Here’s the error log from the open-balena API backend container (I’ve substituted the actual UUID for <uuid>):
Parsing GET /resin/device?$filter=startswith(uuid,%27<uuid>%27)&$select=device_name,id,device_type,overall_status,is_online,ip_address,mac_address,last_connectivity_event,uuid,is_on__commit,supervisor_version,is_web_accessible,note,os_version&$expand=belongs_to__application($select=app_name)
Failed to translate url: {
"resource": "device",
"options": {
"$filter": [
"call",
"args": [
"name": "uuid",
"property": null
"bind": 0
"method": "startswith"
"$select": {
"properties": [
"name": "device_name",
"property": null
"name": "id",
"property": null
"name": "device_type",
"property": null
"name": "overall_status",
"property": null
"name": "is_online",
"property": null
"name": "ip_address",
"property": null
"name": "mac_address",
"property": null
"name": "last_connectivity_event",
"property": null
"name": "uuid",
"property": null
"name": "is_on__commit",
"property": null
"name": "supervisor_version",
"property": null
"name": "is_web_accessible",
"property": null
"name": "note",
"property": null
"name": "os_version",
"property": null
"$expand": {
"properties": [
"name": "belongs_to__application",
"property": null,
"count": null,
"options": {
"$select": {
"properties": [
"name": "app_name",
"property": null
} GET SyntaxError: Could not resolve relationship mapping
at OData2AbstractSQL.ResolveRelationship (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:514:19)
at OData2AbstractSQL.ReferencedField (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:562:46)
at OData2AbstractSQL.AliasSelectField (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:546:38)
at AddSelectFields._.reject.map.field (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:532:36)
at arrayMap (/usr/src/app/node_modules/lodash/lodash.js:639:23)
at Function.map (/usr/src/app/node_modules/lodash/lodash.js:9556:14)
at interceptor (/usr/src/app/node_modules/lodash/lodash.js:16993:35)
at thru (/usr/src/app/node_modules/lodash/lodash.js:8797:14)
at /usr/src/app/node_modules/lodash/lodash.js:4374:28
at arrayReduce (/usr/src/app/node_modules/lodash/lodash.js:683:21)
at baseWrapperValue (/usr/src/app/node_modules/lodash/lodash.js:4373:14)
at LazyWrapper.lazyValue [as value] (/usr/src/app/node_modules/lodash/lodash.js:1859:16)
at baseWrapperValue (/usr/src/app/node_modules/lodash/lodash.js:4371:25)
at LodashWrapper.wrapperValue (/usr/src/app/node_modules/lodash/lodash.js:9052:14)
at OData2AbstractSQL.AddSelectFields (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:533:18)
at OData2AbstractSQL.PathSegment (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:351:18)
at OData2AbstractSQL.match (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:177:32)
at memoizeWeak (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/uri-parser.js:55:51)
at /usr/src/app/node_modules/es5-ext/function/#/partial.js:14:16
at /usr/src/app/node_modules/memoizee/lib/configure-map.js:61:24
at /usr/src/app/node_modules/memoizee/lib/weak.js:87:21
at memoizedOdata2AbstractSQL (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/uri-parser.js:78:56)
at exports.translateUri (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/uri-parser.js:184:34)
at tryCatcher (/usr/src/app/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/usr/src/app/node_modules/bluebird/js/release/promise.js:512:31)
at Promise._settlePromise (/usr/src/app/node_modules/bluebird/js/release/promise.js:569:18)
at Promise._settlePromise0 (/usr/src/app/node_modules/bluebird/js/release/promise.js:614:10)
at Promise._settlePromises (/usr/src/app/node_modules/bluebird/js/release/promise.js:694:18)
at Promise._fulfill (/usr/src/app/node_modules/bluebird/js/release/promise.js:638:18)
at Promise._resolveCallback (/usr/src/app/node_modules/bluebird/js/release/promise.js:432:57)
at Promise._settlePromiseFromHandler (/usr/src/app/node_modules/bluebird/js/release/promise.js:524:17)
at MappingPromiseArray.PromiseArray._resolve (/usr/src/app/node_modules/bluebird/js/release/promise_array.js:126:19)
at MappingPromiseArray._promiseFulfilled (/usr/src/app/node_modules/bluebird/js/release/map.js:101:18)
at Promise._settlePromise (/usr/src/app/node_modules/bluebird/js/release/promise.js:574:26)
at Holder$2._callFunction (<anonymous>:19:29)
at _drainQueueStep (/usr/src/app/node_modules/bluebird/js/release/async.js:142:12)
at _drainQueue (/usr/src/app/node_modules/bluebird/js/release/async.js:131:9)
at Async._drainQueues (/usr/src/app/node_modules/bluebird/js/release/async.js:147:5)
at Immediate.Async.drainQueues [as _onImmediate] (/usr/src/app/node_modules/bluebird/js/release/async.js:17:14)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:120:23)
Parsing PATCH /resin/service_instance(60)
