I need python 3.6 and have tried resin/raspberrypi3-python:3.6 but this still installs python 3.4.
I see the image is based on jessie which has python3.4.
Upgrading pip results in lots of errors - I think this is a bug.
any ideas?
any ideas?
and python --version reports 3.6.4 as well
I am posting this in a number of separatye parts as there is a limit:
Here is the Dockerfile:
phewlett@phewlett-XPS-15-9560:~/electronrx/git/ebio/button-gateway change-resin-image $ cat Dockerfile.template
# base-image for python on any machine using a template variable,
# see more about dockerfile templates here: http://docs.resin.io/deployment/docker-templates/
# and about resin base images here: http://docs.resin.io/runtime/resin-base-images/
# docker pull armhf/ubuntu
# FROM arm32v7/ubuntu:artful
# FROM resin/armv7hf-debian:stretch
FROM resin/raspberrypi3-python:3.6
ENV DBUS_SYSTEM_BUS_ADDRESS unix:path=/host/run/dbus/system_bus_socket
# define our working directory in the container
WORKDIR usr/src/app
ENV PYTHON_CONFIG=/usr/src/app/config.yaml
# copy all files in our root to the working directory
COPY . ./
# Build everything
RUN ./buildscripts/build.sh
# enable systemd init system in the container
# disabled as application failure should cause container to restart
ENV INITSYSTEM on
# execute in shell
CMD ["bash", "start.sh"]
build.sh is:
#!/bin/sh -ex
# build everything
ls -l /etc/*release
cat /etc/*release
python --version
# bluez requires python3-gi, python-gi-cairo, python-dbus, gir1.2-gtk-3.0
# grpcio requires python3-dev
apt-get update && apt-get install -yq --no-install-recommends \
bluez \
ca-certificates \
gcc \
gir1.2-gtk-3.0 \
libdpkg-perl \
python3-dbus \
python3-dev \
python3-gi \
python3-gi-cairo \
python3-pip \
vim \
&& apt-get -y autoremove \
&& apt-get -y autoclean \
&& apt-get -y clean \
PIP_CONFIG_FILE=~/.config/pip/pip.conf
pip3 install --upgrade --ignore-installed pip setuptools
# Overwrite bluetooth config files
cp bluetooth.init /etc/init.d/bluetooth
cp defaults.bluetooth /etc/default/bluetooth
# install python pure dependencies
pip3 install -r ./requirements-dev.txt
pip3 install -r ./requirements.txt
# Static code analysis
pycodestyle --show-pep8 button_gateway tests
python3 -m pylint --rcfile=pylintrc button_gateway tests
# Remove static tools
pip3 uninstall -y -r ./requirements-dev.txt
# Remove all build artifacts
apt-get remove -yq \
gcc \
libdpkg-perl \
python3-dev \
python3-pip \
Log output shows (redacted):
+ find -name __pycache__ -delete -print
+ git symbolic-ref --short HEAD
+ BRANCH=change-resin-image
+ [ -n change-resin-image ]
+ git push -f resin change-resin-image:master
Counting objects: 7, done.
Delta compression using up to 8 threads.
Compressing objects: 100% (7/7), done.
Writing objects: 100% (7/7), 901 bytes | 901.00 KiB/s, done.
Total 7 (delta 4), reused 0 (delta 0)
[Info] Starting build for bluetoothrelay, user g_bryn_mathias
[Info] Dashboard link: https://dashboard.resin.io/apps/960459/devices
[Info] Building on arm03
[Info] Pulling previous images for caching purposes...
