mpous
May 20, 2021, 11:37am
36
Just created this issue on the repo @johncaipa
Hi @mpous i make the changes suggested by @ronyvargas , but disconnection and reconnection becomes more recurrent, I don’t think that’s the problem, at the moment I don’t have another rpi, sorry.
Hi @johncaipa I have read that power issues could cause failures at the concentrator start, considering the previous variable doesn’t fix, I could suggest remove it, and try another power source to see if that fixes the issue?
Regards
mpous
June 10, 2021, 2:01pm
40
@johncaipa today checking your issue i saw this closed issue which matches with your problem
opened 01:24PM - 26 Apr 21 UTC
closed 10:31PM - 26 Apr 21 UTC
I'm using PiHAT with RAK2247, when I setup TTNv2, everything seems to be … working fine, in console I can see gateway connected.
When I changed to v3 and setup gw in TTS console, it seems to be connecting, but only for short time and then disconnects. Status of gateway is also disconnected. In webconsole (live activity) I can see:
15:17:35
Disconnect gateway
network_check
15:17:35
Forward gateway status
Versions
firmware"1.0.0"package"1.0.0"platform"rpi - Firmware 1.0.0 - Protocol 2"station"2.0.5(rpi/std)"
network_check
15:17:35
Versions
network_check
15:17:35
Receive gateway status
Versions
flash_on
15:17:35
Connect gateway
Is this normal behavior?
When checking logs on balena:
26.04.21 15:18:28 (+0200) <main> 2021-04-26 13:18:28.721 [any:INFO] ./tc.trust:
26.04.21 15:18:28 (+0200) <main> cert. version : 3
26.04.21 15:18:28 (+0200) <main> serial number : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
26.04.21 15:18:28 (+0200) <main> issuer name : O=Digital Signature Trust Co., CN=DST Root CA X3
26.04.21 15:18:28 (+0200) <main> subject name : O=Digital Signature Trust Co., CN=DST Root CA X3
26.04.21 15:18:28 (+0200) <main> issued on : 2000-09-30 21:12:19
26.04.21 15:18:28 (+0200) <main> expires on : 2021-09-30 14:01:15
26.04.21 15:18:28 (+0200) <main> signed using : RSA with SHA1
26.04.21 15:18:28 (+0200) <main> RSA key size : 2048 bits
26.04.21 15:18:28 (+0200) <main> basic constraints : CA=true
26.04.21 15:18:28 (+0200) <main> key usage : Key Cert Sign, CRL Sign
26.04.21 15:18:28 (+0200) <main> 2021-04-26 13:18:28.721 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
26.04.21 15:18:28 (+0200) <main> 2021-04-26 13:18:28.788 [TCE:INFO] Connecting to INFOS: wss://eu1.cloud.thethings.network:8887
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.067 [TCE:INFO] Infos: b827:ebff:fe64:2dfe muxs-::0 wss://eu1.cloud.thethings.network:8887/traffic/eui-B827EBFFFE642DFE
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.067 [AIO:DEBU] [3] ws_close reason=1000
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.067 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.067 [AIO:DEBU] [3] WS connection shutdown...
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.068 [any:INFO] ./tc.trust:
26.04.21 15:18:29 (+0200) <main> cert. version : 3
26.04.21 15:18:29 (+0200) <main> serial number : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
26.04.21 15:18:29 (+0200) <main> issuer name : O=Digital Signature Trust Co., CN=DST Root CA X3
26.04.21 15:18:29 (+0200) <main> subject name : O=Digital Signature Trust Co., CN=DST Root CA X3
26.04.21 15:18:29 (+0200) <main> issued on : 2000-09-30 21:12:19
26.04.21 15:18:29 (+0200) <main> expires on : 2021-09-30 14:01:15
26.04.21 15:18:29 (+0200) <main> signed using : RSA with SHA1
26.04.21 15:18:29 (+0200) <main> RSA key size : 2048 bits
26.04.21 15:18:29 (+0200) <main> basic constraints : CA=true
26.04.21 15:18:29 (+0200) <main> key usage : Key Cert Sign, CRL Sign
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.068 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.117 [TCE:VERB] Connecting to MUXS...
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.369 [TCE:VERB] Connected to MUXS.
