RepDK
March 4, 2022, 7:17am
1
A couple of days ago, Spotify started constantly skippings songs whenever i connected to my raspberrypi via spotify connect.
I have tried the following:
Logging out of all devices on spotify
Reinstall balenaOS
Tried the following variables, SOUND_SPOTIFY_ENABLE_CACHE and SOUND_SPOTIFY_DISABLE_NORMALISATION
Rename the SOUND_DEVICE_NAME variable
Updated the Supervisor and OS version
Anyone experiencing the same problem?
Have same issue. Did you get it fixed?
RepDK
May 21, 2022, 1:18pm
3
Unfortunately not, I’m still experiencing the problem. Right now I’m using Bluetooth as a workaround.
But please let me know if you manage to find something.
Added
104.199.65.124 ap-gew4.spotify.com
To etc/hosts
See
opened 04:00PM - 02 Mar 22 UTC
SpotifyAPI
I am using LibreSpot with the JACK Audio backend, and it worked perfectly, but s… ince a few days I can't play any tracks. I didn't change any configurations on my side, so I assume there is a problem with spotify like it already occured here: #510
## Setup
Custom compiled with `--no-default-features` and `--features jackaudio-backend` running as a user service on a Raspberry Pi.
## Used Arguments:
- backend: jackaudio
- bitrate: 320
- no-audio-cache & no-credential-cache
LibreSpot allows connections from any device just fine, but can't play any song, no matter of its length. Mots of the time it just skips every song after a few seconds without any audio played, but sometimes it also crashes completely.
## Logs:
Mar 02 10:48:40 raspberrypi librespot[714]: [2022-03-02T15:48:40Z ERROR librespot_core::channel] channel error: 2 1
Mar 02 10:48:40 raspberrypi librespot[714]: [2022-03-02T15:48:40Z ERROR librespot_playback::player] Unable to load encrypted file: ChannelError
Mar 02 10:48:40 raspberrypi librespot[714]: [2022-03-02T15:48:40Z INFO librespot_playback::player] Loading <Lightning Over Heaven> with Spotify URI <spotify:track:0S0zgiheqNBkRjEMo7pnig>
Mar 02 10:48:40 raspberrypi librespot[714]: [2022-03-02T15:48:40Z WARN librespot_playback::player] Skipping to next track, unable to load track <SpotifyId { id: 38045326986839703698416089418933192304, audio_type: Track }>: ()
Mar 02 10:48:40 raspberrypi librespot[714]: thread '<unnamed>' panicked at 'Map must not be polled after it returned `Poll::Ready`', /home/pi/.cargo/registry/src/github.com-1285ae84e5963aae/futures-util-0.3.17/src/future/future/map.rs:62:17
Mar 02 10:48:40 raspberrypi librespot[714]: stack backtrace:
Mar 02 10:48:41 raspberrypi librespot[714]: 0: 0x8febfc - std::backtrace_rs::backtrace::libunwind::trace::h532c701585cd392d
Mar 02 10:48:41 raspberrypi librespot[714]: at /rustc/db9d1b20bba1968c1ec1fc49616d4742c1725b4b/library/std/src/../../backtrace/src/backtrace/libunwind.rs:93:5
Mar 02 10:48:41 raspberrypi librespot[714]: 1: 0x8febfc - std::backtrace_rs::backtrace::trace_unsynchronized::h15e96deae50ea7f1
Mar 02 10:48:41 raspberrypi librespot[714]: at /rustc/db9d1b20bba1968c1ec1fc49616d4742c1725b4b/library/std/src/../../backtrace/src/backtrace/mod.rs:66:5
Mar 02 10:48:41 raspberrypi librespot[714]: 2: 0x8febfc - std::sys_common::backtrace::_print_fmt::h2de65accbd58b3e4
