/lib/node_modules/resin-cli/node_modules/aws-sdk
npm ERR! error in /usr/local/lib/node_modules/resin-cli/node_modules/aws-sdk: ENOENT: no such file or directory, open '/usr/local/lib/node_modules/resin-cli/node_modules/aws-sdk/package.json'
npm ERR! extraneous: degenerator /usr/local/lib/node_modules/resin-cli/node_modules/degenerator
npm ERR! error in /usr/local/lib/node_modules/resin-cli/node_modules/degenerator: ENOENT: no such file or directory, open '/usr/local/lib/node_modules/resin-cli/node_modules/degenerator/package.json'
npm ERR! extraneous: docker-modem /usr/local/lib/node_modules/resin-cli/node_modules/docker-modem
npm ERR! error in /usr/local/lib/node_modules/resin-cli/node_modules/docker-modem: ENOENT: no such file or directory, open '/usr/local/lib/node_modules/resin-cli/node_modules/docker-modem/package.json'
npm ERR! extraneous: escodegen /usr/local/lib/node_modules/resin-cli/node_modules/escodegen
npm ERR! error in /usr/local/lib/node_modules/resin-cli/node_modules/escodegen: ENOENT: no such file or directory, open '/usr/local/lib/node_modules/resin-cli/node_modules/escodegen/package.json'
npm ERR! extraneous: resin-cli-visuals /usr/local/lib/node_modules/resin-cli/node_modules/resin-cli-visuals
npm ERR! error in /usr/local/lib/node_modules/resin-cli/node_modules/resin-cli-visuals: ENOENT: no such file or directory, open '/usr/local/lib/node_modules/resin-cli/node_modules/resin-cli-visuals/package.json'
npm ERR! extraneous: resin-device-config /usr/local/lib/node_modules/resin-cli/node_modules/resin-device-config
npm ERR! error in /usr/local/lib/node_modules/resin-cli/node_modules/resin-device-config: ENOENT: no such file or directory, open '/usr/local/lib/node_modules/resin-cli/node_modules/resin-device-config/package.json'
npm ERR! peer dep missing: resin-request@^9.0.2, required by resin-register-device@5.0.0
will@MAVEN-MINT:~$ npm -g ls | grep balena-cli
├─┬ balena-cli@9.1.0
I believe the missing peer dependencies are fine but the references to resin-cli are puzzling. Can you try the following to clean things up a bit? (I’m assuming rm -rf /usr/local/lib/node_modules/* && npm -g cache clean --force is not an option).
│ │ ├─┬ balena-sdk@11.0.0
│ │ ├── balena-sdk@11.1.0 deduped
Ran the above inc. removing node modules and get the below now.
Still same database error as previously so will see how easy it is to remote debug the API.
└─┬ balena-cli@9.1.0
