I have recently created an account at Resin.io to evaluate it for a production environment OTA updates. I am having issues with the initial bring up of my device on the dashboard. Below are the details of my test system and some screenshots to explain my situation. I am using default recommended OS in development mode.
Hardware: RPi 3
OS: resinOS 2.7.8+rev1-dev-v6.4.2
connectivity is via 2.4Ghz wifi
I have waited for more than 20 minutes for the device to show up before raising this issue.
Hi. Can you connect a keyboard and login to the host OS? The username for the .dev image should be “root” with no password. Alternatively, you could use a serial console to your pi3 to diagnose it. This post Using a Console Cable should have the details on how to do that.
Once you are connected, by either of the above methods, can you paste the output of the “ifconfig” command please?
Also as a side note, I was able to download index.html from Google.com using wget into the /var/tmp folder. so I am connected to the internet. But it still does not show up on my dashboard.