Mar 02 10:48:41 raspberrypi librespot[714]: at /rustc/db9d1b20bba1968c1ec1fc49616d4742c1725b4b/library/std/src/sys_common/backtrace.rs:67:5
Mar 02 10:48:41 raspberrypi librespot[714]: 3: 0x8febfc - <std::sys_common::backtrace::_print::DisplayBacktrace as core::fmt::Display>::fmt::h85671ae76efc2464
Mar 02 10:48:41 raspberrypi librespot[714]: at /rustc/db9d1b20bba1968c1ec1fc49616d4742c1725b4b/library/std/src/sys_common/backtrace.rs:46:22
Mar 02 10:48:41 raspberrypi librespot[714]: 5: 0x8f709c - std::io::Write::write_fmt::hcccb69ae7e0e5712
Mar 02 10:48:41 raspberrypi librespot[714]: at /rustc/db9d1b20bba1968c1ec1fc49616d4742c1725b4b/library/std/src/io/mod.rs:1697:15
Mar 02 10:48:41 raspberrypi librespot[714]: 6: 0x900c68 - std::sys_common::backtrace::_print::hedd1975fac8ef971
panicking.rs:211:50pberrypi librespot[714]: at /rustc/db9d1b20bba1968c1ec1fc49616d4742c1725b4b/library/std/src/sys_common/backtrace.rs:49:5
Mar 02 10:48:41 raspberrypi librespot[714]: 9: 0x900710 - std::panicking::default_hook::h76fa136e1f70a214
Mar 02 10:48:41 raspberrypi librespot[714]: at /rustc/db9d1b20bba1968c1ec1fc49616d4742c1725b4b/library/std/src/panicking.rs:228:9
Mar 02 10:48:41 raspberrypi librespot[714]: 14: 0x61fd54 - <futures_util::future::future::map::Map<Fut,F> as core::future::future::Future>::poll::h6cdb6d970c4ac361
Mar 02 10:48:41 raspberrypi librespot[714]: 15: 0x60d7d8 - <futures_util::future::try_future::MapErr<Fut,F> as core::future::future::Future>::poll::hfe2e84411f277e84
Mar 02 10:48:41 raspberrypi librespot[714]: 16: 0x5fbd10 - <librespot_playback::player::PlayerInternal as core::future::future::Future>::poll::h28a4cde177e46443
Mar 02 10:48:41 raspberrypi librespot[714]: 17: 0x4c7774 - std::thread::local::LocalKey<T>::with::h85f1e7d59454df33
Mar 02 10:48:41 raspberrypi librespot[714]: 18: 0x4bbad4 - futures_executor::local_pool::block_on::hefeadbfdb9a235f9
Mar 02 10:48:41 raspberrypi librespot[714]: 19: 0x567ff4 - std::sys_common::backtrace::__rust_begin_short_backtrace::ha9233c878f46eaea
Mar 02 10:48:41 raspberrypi librespot[714]: 20: 0x5287ac - core::ops::function::FnOnce::call_once{{vtable.shim}}::he863134c8af815b9
Mar 02 10:48:41 raspberrypi librespot[714]: at /rustc/db9d1b20bba1968c1ec1fc49616d4742c1725b4b/library/alloc/src/boxed.rs:1694:9
Mar 02 10:48:41 raspberrypi librespot[714]: 22: 0x9061e4 - <alloc::boxed::Box<F,A> as core::ops::function::FnOnce<Args>>::call_once::h3a9e9491476f36e5
Mar 02 10:48:41 raspberrypi librespot[714]: [2022-03-02T15:48:41Z ERROR librespot_playback::player] Player Commands Error: channel closed
Mar 02 10:48:42 raspberrypi librespot[714]: [2022-03-02T15:48:42Z ERROR librespot_playback::player] Player Commands Error: channel closed
Not a fix but a Work arround.
Hello, noob here – I added following line to /etc/hosts of Spotify service (via Balena dashboard → Terminal → Spotify target → then editedd with vi, saved with :x), but the changes are not kept after rebooting.
Could you please explain step by step how to make this fix?
Seems to be a problem with librespot.
As a temporary fix you can try to block apresolve.spotify.com in your router config. That should help.