[gateway] Step 1/8 : FROM resin/raspberrypi3-python:3.6
[gateway] ---> c1c02e739ada
[gateway] Step 2/8 : ENV DBUS_SYSTEM_BUS_ADDRESS unix:path=/host/run/dbus/system_bus_socket
[gateway] Using cache
[gateway] ---> dfc65152aa0e
[gateway] Step 3/8 : WORKDIR usr/src/app
[gateway] ---> 78a5fbd8a681
[gateway] Step 4/8 : ENV PYTHON_CONFIG /usr/src/app/config.yaml
[gateway] ---> a885ed84d2b3
[gateway] Step 5/8 : COPY . ./
[gateway] ---> f696463cbb8a
[gateway] Step 6/8 : RUN ./buildscripts/build.sh
[gateway] ---> Running in ced33db1e31d
[gateway] + ls -l /etc/os-release
[gateway]
[gateway] lrwxrwxrwx 1 root root 21 Dec 4 15:12 /etc/os-release -> ../usr/lib/os-release
[gateway] + cat /etc/os-release
[gateway]
[gateway] PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
[gateway] NAME="Debian GNU/Linux"
[gateway] VERSION_ID="8"
[gateway] VERSION="8 (jessie)"
[gateway] ID=debian
[gateway] HOME_URL="http://www.debian.org/"
[gateway] SUPPORT_URL="http://www.debian.org/support"
[gateway] BUG_REPORT_URL="https://bugs.debian.org/"
[gateway] + python --version
[gateway]
[gateway] Python 3.6.4
[gateway] + apt-get update
[gateway]
[gateway] Get:1 http://security.debian.org jessie/updates InRelease [63.1 kB]
[gateway] Get:2 http://archive.raspbian.org jessie InRelease [14.9 kB]
[gateway] Get:3 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
[gateway] Ign http://deb.debian.org jessie InRelease
[gateway] Get:4 http://deb.debian.org jessie-updates InRelease [145 kB]
[gateway] Get:5 http://deb.debian.org jessie Release.gpg [2434 B]
[gateway] Get:6 http://deb.debian.org jessie Release [148 kB]
[gateway] Get:7 http://security.debian.org jessie/updates/main armhf Packages [615 kB]
[gateway] Get:8 http://archive.raspbian.org jessie/main armhf Packages [13.3 MB]
[gateway] Get:9 http://archive.raspberrypi.org jessie/main armhf Packages [172 kB]
[gateway] Get:10 http://deb.debian.org jessie-updates/main armhf Packages [23.1 kB]
[gateway] Get:11 http://deb.debian.org jessie/main armhf Packages [8864 kB]
[gateway] Get:12 http://archive.raspbian.org jessie/contrib armhf Packages [49.5 kB]
[gateway] Get:13 http://archive.raspbian.org jessie/non-free armhf Packages [101 kB]
[gateway] Get:14 http://archive.raspbian.org jessie/rpi armhf Packages [1297 B]
[gateway] Get:15 http://archive.raspbian.org jessie/firmware armhf Packages [1202 B]
[gateway] Fetched 23.5 MB in 12s (1962 kB/s)
[gateway] Reading package lists...
[gateway] + apt-get install -yq --no-install-recommends bluez ca-certificates gcc gir1.2-gtk-3.0 libdpkg-perl python3-dbus python3-dev python3-gi python3-gi-cairo python3-pip vim
[gateway]
[gateway] Building dependency tree...
[gateway] Reading state information...
[gateway] ca-certificates is already the newest version.
[gateway] libdpkg-perl is already the newest version.
[gateway] libdpkg-perl set to manually installed.
[gateway] gcc is already the newest version.
[gateway] gcc set to manually installed.
