Balena env rm: Database error
Original Github issue: https://github.com/balena-io/open-balena/issues/61
As of right now, deleting environment variables on openBalena is not possible due to a BalenaRequestError: Request error: Database error. This happens on device and application variables.
$ balena -v
11.7.3
$ balena env add BALENA_SUPERVISOR_LOCAL_MODE 1 --device 0a160ca
$ balena envs --device 0a160ca --config
ID NAME                         VALUE
1  BALENA_SUPERVISOR_LOCAL_MODE 1
$ balena env rm BALENA_SUPERVISOR_LOCAL_MODE --device 0a160ca
? Are you sure you want to delete the environment variable? Yes
    at C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\balena-request\build\request.js:197:17
    at tryCatcher (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\util.js:16:23)
    at Promise._settlePromiseFromHandler (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\promise.js:517:31)
    at Promise._settlePromise (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\promise.js:574:18)
    at Promise._settlePromise0 (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\promise.js:619:10)
    at Promise._settlePromises (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\promise.js:699:18)
    at _drainQueueStep (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\async.js:138:12)
    at _drainQueue (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\async.js:131:9)
    at Async._drainQueues (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\async.js:147:5)
    at Immediate.Async.drainQueues [as _onImmediate] (C:\ProgramData\nvm\v12.7.0\node_modules\balena-cli\node_modules\bluebird\js\release\async.js:17:14)
    at processImmediate (internal/timers.js:439:21)
    at process.topLevelDomainCallback (domain.js:126:23)
https://forums.balena.io
(node:17136) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated
@dfunckt Any idea what might be causing this? I am still getting this error, even after upgrading balena-cli to 11.7.5:
$ balena env add TEST_ENV 1 --device 59525b1
$ balena envs --device 59525b1
ID NAME     VALUE
6  TEST_ENV 1
$ balena env rm TEST_ENV --device 59525b1
variable: "set DEBUG=1" on a Windows command prompt, or "export DEBUG=1"
on Linux or macOS.
If you need help, dont hesitate in contacting our support forums at
(node:9884) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated
ID NAME     VALUE
6  TEST_ENV 1
Hi, is the device in local mode? Also, could you post the output of DEBUG=1 balena env rm TEST_ENV --device 59525b1 ?
This one is not. Since my original post I have made a new openBalena install and haven’t set any device to local mode.
$ DEBUG=1 balena env rm TEST_ENV --device 59525b1
Debug: original argv0="C:\Program Files\nodejs\node.exe" argv=[C:\Program Files\nodejs\node.exe,C:\Program Files\nodejs\node_modules\balena-cli\bin\balena,env,rm,TEST_ENV,--device,59525b1] length=7
(node:15440) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated
Thanks for the information. What OS version is the device running and what device is it? I will try and replicate the bug on my local machine
I am testing using many Raspberry Pi 3B+.
os_version: balenaOS 2.38.0+rev1
os_variant: dev
I just tried with another device using the prod os_variant, but I get the same error.
Got some more! I managed to go through the large amount of logs openBalena produces and found this happening when running the balena env rm command :
Aug 06 15:31:48 7658c5fe8305 api[1469]: Parsing DELETE /resin/application_environment_variable(%27TEST_ENV%27)
Aug 06 15:31:48 7658c5fe8305 api[1469]: Running DELETE /resin/application_environment_variable(%27TEST_ENV%27)
Aug 06 15:31:48 7658c5fe8305 api[1469]: SELECT "application environment variable"."id"
Aug 06 15:31:48 7658c5fe8305 api[1469]: FROM "application environment variable"
Aug 06 15:31:48 7658c5fe8305 api[1469]: WHERE "application environment variable"."id" = $1 [ 'TEST_ENV' ]
Aug 06 15:31:48 7658c5fe8305 api[1469]: Error building the application_environment_variable filter invalid input syntax for integer: "TEST_ENV" DatabaseError: invalid input syntax for integer: "TEST_ENV"
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at wrapDatabaseError (/usr/src/app/node_modules/@resin/pinejs/out/database-layer/db.js:41:15)
Aug 06 15:31:48 7658c5fe8305 api[1469]: From previous event:
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at PostgresTx.executeSql (/usr/src/app/node_modules/@resin/pinejs/out/database-layer/db.js:143:19)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at abstract_sql_1.getAndCheckBindValues.then.values (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:926:19)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at runQuery (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:922:68)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at doRunQuery (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:647:40)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at permissions.addPermissions.then (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:649:24)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Holder$2._callFunction (<anonymous>:19:29)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at uriParser.parseOData.then.request (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:643:57)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Object.exports.getAffectedIds.Promise.method (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:630:10)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Object.exports.getCurrentRequestAffectedIds.args [as getCurrentRequestAffectedIds] (/usr/src/app/src/platform/index.ts:90:62)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at addEnvHooks (/usr/src/app/src/hooks/resources/envvars.ts:118:23)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Hook.preRunHook [as hookFn] (/usr/src/app/src/hooks/resources/envvars.ts:24:32)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Promise.try (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/hooks.js:12:25)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Hook.run (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/hooks.js:11:27)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Promise.map.hook (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:344:44)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Promise.method (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:344:20)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at runRequest (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:807:12)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at tx (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:728:24)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Promise.try (/usr/src/app/node_modules/@resin/pinejs/out/database-layer/db.js:191:50)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at promise.tap.tx (/usr/src/app/node_modules/@resin/pinejs/out/database-layer/db.js:191:43)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Promise (/usr/src/app/node_modules/@resin/pinejs/out/database-layer/db.js:191:22)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Object.transaction (/usr/src/app/node_modules/@resin/pinejs/out/database-layer/db.js:182:16)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at runTransaction (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:903:27)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at uriParser.parseOData.then.then.request (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:711:30)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at requestPart (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:711:14)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Promise.each.p (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/control-flow.js:32:16)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at mapTill (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/control-flow.js:31:20)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at runHooks.then (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:693:16)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at exports.handleODataRequest (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/sbvr-utils.js:684:10)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Layer.handle [as handle_request] (/usr/src/app/node_modules/express/lib/router/layer.js:95:5)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at next (/usr/src/app/node_modules/express/lib/router/route.js:137:13)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at next (/usr/src/app/node_modules/express/lib/router/route.js:131:14)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Route.dispatch (/usr/src/app/node_modules/express/lib/router/route.js:112:3)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at /usr/src/app/node_modules/express/lib/router/index.js:281:22
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at param (/usr/src/app/node_modules/express/lib/router/index.js:354:14)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at param (/usr/src/app/node_modules/express/lib/router/index.js:365:14)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at Function.process_params (/usr/src/app/node_modules/express/lib/router/index.js:410:3)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at next (/usr/src/app/node_modules/express/lib/router/index.js:275:10)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at next (/usr/src/app/node_modules/express/lib/router/route.js:117:14)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at app.all (/usr/src/app/src/platform/versions.ts:11:9)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at passport.authenticate (/usr/src/app/src/platform/jwt.ts:104:9)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at JwtStrategy.strategy.success (/usr/src/app/node_modules/passport/lib/middleware/authenticate.js:214:18)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at verified (/usr/src/app/node_modules/passport-jwt/lib/strategy.js:115:41)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at runCallback (timers.js:705:18)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at tryOnImmediate (timers.js:676:5)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at processImmediate (timers.js:658:5)
Aug 06 15:31:48 7658c5fe8305 api[1469]:     at process.topLevelDomainCallback (domain.js:120:23)
Aug 06 15:31:48 7658c5fe8305 api[1469]: { DatabaseError: invalid input syntax for integer: "TEST_ENV"
Aug 06 15:31:48 7658c5fe8305 api[1469]:   message: 'invalid input syntax for integer: "TEST_ENV"',
Aug 06 15:31:48 7658c5fe8305 api[1469]:   name: 'DatabaseError',
Aug 06 15:31:48 7658c5fe8305 api[1469]:   code: '22P02' }
Aug 06 15:31:48 7658c5fe8305 api[1469]:   message: 'Database error',
Oh my, I figured it out:
I should be using the variable id instead of its name, AS STATED IN THE DOCS :man_facepalming:
https://www.balena.io/docs/reference/cli/#env-rm-id
Still, now I don’t get an error but the variable doesn’t seem to go away :thinking:
ID NAME     VALUE
6  TEST_ENV 1
$ DEBUG=1 balena env rm 6 --device c250187 -y
Debug: original argv0="C:\Program Files\nodejs\node.exe" argv=[C:\Program Files\nodejs\node.exe,C:\Program Files\nodejs\node_modules\balena-cli\bin\balena,env,rm,6,--device,c250187,-y] length=8
ID NAME     VALUE
6  TEST_ENV 1
I think the issue here is that you’re passing along the device id after the --device command. If you remove the device id it works fine:
$(04:57 pm) ~/ balena envs --device f37237e1a23d63ee2f8dda427d8736be
ID     NAME VALUE
137963 TEST 1
$(04:57 pm) ~/ balena env rm 137963 --device f37237e1a23d63ee2f8dda427d8736be -y
$(04:58 pm) ~/ balena envs --device f37237e1a23d63ee2f8dda427d8736be
ID     NAME VALUE
137963 TEST 1
$(04:58 pm) ~/ balena env rm 137963 --device
No environment variables found
If you need help, don't hesitate in contacting us at:
  GitHub: https://github.com/balena-io/balena-cli/issues/new
  Forums: https://forums.balena.io
$(04:58 pm) ~/
Its unexpected that the command would fail silently, whilst providing a false positive response, when providing the additional argument. I’ve opened a GitHub issue to track this that you can see here https://github.com/balena-io/balena-cli/issues/1380
Oh my god that’s it!
