Reset config variable - Fleet Configuration - Bug?
When removing a config variable the value still remains in “config.txt”, noticed on Raspberry Pi 2.
Example :
  • setting RESIN_HOST_CONFIG_display_rotate = 1
  • device reboot with screen rotated
  • removing RESIN_HOST_CONFIG_display_rotate
  • device still with screen rotated
  • config variable remains in “config.txt”
Additionally, devices doesn’t always restart after variables been added or removed. Sometime I need to restart via device list.
Regards,
Thibaut
I think this should work, so I’ve raised the issue with our development team. I’ll let you know when I hear back. Thanks!
There is an open issue here: https://github.com/resin-io/resin-supervisor/issues/450
The fix is currently being worked on and should be available in the near future.
Thank you for your responsiveness.
I will follow the issue and confirm resolution when available.
Bien à vous,
Thibaut
