Thank you very much, your career is a great inspiration to me, thank you for giving so much to the community
Is this working now @rojasyal ? Could you please share what you did?
Hi @mpous, yes it is working,
I did the other deployment using Balena CLI.
- Clone the repository to my workplace.
- Cd the-things-stack-docker
- balena push [Fleet]
Hi @mpous I am going to use node red with an ethernet port, how do I enable the native ethernet port of the raspberry pi and assign it a static IP.
I am using this image on the raspberry pi
Hello @rojasyal iâm not sure what do you need exactly. Do you need to assign to the Node-RED service to a static IP address? or whatâs the reason?
On the raspberry I have TTN running, that TTN data is consumed by MQTT to node red, but I must deliver it by MODBUS TCP/IP. The raspberry only has one Ethernet port and I have connected a USB to Ethernet converter. How could you see the IP that it has? I assign to that port.
Hi @mpous I am trying to configure a static IP using the documentation but when making the change in the file it continues with the same IP in balena cloud.
@rojasyal could you please share how are you defining the container?
Hi @mpous, i fixed IP static⌠i have problem when i want yo use modbus tcp IP It gives me an error with port 502 It tell me thats Is clósed. Enable It in docker compose, unsuccesfully
What error do you get @rojasyal ? Did you change the docker-compose of the project?
Could you please confirm how do you open port 502 on the node-RED container on the docker-compose or the Dockerfile @rojasyal ?
Yes, I added it in the docker-compose in the node-red port part without success. Itâs something I donât understand that blocks that port in Balena.
Could you please share the docker-compose @rojasyal ?
@rojasyal could you please build from the Node-RED project?
