Here is the journalctl -a -u NetworkManager
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9232] NetworkManager (version 1.20.2) is starting... (for the first time)
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9232] Read config: /etc/NetworkManager/NetworkManager.conf (etc: os-networkmanager.conf)
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9426] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9503] manager[0x55f8f767a0f0]: monitoring kernel firmware directory '/lib/firmware'.
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9541] hostname: hostname: using hostnamed
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9546] dns-mgr[0x55f8f765c240]: init: dns=default,systemd-resolved rc-manager=resolvconf
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9553] manager[0x55f8f767a0f0]: rfkill: Wi-Fi hardware radio set enabled
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9553] manager[0x55f8f767a0f0]: rfkill: WWAN hardware radio set enabled
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9667] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.20.2/libnm-device-plugin-wwan.so)
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9735] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.20.2/libnm-device-plugin-wifi.so)
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9774] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.20.2/libnm-device-plugin-bluetooth.so)
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9789] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.20.2/libnm-device-plugin-adsl.so)
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9792] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9803] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9809] manager: Networking is enabled by state file
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9816] dhcp-init: Using DHCP client 'internal'
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9818] settings: Loaded settings plugin: keyfile (internal)
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9906] device (lo): carrier: link connected
Nov 15 13:19:15 7714f7e NetworkManager[871]: <info> [1573823955.9918] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.0007] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.0128] settings: (enp2s0): created default wired connection 'Wired connection 1'
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.0219] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.1375] manager: (resin-dns): new Bridge device (/org/freedesktop/NetworkManager/Devices/3)
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.1437] manager: (sit0): new IPTunnel device (/org/freedesktop/NetworkManager/Devices/4)
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.1756] modem-manager: ModemManager available
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.1757] bluez: use BlueZ version 5
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.1837] bluez5: NAP: added interface F4:06:69:31:91:F0
Nov 15 13:19:16 7714f7e NetworkManager[871]: <info> [1573823956.6598] manager: (balena0): new Bridge device (/org/freedesktop/NetworkManager/Devices/5)
Nov 15 13:19:19 7714f7e NetworkManager[871]: <info> [1573823959.9976] device (enp2s0): carrier: link connected
Nov 15 13:19:19 7714f7e NetworkManager[871]: <info> [1573823959.9982] device (enp2s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Nov 15 13:19:20 7714f7e NetworkManager[871]: <info> [1573823960.0002] policy: auto-activating connection 'Wired connection 1' (1413dc76-be2c-382c-aa2e-afb5fa0a9bb8)
Nov 15 13:19:20 7714f7e NetworkManager[871]: <info> [1573823960.0020] device (enp2s0): Activation: starting connection 'Wired connection 1' (1413dc76-be2c-382c-aa2e-afb5fa0a9bb8)
Nov 15 13:19:20 7714f7e NetworkManager[871]: <info> [1573823960.0023] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 15 13:19:20 7714f7e NetworkManager[871]: <info> [1573823960.0032] manager: NetworkManager state is now CONNECTING
Nov 15 13:19:20 7714f7e NetworkManager[871]: <info> [1573823960.0038] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 15 13:19:20 7714f7e NetworkManager[871]: <info> [1573823960.0050] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 15 13:19:20 7714f7e NetworkManager[871]: <info> [1573823960.0058] dhcp4 (enp2s0): activation: beginning transaction (no timeout)
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.3724] manager: (supervisor0): new Bridge device (/org/freedesktop/NetworkManager/Devices/6)
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4183] device (supervisor0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4237] device (supervisor0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4252] device (supervisor0): Activation: starting connection 'supervisor0' (455f5d6b-59bf-4c3b-83c8-a475ce2b683b)
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4258] device (supervisor0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4271] device (supervisor0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4279] device (supervisor0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4284] device (supervisor0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4527] device (supervisor0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4533] device (supervisor0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Nov 15 13:19:37 7714f7e NetworkManager[871]: <info> [1573823977.4559] policy: set-hostname: set hostname to 'localhost.localdomain' (no default device)
Nov 15 13:19:37 localhost.localdomain NetworkManager[871]: <info> [1573823977.4560] device (supervisor0): Activation: successful, device activated.
