Hey @maggie0002, I’ll try to add some thoughts here as I think it depends on the type of change. Although you’ve stated that it would be content in volumes, I’ll try to cover multiple eventualities.
One workflow I’ve been thinking about quite a lot is that where you have a fleet, and you flip one of the devices into development mode. You are able to use an IDE running on that device to develop the application and make changes, then when you’re happy with them, you do a balena push to create another release on that fleet which allows you to roll out all of the changes you just made to all of the other devices, and also flip that device back into normal mode and it will receive the update as well. The updated release can of course include files which are then copied into user volumes.
Another workflow is where you could fork a fleet. Working with the example that a device is a member of an open fleet, they could fork that fleet, which essentially comes down to automatically creating a new fleet, pushing a release to that fleet, and then moving the device over. This would then allow any any changes to be made in a similar way as above, but instead creating a new fleet to run these changes instead of applying them to the original. In the same way as above, the release could contain the files which are then copied to the user directory.
A third, more direct approach could be using something like IPFS, or min.io, or some other distributed filesystem to synchronise files between devices in real time. That way you could continue to provision devices with the standard, ‘empty’, image, but as soon as they provision and join the fleet, they would receive the latest copy of the files you’re talking about.
I think in summary the difference is that if you want changes to be replicated across devices within a fleet as part of their day to day running, use some means of file distribution from device to device. If you want the changes to be replicated across the fleet as part of the software that’s deployed to them, and as such receive the benefits such as the ability to deploy new, roll back etc., then it’s better to use releases. It depends if it’s a continuous sync and deploy or an iterative thing, I guess.
Either way, pulling SD cards and cloning them is not something we ever really consider because that requires physical access and is kind of the heart of the device. As you suspected, it would cause issues with UUID clashes, because once that device has been provisioned it is no longer generic and contains the UUID as well as device-specific API key. It holds the identity of that device.
If you can share more information about the use case you have in mind I may be able to be more specific with my suggestions
