Problems connecting LoRa basics station to TTN V3
Here the other 5 log files.
6.txt (9.4 KB)
7.txt (9.4 KB)
8.txt (9.4 KB)
9.txt (6.3 KB)
10.txt (6.3 KB)
First, the Mode: STATIC parameter suggests that an existing station.conf file is taking precedence over the variables you might be setting in the balena dashboard. This means you might be mounting a config folder in your project, right? If that’s the case I’d suggest not to do it until you have a working configuration, otherwise it will mess with your tests.
Second, the error below suggests a connection problem to the LNS. The CUPS server worked fine thou. This could have been a temporary issue.
I have no idea why the log 1 says STATIC. All other 9 logs say DYNAMIC. I am not mounting a config folder; I do not even know how to do that. Perhaps I did not properly restarted the service in Balena?
About the second issue, I am now testing if port 8887 is open in the university net.
Hi again,
I got it working! The port 8887 was closed. Now seems to work nicely. Sorry if I caused inconvenience with such a silly issue. Still, thanks @xoseperez for having a look.
15.06.22 11:55:24 (-0500) Started service 'basicstation sha256:a76a088b1dccc08c11601bf6d9758f5e254cb95e496d9ef2cb9d365f07ee4778'
15.06.22 11:55:24 (-0500)  basicstation  GATEWAY_EUI: DCA632FFFEDF31F7
15.06.22 11:55:25 (-0500)  basicstation  parse error: Invalid numeric literal at EOF at line 1, column 12
15.06.22 11:55:25 (-0500)  basicstation  ------------------------------------------------------------------
15.06.22 11:55:25 (-0500)  basicstation  Protocol
15.06.22 11:55:25 (-0500)  basicstation  Mode:          DYNAMIC
15.06.22 11:55:25 (-0500)  basicstation  Protocol:      CUPS
15.06.22 11:55:25 (-0500)  basicstation  CUPS Server:   https://nam1.cloud.thethings.network:443
15.06.22 11:55:25 (-0500)  basicstation  Main NIC:      eth0
15.06.22 11:55:25 (-0500)  basicstation  Gateway EUI:   DCA632FFFEDF31F7
15.06.22 11:55:25 (-0500)  basicstation  Radio
15.06.22 11:55:25 (-0500)  basicstation  Model:         RAK2245
15.06.22 11:55:25 (-0500)  basicstation  Concentrator:  SX1301
15.06.22 11:55:25 (-0500)  basicstation  Design:        V2
15.06.22 11:55:25 (-0500)  basicstation  Radio Device:  /dev/spidev0.0
15.06.22 11:55:25 (-0500)  basicstation  Interface:     SPI
15.06.22 11:55:25 (-0500)  basicstation  SPI Speed:     2000000
15.06.22 11:55:25 (-0500)  basicstation  Reset GPIO:    17
15.06.22 11:55:25 (-0500)  basicstation  Enable GPIO:   0
15.06.22 11:55:25 (-0500)  basicstation  Concentrator reset through GPIO17
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.104 [SYS:INFO] Logging     : stderr (maxsize=10000000, rotate=3)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.104 [SYS:INFO] Station Ver : 2.0.6(rpi/stdn) 2022-05-31 17:06:34
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.104 [SYS:INFO] Package Ver : (null)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.104 [SYS:INFO] mbedTLS Ver : 2.28.0
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.104 [SYS:INFO] proto EUI   : dca6:32ff:fedf:31f7   (station.conf)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.104 [SYS:INFO] prefix EUI  : ::1   (builtin)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.104 [SYS:INFO] Station EUI : dca6:32ff:fedf:31f7
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.105 [SYS:INFO] Station home: ./    (builtin)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.105 [SYS:INFO] Station temp: /var/tmp/     (builtin)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.109 [RAL:DEBU] execvp argv[0]: </proc/self/exe>
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.109 [RAL:DEBU]        argv[1]: <-S>
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.109 [RAL:DEBU]        argv[2]: <(null)>
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.116 [S00:INFO] Logging     : stderr (maxsize=10000000, rotate=3)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.116 [S00:INFO] Station Ver : 2.0.6(rpi/stdn) 2022-05-31 17:06:34
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.118 [S00:INFO] Package Ver : (null)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.118 [S00:INFO] mbedTLS Ver : 2.28.0
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.118 [S00:INFO] proto EUI   : dca6:32ff:fedf:31f7   (station.conf)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.118 [S00:INFO] prefix EUI  : ::1   (builtin)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.119 [S00:INFO] Station EUI : dca6:32ff:fedf:31f7
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.120 [S00:INFO] Station home: ./    (builtin)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.120 [S00:INFO] Station temp: /var/tmp/     (builtin)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.121 [S00:INFO] Station slave: 0
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.122 [S00:INFO] Slave LGW (0) - started.
