The terminal would not connect if the application is restarting. The device needs a reboot after the RESIN_HOST_CONFIG_gpu_mem_256 settings are done for the system to boot with the new memory allocation, was the device rebooted after this config was done?
Yes, it automatically reboots when a RESIN env var is set or changed. Although the log says the application was successfully loaded, it is clear that it is not running correctly. I will try removing and redeploying.
this happens already with official base images parsing labels on the images, which is not possible with custom (or community) images like resin-wpe atm
‘Our efforts have made it possible to run WPE on the Raspberry Pi (1, 2 and 3), Jetson TK1, MinnowBoard Max and Intel NUC. WPE could run out of the box in any HW that has a good EGL and OpenGL ES 2 support and basic GStreamer integration.’
‘…This project provides an easy way of running WPE Webkit for the RaspberryPi. https://www.igalia.com/wpe/ WPEWebkit is a full featured browser that takes advantage of the GPU to provide hardware accelerated CSS, WebGL, and HTML5 video…’
@PI_CABLES it is indeed from Igalia. @petrosagg made it a Docker container with his magic and I guess this involves a lot of effort and as for now that effort has been put on armv7 only
