I have issues creating releases. The release build process finishes successfully, but the release is marked as “failed” (on the Releases Page).
We deploy multi-container apps and the images are rather huge. All together the release has approx. >50GB.
My question: Is there a release size limit, or is there a timeout for the deployment process?
Hello @haronaut could you please share the resulting logs from your fleet’s releases?
Hi! @mpous You mean the release build logs on the bottom right? There is nothing special listed. We only have prebuilt images, so all services are listed with This service uses the pre-built image <image name>
