- resin-cli version: 7.6.2
- Operating system and architecture: MacOS Hish Sierra 10.13.6 MacBook Pro (13-inch, 2017, Four Thunderbolt 3 Ports) 3.5 GHz Intel Core i7
- Node v10.0.0
- NPM 6.2.0
.resin-sync.yml:
app-name: vaporware
build-triggers:
- Dockerfile: 4e79c33215723b0cb5e641f00cedfcaf620073d5048f25d8fc1cc9c617c7637d
environment:
- 'DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket'
- BRACTLET_BAS_TRENDING_ENABLE=0
- BRACTLET_DHCP_ENABLE=1
- BRACTLET_POWER_METER_TRENDING_ENABLE=1
- BRACTLET_STATIC_IP_ADDRESS=192.168.1.235
- BRACTLET_STATIC_NETMASK=255.255.255.0
- BRACTLET_STATIC_GATEWAY=192.168.1.1
- BRACTLET_WIRED_INTERNET_ENABLE=1
- BRACTLET_WIRED_INTERFACE_ENABLE=1
destination: /usr/src/app
ignore:
- .git
- node_modules/
uuid: 6876cb1
Full error message after running resin sync:
Got application container info.
resin sync failed. ResinRequestError: Request error: App not found
If you need help, don't hesitate in contacting us at:
GitHub: https://github.com/resin-io/resin-cli/issues/new
Forums: https://forums.balena.io