The naming is super confusing. --device everywhere across the cli is used to pass a device ID.
I definitely get why this works this way, but maybe it should be changed a bit or better explained for clarity.
Thanks a lot for your time!
I agree with you that this is confusing behaviour - It seems that you’ve experienced several usability issues one after the other! I’ll try and take some time to look into this tomorrow and see if I can improve the situation.
As of v11.8.1 balena CLI contains a few improvements to the balena env rm command. If a string is passed instead of an integer ID then a warning message will be printed and similarly, if an extra argument is present (i.e. a device ID after the -d flag) a warning message will also be printed.
Thanks for reporting this issue!
Hey there! I’m having some trouble deleting environment variables again.
$ balena envs -a myApp --config
ID NAME                        VALUE
15 RESIN_HOST_CONFIG_dtoverlay vc4-fkms-v3d
14 RESIN_HOST_CONFIG_gpu_mem   396
$ balena env rm -y 15
ID NAME                        VALUE
Checking the db logs, I see something going on if I try to run balena env add RESIN_HOST_CONFIG_dtoverlay vc4-fkms-v3d -a myApp multiple times:
db_1             | 2019-10-02 17:25:21.881 UTC [62263] ERROR:  duplicate key value violates unique constraint "application config variable_application_name_key"
db_1             | 2019-10-02 17:25:21.881 UTC [62263] DETAIL:  Key (application, name)=(7, RESIN_HOST_CONFIG_dtoverlay) already exists.
db_1             | 2019-10-02 17:25:21.881 UTC [62263] STATEMENT:  INSERT INTO "application config variable" ("application", "name", "value")db_1
db_1             |      VALUES ($1, $2, $3) RETURNING "id";
Can adding the same variable multiple time break something?
Hi @edorgeville ,
Can you clarify the open-balena-api & the balena-cli version that you are using?
Hey @thgreasi!
  • openBalena v1.3.0
  • balena-cli 11.13.1
It seems that the CLI is lacking a way to specify that the variable that you want to delete is a configuration one,
Thanks for bringing this up. I’ve opened an issue for this on the balena-cli repository where you can track progress.
In the mean time the best that you can achieve with the current CLI is to clear the value of that config variable with
balena env add RESIN_HOST_CONFIG_dtoverlay "" --application myApp
If you are using the balena-sdk you could achieve this with the following method:
About the duplicate key value violates unique constraint "application config variable_application_name_key" error that you are seeing when trying to set the value of a pre-existing envvar, that’s expected since the CLI’s balena env add command tries to create a new env var or updates it if it gets a conflict error. Are you facing an issue with this, or is it just a concern about the extra error log?
Cool. The device supervisor logs shows:
Applied boot config: {"dtoverlay":[""],"gpu_mem":"396","dtparam":["i2c_arm=on","spi=on","audio=on"],"disable_splash":"1","avoid_warnings":"1"}
Does it mean that dtoverlay won’t be added to config.txt or will it be equivalent to adding dtoverlay= (with no options) to config.txt?
Nope! Just wanted to give more intel in order to find what was causing the bug, turns out it’s unrelated :^)
I’ll follow the Github issue, thanks.
Hi.
I would think this option but I haven’t tested it. You could verify by SSHing in the the device and looking at /mnt/boot/config.txt to see what state it is in :+1:
$ balena ssh 88f5854.local
root@88f5854:~# cat /mnt/boot/config.txt
dtoverlay=
gpu_mem=396
dtparam=i2c_arm=on
dtparam=spi=on
dtparam=audio=on
disable_splash=1
avoid_warnings=1
:scream:!!!
Eh, I don’t know if it’s really an issue. Not sure if this changes the defaults or not.
