Pip install fails with "Connection broken"
I am having issues with using pip in a resin based image. My Dockerfile is the following:
FROM resin/raspberrypi3-python:3.6
MAINTAINER Andrew Kail <andrew.a.kail@gmail.com>
RUN [ "cross-build-start" ]
RUN apt-get update
RUN pip install Django
RUN [ "cross-build-end" ]
When it hits the ‘pip install’ I get the following error.
Collecting Django
  Downloading Django-2.0.2-py3-none-any.whl (7.1MB)
Exception:
Traceback (most recent call last):
  File "/usr/local/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 232, in _error_catcher
    yield
  File "/usr/local/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 314, in read
    data = self._fp.read(amt)
  File "/usr/local/lib/python3.6/site-packages/pip/_vendor/cachecontrol/filewrapper.py", line 60, in read
    data = self.__fp.read(amt)
  File "/usr/local/lib/python3.6/http/client.py", line 449, in read
    n = self.readinto(b)
  File "/usr/local/lib/python3.6/http/client.py", line 493, in readinto
    n = self.fp.readinto(b)
  File "/usr/local/lib/python3.6/socket.py", line 586, in readinto
    return self._sock.recv_into(b)
  File "/usr/local/lib/python3.6/ssl.py", line 1009, in recv_into
    return self.read(nbytes, buffer)
  File "/usr/local/lib/python3.6/ssl.py", line 871, in read
    return self._sslobj.read(len, buffer)
  File "/usr/local/lib/python3.6/ssl.py", line 631, in read
    v = self._sslobj.read(len, buffer)
ConnectionResetError: [Errno 104] Connection reset by peer
During handling of the above exception, another exception occurred:
  File "/usr/local/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/usr/local/lib/python3.6/site-packages/pip/commands/install.py", line 324, in run
    requirement_set.prepare_files(finder)
  File "/usr/local/lib/python3.6/site-packages/pip/req/req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/usr/local/lib/python3.6/site-packages/pip/req/req_set.py", line 620, in _prepare_file
    session=self.session, hashes=hashes)
  File "/usr/local/lib/python3.6/site-packages/pip/download.py", line 821, in unpack_url
    hashes=hashes
  File "/usr/local/lib/python3.6/site-packages/pip/download.py", line 659, in unpack_http_url
    hashes)
  File "/usr/local/lib/python3.6/site-packages/pip/download.py", line 882, in _download_http_url
    _download_url(resp, link, content_file, hashes)
  File "/usr/local/lib/python3.6/site-packages/pip/download.py", line 603, in _download_url
    hashes.check_against_chunks(downloaded_chunks)
  File "/usr/local/lib/python3.6/site-packages/pip/utils/hashes.py", line 46, in check_against_chunks
    for chunk in chunks:
  File "/usr/local/lib/python3.6/site-packages/pip/download.py", line 571, in written_chunks
  File "/usr/local/lib/python3.6/site-packages/pip/utils/ui.py", line 139, in iter
    for x in it:
  File "/usr/local/lib/python3.6/site-packages/pip/download.py", line 560, in resp_read
    decode_content=False):
  File "/usr/local/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 357, in stream
    data = self.read(amt=amt, decode_content=decode_content)
  File "/usr/local/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 324, in read
    flush_decoder = True
  File "/usr/local/lib/python3.6/contextlib.py", line 99, in __exit__
    self.gen.throw(type, value, traceback)
  File "/usr/local/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 250, in _error_catcher
    raise ProtocolError('Connection broken: %r' % e, e)
pip._vendor.requests.packages.urllib3.exceptions.ProtocolError: ("Connection broken: ConnectionResetError(104, 'Connection reset by peer')", ConnectionResetError(104, 'Connection reset by peer'))
I am building on Manjaro Linux with docker version 18.01.0-ce and kernel 4.14.16-1.
Some google searching has shown issues in Travis CI that are the same, but the fix did not work for me.
Also, I am able to do these builds without issue using x86 based images doing the exact same docker commands.
Has anyone experienced this before and worked around it? I’m at a loss.
This looks like a temporary network failure. I just pushed a project that downloads Django and it built correctly.
Could you please try again?
I agree. Everything I have found points to that being the issue. I am not currently pushing anything to resin, just starting to get started with building rpi3 images on my personal device.
Its a little strange that apt-get update (and upgrade) are working fine. Same build works fine with alpine and debian x86 images.
Next I may try another resin arm image and then do a tcpdump to see what the network traffic over the docker interface looks like.
Tcpdump with wireshark. ZeroWindow Error
157 1.798524 172.17.0.2 151.101.0.223 TCP 54 [TCP ZeroWindow] 41582 → 443 [ACK] Seq=1798 Ack=852072 Win=0 Len=0
Also:
Build fails identically with resin/armv7hf-debian image as well.
