is there any news on when there will be a new release for the Raspberry pi zero 2 w? The current “Reccomended” version has wifi stability issues and the latest compatible version came out almost 9 months ago and has problems with the network as well.
Hi @carottid , can you share what kind of errors you are getting on your Raspberry Pi Zero 2? Any kind of error logs or screenshots would be helpful. One of our agents might be able to replicate the issues that you are experiencing.
So booting with 2.94.4
Dev image with wifi set I get the following back on the dashboard:
Supervisor starting
Applying configuration change {"SUPERVISOR_POLL_INTERVAL":"900000","SUPERVISOR_DELTA":"1","SUPERVISOR_DELTA_VERSION":"3"}
Applied configuration change {"SUPERVISOR_POLL_INTERVAL":"900000","SUPERVISOR_DELTA":"1","SUPERVISOR_DELTA_VERSION":"3"}
Applying boot config: {"gpu_mem_1024":"448","gpu_mem_256":"192","gpu_mem_512":"256","dtoverlay":[""],"dtparam":["i2c_arm=on","spi=on","audio=on"],"enable_uart":"1","avoid_warnings":"1","disable_overscan":"1","disable_splash":"1","gpu_mem":"16"}
Applied boot config: {"gpu_mem_1024":"448","gpu_mem_256":"192","gpu_mem_512":"256","dtoverlay":[""],"dtparam":["i2c_arm=on","spi=on","audio=on"],"enable_uart":"1","avoid_warnings":"1","disable_overscan":"1","disable_splash":"1","gpu_mem":"16"}
Applying boot config: {}
Applied boot config: {}
Rebooting
And then it never reconnects
I don’t have an ethernet dongle around right now but I’ll try over that in a few days but I’m not super hopeful given the warning tag on that image is:
“Without network connectivity, preloaded applications won’t run on the first boot after programming”
any idea where I can get more details on that?
Power cycling so that it reboots again doesn’t seem to help
On the reccomended theres now also issues with losing the wifi during operation and not being able to recover.
U-Boot 2020.01 (Jan 06 2020 - 20:56:31 +0000)
DRAM: 256 MiB
RPI: Board rev 0x12 outside known range
RPI Unknown model (0x902120)
MMC: mmc@7e202000: 0, mmcnr@7e300000: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial
ut: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is urrent device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
516 bytes read in 1 ms (503.9 KiB/s)
## Executing script at 0400000
Scanning mmc usb devices 0 1 2
24 bytes read in 2 ms (11.7 KiB/s)
Found resin image on mmc 0
Loading resinOS_uEnv.txtfrom mmc device 0 partition 1
Loading extra_uEnv.txt from mmc device 0 partition 1
0 bytes read in 2 ms (0 Bytes/s)
Import extra_uEnv.txt in environment
Loading bootcount.env from mmc device 0 partition 1
No bootcount.env fie. Setting bootcount=0 in environment
** Reading file would overwrite reserved memory **
Error: Bad gzipped ata
Bad Linux ARM64 Image magic!
SCRIPT FAILED: continuing...
Card did not respond to voltage select!
startig USB...
Bus usb@7e980000: scanning bus usb@7e980000 for devices... cannot reset port 1!?
cannot reset port 2!?
4 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
No ethrnet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrievig file: pxelinux.cfg/00000000
No ethernet found.
Retrievin file: pxelinux.cfg/0000000
No ethernet found.
Retrievingfile: pxelinux.cfg/000000
No ethernet found.
Retrieving fie: pxelinux.cfg/00000
No ethernet found.
Retrieving file: xelinux.cfg/0000
No ethernet found.
Retrieving file: pxeliux.cfg/000
No ethernet found.
Retrieving file: pxelinux.cf/00
No ethernet found.
Retrieving file: pxelinux.cfg/0
Noethernet found.
Retrieving file: pxelinux.cfg/default-arm-cm283x-rpi
No ethernet found.
Retrieving file: pxelinux.cf/default-arm-bcm283x
No ethernet found.
Retrieving file: pelinux.cfg/default-arm
No ethernet found.
Retrieving file:pxelinux.cfg/default
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
U-Boot>
