Thanks for creating this tool! It would be nice if Etcher would support discarding empty blocks if flashing from .bz2 files. When I flash the .bz2 file it takes about 30 minutes to flash the image. If I extract the archive which contains a .sdimg file flashing only takes 5 minutes because Etcher is able to discard empty blocks in this case.
Best regards
Martin