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6049] dhcp4 (enp2s0): state changed unknown -> bound
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6080] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6289] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6296] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6306] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6327] manager: NetworkManager state is now CONNECTED_SITE
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6328] policy: set 'Wired connection 1' (enp2s0) as default for IPv4 routing and DNS
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6341] dns-mgr: Writing DNS information to /sbin/resolvconf
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6499] device (enp2s0): Activation: successful, device activated.
Nov 15 13:19:51 localhost.localdomain NetworkManager[871]: <info> [1573823991.6516] manager: startup complete
Nov 15 13:25:14 localhost.localdomain NetworkManager[871]: <info> [1573824314.1092] manager: (br-9a6abe6ec772): new Bridge device (/org/freedesktop/NetworkManager/Devices/7)
Nov 15 13:25:21 localhost.localdomain NetworkManager[871]: <info> [1573824321.0369] manager: (resin-vpn): new Tun device (/org/freedesktop/NetworkManager/Devices/8)
Nov 15 13:27:18 localhost.localdomain NetworkManager[871]: <info> [1573824438.9375] manager: (dummy0): new Dummy device (/org/freedesktop/NetworkManager/Devices/9)
Nov 15 13:27:20 localhost.localdomain NetworkManager[871]: <info> [1573824440.1793] manager: (dummy0): new Dummy device (/org/freedesktop/NetworkManager/Devices/10)
Nov 15 13:57:34 localhost.localdomain NetworkManager[871]: <info> [1573826254.7722] manager: (dummy0): new Dummy device (/org/freedesktop/NetworkManager/Devices/11)
Nov 15 14:03:22 localhost.localdomain NetworkManager[871]: <info> [1573826602.4135] manager: (dummy0): new Dummy device (/org/freedesktop/NetworkManager/Devices/12)
Nov 15 14:08:33 localhost.localdomain NetworkManager[871]: <info> [1573826913.6772] manager: (dummy0): new Dummy device (/org/freedesktop/NetworkManager/Devices/13)
Nov 15 15:21:53 localhost.localdomain NetworkManager[871]: <info> [1573831313.7117] manager: (resin-vpn): new Tun device (/org/freedesktop/NetworkManager/Devices/14)
And here is the ip a s
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: sit0@NONE: <NOARP> mtu 1480 qdisc noop qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
3: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel qlen 1000
link/ether 44:8a:5b:fd:6e:ef brd ff:ff:ff:ff:ff:ff
inet 172.17.254.51/24 brd 172.17.254.255 scope global dynamic enp2s0
valid_lft 35663sec preferred_lft 35663sec
inet6 fe80::5abe:13eb:8be4:111d/64 scope link
4: resin-dns: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue qlen 1000
link/ether 6e:f8:f0:1d:2d:f6 brd ff:ff:ff:ff:ff:ff
inet 10.114.102.1/24 scope global resin-dns
inet6 fe80::6cf8:f0ff:fe1d:2df6/64 scope link
5: balena0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue
link/ether 02:42:18:7c:94:32 brd ff:ff:ff:ff:ff:ff
inet 10.114.101.1/24 brd 10.114.101.255 scope global balena0
6: supervisor0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue
link/ether 02:42:e1:5d:6b:5d brd ff:ff:ff:ff:ff:ff
inet 10.114.104.1/25 brd 10.114.104.127 scope global supervisor0
7: br-9a6abe6ec772: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue
link/ether 02:42:ad:48:84:19 brd ff:ff:ff:ff:ff:ff
inet 172.18.0.1/16 brd 172.18.255.255 scope global br-9a6abe6ec772
14: resin-vpn: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc fq_codel qlen 100
link/[65534]
inet 10.240.0.3 peer 10.240.0.1/32 scope global resin-vpn
inet6 fe80::1c7c:39a9:5ccb:bef2/64 scope link
