So I was using RPi 4 when nothing worked surprisingly, everyone else on the forums is also complaining about how the images aren’t working, I feel like they rushed to make this and didn’t spend any time for the images, the issues are:
It goes offline after 5 mins randomly
It downloads the image but doesn’t do anything with it
I haven’t seen a single working RPi 4 folding
Even the official FAH/F@H dev team hasn’t made anything that works on RPi4(I tried and it didn’t work)
I reimaged 5 times so it isn’t an issue with the card
I also swapped the card once and still doesn’t work
The URLs are completely useless, doesn’t work 100% of the time
You need a fan or it will get too hot and short your RPi, I learned this the hard way
9 and so on. I also feel like this is useless, I use the official FAH/F@H software on my windows and it calls 2.3GHz “Light Mode” Whereas the “Medium Mode” is around 6.9GHz and full depends on your setup, and the ram usage is 4.5 GB on average on “Light Mode”, Which means out RPi’s are barely doing anything helpful, there are also people saying that this is all a big scam and this is “Helping People Grow Rich”
I highly suggest using the official FAH/F@H software on your Main Computer because you can set it so it runs when you’re idle or even when your working, it can also be used on a lot of platforms, they also say that it works on RPi but it hasn’t for me, I suggest if you’re having trouble with the image or anything really that isn’t working it probably won’t help if you reimage 99 times over.
I really do hope that the Dev team at Balena can fix this issue because if this is also giving false results then it is a bigger issue, I would also like to see if the dev team even tested this, it seems unlikely that they have all those different single board comps and comps, I really want to see them even just release a video on if this even works, the official FAH/F@H team actually even have tutorials whereas Balena doesn’t. In fact, they don’t even have a support system and just direct us back to other people with the same issue which I think is hilarious. They also say that the “idea” is to make it a simple “insert sd and forget” though it would be nice if they realized that it wasn’t doing anything.
I also think that I never agreed to anything of being on the “map” that they have so I think that the map is fake if it is hidden in the tos or pn then nobody really reads that and that can lead to some issues legally.
Is it me or did I see the number go from 3k(yesterday) to 2k? And it stayed around the same number since?
Overall, just don’t try this, if you want to help with folding, just go to the offical https://foldingathome.org/ website and help there, they support many more platforms and is better since you can actually control what you help with, and see what your helping with.