[gateway] The following extra packages will be installed:
[gateway] adwaita-icon-theme dbus dconf-gsettings-backend dconf-service dh-python
[gateway] gir1.2-atk-1.0 gir1.2-freedesktop gir1.2-gdkpixbuf-2.0 gir1.2-glib-2.0
[gateway] gir1.2-pango-1.0 glib-networking glib-networking-common
[gateway] glib-networking-services gsettings-desktop-schemas init-system-helpers
[gateway] libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data libatspi2.0-0 libavahi-client3
[gateway] libavahi-common-data libavahi-common3 libcairo-gobject2 libcap-ng0
[gateway] libcolord2 libcups2 libdconf1 libexpat1-dev libgirepository-1.0-1 libgpm2
[gateway] libgtk-3-0 libgtk-3-bin libgtk-3-common libjson-glib-1.0-0
[gateway] libjson-glib-1.0-common libmpdec2 libpangoxft-1.0-0 libproxy1 libpython3-dev
[gateway] libpython3-stdlib libpython3.4 libpython3.4-dev libpython3.4-minimal
[gateway] libpython3.4-stdlib librest-0.7-0 libsoup-gnome2.4-1 libsoup2.4-1
[gateway] libwayland-client0 libwayland-cursor0 libxcomposite1 libxcursor1 libxdamage1
[gateway] libxfixes3 libxft2 libxi6 libxinerama1 libxkbcommon0 libxrandr2 python3
[gateway] python3-cairo python3-chardet python3-colorama python3-distlib
[gateway] python3-html5lib python3-minimal python3-pkg-resources python3-requests
[gateway] python3-setuptools python3-six python3-urllib3 python3.4 python3.4-dev
[gateway] python3.4-minimal vim-common vim-runtime xkb-data
[gateway] Suggested packages:
[gateway] dbus-x11 cups-common gpm gvfs python3-doc python3-tk python3-venv
[gateway] python-dbus-doc python3-dbus-dbg python3-genshi python3-lxml
[gateway] python3-ndg-httpsclient python3-openssl python3-pyasn1 python3.4-venv
[gateway] python3.4-doc binfmt-support ctags vim-doc vim-scripts
[gateway] Recommended packages:
[gateway] at-spi2-core colord python3-wheel
[gateway] The following NEW packages will be installed:
[gateway] adwaita-icon-theme bluez dbus dconf-gsettings-backend dconf-service
[gateway] dh-python gir1.2-atk-1.0 gir1.2-freedesktop gir1.2-gdkpixbuf-2.0
[gateway] gir1.2-glib-2.0 gir1.2-gtk-3.0 gir1.2-pango-1.0 glib-networking
[gateway] glib-networking-common glib-networking-services gsettings-desktop-schemas
[gateway] init-system-helpers libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data
[gateway] libatspi2.0-0 libavahi-client3 libavahi-common-data libavahi-common3
[gateway] libcairo-gobject2 libcap-ng0 libcolord2 libcups2 libdconf1 libexpat1-dev
[gateway] libgirepository-1.0-1 libgpm2 libgtk-3-0 libgtk-3-bin libgtk-3-common
[gateway] libjson-glib-1.0-0 libjson-glib-1.0-common libmpdec2 libpangoxft-1.0-0
[gateway] libproxy1 libpython3-dev libpython3-stdlib libpython3.4 libpython3.4-dev
[gateway] libpython3.4-minimal libpython3.4-stdlib librest-0.7-0 libsoup-gnome2.4-1
[gateway] libsoup2.4-1 libwayland-client0 libwayland-cursor0 libxcomposite1
[gateway] libxcursor1 libxdamage1 libxfixes3 libxft2 libxi6 libxinerama1 libxkbcommon0
[gateway] libxrandr2 python3 python3-cairo python3-chardet python3-colorama
[gateway] python3-dbus python3-dev python3-distlib python3-gi python3-gi-cairo
[gateway] python3-html5lib python3-minimal python3-pip python3-pkg-resources
[gateway] python3-requests python3-setuptools python3-six python3-urllib3 python3.4
[gateway] python3.4-dev python3.4-minimal vim vim-common vim-runtime xkb-data
[gateway] 0 upgraded, 84 newly installed, 0 to remove and 11 not upgraded.
[gateway] Need to get 72.9 MB of archives.
