I had an application for Screenly-OSE (called “Screenly”) which had a device (RPi-3) attached. I deleted the application, and then recreated with the same name. My problem is that the same device, with the new Pi3 image burned to the SD card, no longer attaches to Resin. It sits at the resin logo but I don’t see it in the Resin console. The device is connected by ethernet, so it’s not an issue with the wifi setup. Any ideas?
JP
