I am not sure if this post should be in balenaCloud or in balenaOS, as it has to do with both.
I use a single device (raspberry pi) to test multiple applications before deploying changes to my fleets.
This week, I noticed something peculiar while switching from one image to a different one.
- First I had the device running a development image of application A in local mode (Device A).
I did some testing and everything was fine. - Then I had to test some things for a different application, so I flashed a development image of application B, put it in local mode and everything was fine (Device B).
- After a while, I had to go back to application A, but the original SD had been lost/overwritten, so I grabbed the image of the version it was and configured it to be the same device with
balena os configure <img> --device <uuid>. (Device A again)
When I booted this up, I saw something odd.
In the dashboard, the device showed up as online, running the newer version, in development local mode, but no application container.
I noticed that balena ps -a in the HostOS did not show my application container at all.
Expecting this to be due to the local mode, I tried to local push, but that gave me connection refused errors.
I did a few reboots and everything stayed the same.
Thinking local mode was breaking things, I went to the dashboard to disable it, but the dashboard told me that could only be done in development images (which it was still showing to be the current release).
Thinking somehow something else broke, I tried to update the OS to the latest version, which it did successfully, but still no application container and still no option to disable local mode.
Tracing back my steps, I noticed I had actually flashed a production image, rather than a development image.
After grabbing the latest development image and configuring the uuid my device is now running as expected.
My conclusion is that somehow switching from a development image in local mode to a production image on the device, but not in the dashboard, stopped the application container from being made.
