I’m having some problems getting resin-wpe working in a multi-container deployment. If I take the https://github.com/resin-io-projects/resin-wpe project as-is and push it to my devices, then everything works as expected. I can see the WPE_URL that I’ve configured and everything seems fine. However, if I take that same project and add this very simple docker-compose.yml file:
version: '2.1'
services:
display:
build: .
privileged: true
Then all I get is a blank screen. The logs don’t show the usual Hello InjectedBundle messages that the single-container deployment shows.
I’ve also tried other options of adding capabilities and mapping devices with the same results. Does anyone have a working configuration of WPE with multi-containers?
Alright, so I took your project as-is and pushed it to my devices. It failed initially because /dev/fb1 didn’t exist (is this my problem, or is it just because I’m only using HDMI?)
I removed /dev/fb1 from the devices and pushed again, and I’m seeing the same blank white screen as before.
@Cryowatt I think you just need to switch it to /dev/fb0 if you are using hdmi, also don’t forget to increase the amount of gpu memory available to the device.
So I’ve tried
devices:
- "/dev/fb0:/dev/fb0"
- "/dev/fb1:/dev/fb1"
- "/dev/vchiq:/dev/vchiq"
and
devices:
and
devices:
- "/dev/fb0:/dev/fb1"
No luck with any.
I currently have gpu_mem set to 396 (which seemed to work in the single-container deployment).