[gateway] Get:82 http://deb.debian.org/debian/ jessie/main python3-pip all 1.5.6-5 [97.2 kB]
[gateway] Get:83 http://deb.debian.org/debian/ jessie/main vim-runtime all 2:7.4.488-7+deb8u3 [5048 kB]
[gateway] Get:84 http://deb.debian.org/debian/ jessie/main vim armhf 2:7.4.488-7+deb8u3 [827 kB]
[gateway] debconf: delaying package configuration, since apt-utils is not installed
[gateway] Unpacking librest-0.7-0:armhf (0.7.92-3) ...
[gateway] Preparing to unpack .../vim_2%3a7.4.488-7+deb8u3_armhf.deb ...
[gateway] Unpacking vim (2:7.4.488-7+deb8u3) ...
[gateway] Processing triggers for libglib2.0-0:armhf (2.42.1-1+b1) ...
[gateway] Processing triggers for libc-bin (2.19-18+deb8u10) ...
[gateway] Processing triggers for mime-support (3.58) ...
[gateway] Processing triggers for hicolor-icon-theme (0.13-1) ...
[gateway] Processing triggers for systemd (215-17+deb8u7) ...
[gateway] Setting up libpython3.4-minimal:armhf (3.4.2-1) ...
[gateway] Setting up python3.4 (3.4.2-1) ...
[gateway] Processing triggers for dbus (1.8.22-0+deb8u1) ...
[gateway] + apt-get -y autoremove
[gateway]
[gateway] 0 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
[gateway] + apt-get -y autoclean
[gateway]
[gateway] + apt-get -y clean
[gateway]
[gateway] + rm -rf /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_jessie_InRelease /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_jessie_main_binary-armhf_Packages.gz /var/lib/apt/lists/archive.raspbian.org_raspbian_dists_jessie_InRelease /var/lib/apt/lists/archive.raspbian.org_raspbian_dists_jessie_contrib_binary-armhf_Packages.gz /var/lib/apt/lists/archive.raspbian.org_raspbian_dists_jessie_firmware_binary-armhf_Packages.gz /var/lib/apt/lists/archive.raspbian.org_raspbian_dists_jessie_main_binary-armhf_Packages.gz /var/lib/apt/lists/archive.raspbian.org_raspbian_dists_jessie_non-free_binary-armhf_Packages.gz /var/lib/apt/lists/archive.raspbian.org_raspbian_dists_jessie_rpi_binary-armhf_Packages.gz /var/lib/apt/lists/deb.debian.org_debian_dists_jessie-updates_InRelease /var/lib/apt/lists/deb.debian.org_debian_dists_jessie-updates_main_binary-armhf_Packages.gz /var/lib/apt/lists/deb.debian.org_debian_dists_jessie_Release /var/lib/apt/lists/deb.debian.org_debian_dists_jessie_Release.gpg /var/lib/apt/lists/deb.debian.org_debian_dists_jessie_main_binary-armhf_Packages.gz /var/lib/apt/lists/lock /var/lib/apt/lists/partial /var/lib/apt/lists/security.debian.org_dists_jessie_updates_InRelease /var/lib/apt/lists/security.debian.org_dists_jessie_updates_main_binary-armhf_Packages.gz
[gateway]
[gateway] + PIP_CONFIG_FILE=/root/.config/pip/pip.conf
[gateway] + pip3 install --upgrade --ignore-installed pip setuptools
[gateway]
[gateway] Traceback (most recent call last):
[gateway] File "/usr/local/bin/pip3", line 7, in <module>
[gateway] from pip import main
[gateway] File "/usr/lib/python3/dist-packages/pip/__init__.py", line 72, in <module>
[gateway] from pip.log import logger
[gateway] File "/usr/lib/python3/dist-packages/pip/log.py", line 9, in <module>
[gateway] import colorama, pkg_resources
[gateway] File "/usr/lib/python3/dist-packages/pkg_resources.py", line 1520, in <module>
[gateway] register_loader_type(importlib_bootstrap.SourceFileLoader, DefaultProvider)
[gateway] AttributeError: module 'importlib._bootstrap' has no attribute 'SourceFileLoader'
[gateway]
[gateway] + cp bluetooth.init /etc/init.d/bluetooth
[gateway]
[gateway] + cp defaults.bluetooth /etc/default/bluetooth
[gateway]
[gateway] + pip3 install -r ./requirements-dev.txt
[gateway]
[gateway]
[gateway] Removing intermediate container ced33db1e31d
[gateway] The command '/bin/sh -c ./buildscripts/build.sh' returned a non-zero code: 1
[Info] Uploading images
[Error] Service: gateway
[Error] Error: The command '/bin/sh -c ./buildscripts/build.sh' returned a non-zero code: 1
To git.resin.io:g_bryn_mathias/bluetoothrelay.git
! [remote rejected] change-resin-image -> master (hook declined)
error: failed to push some refs to 'g_bryn_mathias@git.resin.io:g_bryn_mathias/bluetoothrelay.git'
That nearly worked - the problem is a missing dependency and my image has doubled in size from 300MB to >600MB.
