I am trying to configure a device with a static IP address like I have many times before and it is not working. My device is connected to the internet via WiFI (working fine). The ethernet port is to be connected to a router-less network which is managed by IT individuals manually. We are currently trying to setup the connection via the Network Manager config files in the system-configuration directory.
The thing is that it appears that this solution has stopped working. I have tried using the exact same file from previous successful installs, but they fail to setup eth0 with a static IP address. Has something changed in recent versions of Resin OS that would cause this? Is there any way for you to help with the debugging process? I have attached the old file that we had been using for Static IP configuraiton as well as a few other stabs at the config file.
resin-eth1.log (168 Bytes)
resin-eth2.log (166 Bytes)
resin-eth3.log (166 Bytes)
resin-eth4.log (168 Bytes)
