@rojasyal did you try with different address than 127.0.0.1? Did you try the name of the container?
yes, I tried with different IP and it doesnât work.
Any other options I should try?
container_name: node-red
@rojasyal whatâs the current situation here? Could you please share the step by step you took and the problem you have?
I already solved the problem, the problem was that I did not have modbus communication with node red and I added in the docker-compose network_mode: host and port 18502:18502 and I had communication. thank you
Thanks for confirming that this was the thing!
Looking forward to learn more about your industrial project!
