I Have a Raspberry Pi 3 that is failing to upgrade. Log file below.
Also, the device is not responding to reboot requests nor is updating the terminal at the resin.io website (it’s like the supervisor is not running).
The application container is working just fine.
root@xxxxxxx:/mnt/data/resinhup# cat upgrade-2.x.sh.20180404_021658.log
[000000001][LOG]Loading info from config.json
[000000001][LOG]Loading info from device-type.json
[000000001][LOG]Device type check: OK
[000000002][LOG]Target OS version “2.12.5+rev1” OK.
[000000002][LOG]VARIANT_ID: prod
[000000002][LOG]Host OS version “2.12.3+rev1” OK.
[000000002][LOG]Checking for manifest of registry.hub.docker.com/resin/resinos:2.12.5_rev1-raspberrypi3
[000000006][LOG]Manifest found, good to go…
[000000006][LOG]No resin-device-progress fix is required…
[000000006][LOG]No supervisor updater fix is required…
[000000007][LOG]hostapp-update command exists, use that for update
[000000008][LOG]Running pre-update fixes for raspberrypi3
Removing start_db.elf from boot partition
Removing fixup_db.dat from boot partition
[000000008][LOG]Starting hostapp-update
9e935237520f
Untagged: registry.hub.docker.com/resin/resinos:2.10.1_rev1-raspberrypi3
Untagged: registry.hub.docker.com/resin/resinos@sha256:bc905d1a9d299364bc816faedcf4677bc761a2fed3c50b996f0a387a52a0b5be
Deleted: sha256:75d9f51636d509033f08bfaf572c073d50f433646a30e061dfb05257467ad290
Deleted: sha256:5942324dd17837c0552a6f439ef3c601c3b1f781c127278d162a61f1689e0c9d
2.12.5_rev1-raspberrypi3: Pulling from resin/resinos
0e4760eb8ffa: Pulling fs layer
0e4760eb8ffa: Ready to download
failed to register layer: Error processing tar file(exit status 1): unexpected EOF
[000000367][ERROR]hostapp-update has failed…-