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.411 [RAL:WARN] Ignoring unsupported/unknown field: antenna_gain
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.412 [RAL:INFO] Lora gateway library version: Version: 5.0.1;
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] Connecting to device: /dev/spidev0.0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:DEBU] SX130x txlut table (0 entries)
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 rxrfchain 0: enable=1 freq=867.5MHz rssi_offset=-166.000000 type=2 tx_enable=1 tx_notch_freq=0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 rxrfchain 1: enable=1 freq=868.5MHz rssi_offset=-166.000000 type=2 tx_enable=0 tx_notch_freq=0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 0: enable=1 rf_chain=1 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 1: enable=1 rf_chain=1 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 2: enable=1 rf_chain=1 freq=0 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 3: enable=1 rf_chain=0 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 4: enable=1 rf_chain=0 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 5: enable=1 rf_chain=0 freq=0 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 6: enable=1 rf_chain=0 freq=200000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 7: enable=1 rf_chain=0 freq=400000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 8: enable=1 rf_chain=1 freq=-200000 bandwidth=2 datarate=2 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX1301 ifchain 9: enable=1 rf_chain=1 freq=300000 bandwidth=3 datarate=50000 sync_word=0/0
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] SX130x LBT not enabled
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.413 [RAL:VERB] Station device: /dev/spidev0.0 (PPS capture disabled)
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.414 [RAL:ERRO] Concentrator start failed: lgw_start
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.414 [RAL:ERRO] ral_config failed with status 0x08
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.414 [any:ERRO] Closing connection to muxs - error in s2e_onMsg
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.414 [AIO:DEBU] [3] ws_close reason=1000
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.414 [AIO:DEBU] Echoing close - reason=1000
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.460 [AIO:DEBU] [3|WS] Server sent close: reason=1000
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.460 [AIO:DEBU] [3] WS connection shutdown...
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.461 [TCE:VERB] Connection to MUXS closed in state -1
26.04.21 15:18:29 (+0200) <main> 2021-04-26 13:18:29.461 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.462 [any:INFO] ./tc.trust:
26.04.21 15:18:39 (+0200) <main> cert. version : 3
26.04.21 15:18:39 (+0200) <main> serial number : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
26.04.21 15:18:39 (+0200) <main> issuer name : O=Digital Signature Trust Co., CN=DST Root CA X3
26.04.21 15:18:39 (+0200) <main> subject name : O=Digital Signature Trust Co., CN=DST Root CA X3
26.04.21 15:18:39 (+0200) <main> issued on : 2000-09-30 21:12:19
26.04.21 15:18:39 (+0200) <main> expires on : 2021-09-30 14:01:15
26.04.21 15:18:39 (+0200) <main> signed using : RSA with SHA1
26.04.21 15:18:39 (+0200) <main> RSA key size : 2048 bits
26.04.21 15:18:39 (+0200) <main> basic constraints : CA=true
26.04.21 15:18:39 (+0200) <main> key usage : Key Cert Sign, CRL Sign
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.463 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.513 [TCE:INFO] Connecting to INFOS: wss://eu1.cloud.thethings.network:8887
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.812 [TCE:INFO] Infos: b827:ebff:fe64:2dfe muxs-::0 wss://eu1.cloud.thethings.network:8887/traffic/eui-B827EBFFFE642DFE
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.812 [AIO:DEBU] [3] ws_close reason=1000
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.813 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.813 [AIO:DEBU] [3] WS connection shutdown...
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.814 [any:INFO] ./tc.trust:
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.814 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
26.04.21 15:18:39 (+0200) <main> 2021-04-26 13:18:39.861 [TCE:VERB] Connecting to MUXS...
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.116 [TCE:VERB] Connected to MUXS.
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.163 [RAL:WARN] Ignoring unsupported/unknown field: antenna_gain
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.163 [RAL:INFO] Lora gateway library version: Version: 5.0.1;
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.164 [RAL:VERB] Connecting to device: /dev/spidev0.0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:DEBU] SX130x txlut table (0 entries)
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 rxrfchain 0: enable=1 freq=867.5MHz rssi_offset=-166.000000 type=2 tx_enable=1 tx_notch_freq=0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 rxrfchain 1: enable=1 freq=868.5MHz rssi_offset=-166.000000 type=2 tx_enable=0 tx_notch_freq=0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 0: enable=1 rf_chain=1 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 1: enable=1 rf_chain=1 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 2: enable=1 rf_chain=1 freq=0 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 3: enable=1 rf_chain=0 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 4: enable=1 rf_chain=0 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 5: enable=1 rf_chain=0 freq=0 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 6: enable=1 rf_chain=0 freq=200000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 7: enable=1 rf_chain=0 freq=400000 bandwidth=0 datarate=0 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 8: enable=1 rf_chain=1 freq=-200000 bandwidth=2 datarate=2 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX1301 ifchain 9: enable=1 rf_chain=1 freq=300000 bandwidth=3 datarate=50000 sync_word=0/0
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] SX130x LBT not enabled
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.165 [RAL:VERB] Station device: /dev/spidev0.0 (PPS capture disabled)
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.166 [RAL:ERRO] Concentrator start failed: lgw_start
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.166 [RAL:ERRO] ral_config failed with status 0x08
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.166 [any:ERRO] Closing connection to muxs - error in s2e_onMsg
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.166 [AIO:DEBU] [3] ws_close reason=1000
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.166 [AIO:DEBU] Echoing close - reason=1000
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.211 [AIO:DEBU] [3|WS] Server sent close: reason=1000
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.211 [AIO:DEBU] [3] WS connection shutdown...
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.211 [TCE:VERB] Connection to MUXS closed in state -1
26.04.21 15:18:40 (+0200) <main> 2021-04-26 13:18:40.211 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
did you try to change the LoRa hat? could you please try to share the logs as well?
thanks
Thank you very much for this hint. My RAK833 works now with Balena Basicstation.
You rescued 130 Euro !!!