Why is it so large?
Is there anything I can remove?
OK - unfortunately the resin imahe has python3.6 but is based on jessie.
This causes problems when installing python packages with C dependencies.
Installing python bluezero package eventually (after installing C deps one-by one as failure occurs) leads to the error below. The version of gobject-introspection is 1.46 but only 1.42 is available.
For this to work I need a python 3.6 image based on stretch which has 1.50.
This is because this image is based on jessie. jessie is too far behind to keep up with such C deps as this.
Running setup.py install for pygobject: started
[gateway] Running setup.py install for pygobject: finished with status 'error'
[gateway] Complete output from command /usr/local/bin/python3.6 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-zuujpegq/pygobject/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-kh83jvf7-record/install-record.txt --single-version-externally-managed --compile:
[gateway] running install
[gateway] running build
[gateway] running build_py
[gateway] creating build
[gateway] creating build/lib.linux-armv8l-3.6
[gateway] creating build/lib.linux-armv8l-3.6/pygtkcompat
[gateway] copying pygtkcompat/__init__.py -> build/lib.linux-armv8l-3.6/pygtkcompat
[gateway] copying pygtkcompat/pygtkcompat.py -> build/lib.linux-armv8l-3.6/pygtkcompat
[gateway] copying pygtkcompat/generictreemodel.py -> build/lib.linux-armv8l-3.6/pygtkcompat
[gateway] creating build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/__init__.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/_signalhelper.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/importer.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/pygtkcompat.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/module.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/_constants.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/_ossighelper.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/_error.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/_option.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/_propertyhelper.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/docstring.py -> build/lib.linux-armv8l-3.6/gi
[gateway] copying gi/types.py -> build/lib.linux-armv8l-3.6/gi
[gateway] creating build/lib.linux-armv8l-3.6/gi/repository
[gateway] copying gi/repository/__init__.py -> build/lib.linux-armv8l-3.6/gi/repository
[gateway] creating build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/__init__.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/GIMarshallingTests.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/Gdk.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/Gtk.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/GLib.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/Pango.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/Gio.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/GObject.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] copying gi/overrides/keysyms.py -> build/lib.linux-armv8l-3.6/gi/overrides
[gateway] running build_ext
[gateway] Requested 'gobject-introspection-1.0 >= 1.46.0' but version of gobject-introspection is 1.42.0
[gateway] Command '('pkg-config', '--print-errors', '--exists', 'gobject-introspection-1.0 >= 1.46.0')' returned non-zero exit status 1.
[gateway] ----------------------------------------
[gateway] Command "/usr/local/bin/python3.6 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-zuujpegq/pygobject/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-kh83jvf7-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-zuujpegq/pygobject/
Can I use this Dockerfile:
and change jessie to stretch?
