Raspberry Pi 3 B+ Boot & Flash from USB to microSD?
Has anyone figured out how to do this?
I currently have to flash the microSD directly from a laptop, then use it to boot the Pi. That’s far less scalable than having a single USB that I can plug into a new device, flash it, then move on to the next.
The web suggests that B+ enables USB boot by default, but I only get a blank screen if I try to boot with a Resin image burned with Etcher.
-James
Hi, we’re currently looking into this, but it appears that the RPi 3 B+ currently does not enable usbboot with a blank SD-card by default.
What the RPi 3 B+ does enable by default though, is booting from a USB attached mass-storage device instead of from the SD-card – if that’s what you mean?
Regarding the blank screen – what Resin image are you flashing?
@jhermsmeier I just tested again - flashed a USB stick with v2.12.5+rev2 in production mode and tried to boot with a fresh SD-card in the slot but it never initializes the display. The power to the display never comes on. If I flash the SD-card with the image, it powers up fine.
ok I’m having the opiset thang happen to me. etcher will not take the noobs os and put on a flash or a sd. gives me there error say invalid image. I was told this works with zip. files. running v1.4.4 of etcher on a win10 os.
Someone Please Help??
I’ve been trying to simply flash my SD Card and my SSD External Hard Drive and I get nothing. First of all. How do I download ETCHER so I can flash it?? The file I downloaded will not allow me to do anything. Can someone please HELP ME??
@Omega NOOBS is not a disk image, but an archive of files which requires a different installation mechanic (see https://www.raspberrypi.org/learning/software-guide/quickstart/ for details on that) – if you want to flash Raspbian with Etcher, you’ll need to download one of the full disk images available from https://www.raspberrypi.org/downloads/raspbian/
Hey @bob.srw
You can download Etcher from https://etcher.io, selecting the fitting download for your operating system from the dropdown, or the “Downloads” section at the bottom of the page.
Which file did you download and from where?
did someone find a way to flash RPI SD card by plugin an USB stick? like process used to provision up-board devices.