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.108 [RAL:INFO] Master has started slave: pid=44 idx=0 (attempt 1)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.308 [TCE:INFO] Starting TC engine
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.309 [TCE:ERRO] No TC URI configured
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.309 [CUP:INFO] Starting a CUPS session in 0 seconds.
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.309 [TCE:INFO] Router rejected or retry limit reached. Invoking CUPS.
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.309 [TCE:INFO] Terminating TC engine
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.309 [CUP:INFO] Starting a CUPS session now.
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.309 [CUP:INFO] Connecting to CUPS ... https://nam1.cloud.thethings.network:443 (try #1)
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.377 [AIO:INFO] ./cups.trust:
15.06.22 11:55:26 (-0500)  basicstation  cert. version     : 3
15.06.22 11:55:26 (-0500)  basicstation  serial number     : 04:00:00:00:00:01:15:4B:5A:C3:94
15.06.22 11:55:26 (-0500)  basicstation  issuer name       : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
15.06.22 11:55:26 (-0500)  basicstation  subject name      : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
15.06.22 11:55:26 (-0500)  basicstation  issued  on        : 1998-09-01 12:00:00
15.06.22 11:55:26 (-0500)  basicstation  expires on        : 2028-01-28 12:00:00
15.06.22 11:55:26 (-0500)  basicstation  signed using      : RSA with SHA1
15.06.22 11:55:26 (-0500)  basicstation  RSA key size      : 2048 bits
15.06.22 11:55:26 (-0500)  basicstation  basic constraints : CA=true
15.06.22 11:55:26 (-0500)  basicstation  key usage         : Key Cert Sign, CRL Sign
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.431 [CUP:VERB] Retrieving update-info from CUPS https://nam1.cloud.thethings.network:443...
15.06.22 11:55:26 (-0500)  basicstation  2022-06-15 16:55:26.435 [CUP:DEBU] CUPS Request: {"router":"dca6:32ff:fedf:31f7","cupsUri":"https://nam1.cloud.thethings.network:443","tcUri":null,"cupsCredCrc":3424366189,"tcCredCrc":2077607535,"station":"2.0.6(rpi/stdn) 2022-05-31 17:06:10","model":"rpi","package":null,"keys":[]}
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.349 [CUP:INFO] [Segment] TC URI: wss://nam1.cloud.thethings.network:8887
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.349 [CUP:INFO] [Segment] TC Credentials (1510 bytes)
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.349 [SYS:INFO]  credComplete - trust_off=   0, trust_len=1391               30 82 05 6b  30 82 03 53
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.349 [SYS:INFO]  credComplete - cert_off =1391, cert_len =   0  da de 18 27  00 00 00 00  41 75 74 68
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.349 [SYS:INFO]  credComplete - key_off  =1395, key_len  = 115  00 00 00 00  41 75 74 68  6f 72 69 7a
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.350 [CUP:INFO] [Segment] TC Credentials update completed (1510 bytes)
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.365 [AIO:DEBU] [4] HTTP connection shutdown...
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.366 [CUP:INFO] CUPS provided TC updates (uri) - restarting TC engine
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.366 [CUP:INFO] Interaction with CUPS done - next regular check in 1d
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.366 [TCE:INFO] Starting TC engine
15.06.22 11:55:27 (-0500)  basicstation  2022-06-15 16:55:27.367 [AIO:INFO] ./tc.trust:
15.06.22 11:55:27 (-0500)  basicstation  cert. version     : 3
15.06.22 11:55:27 (-0500)  basicstation  serial number     : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00
15.06.22 11:55:27 (-0500)  basicstation  issuer name       : C=US, O=Internet Security Research Group, CN=ISRG Root X1
15.06.22 11:55:27 (-0500)  basicstation  subject name      : C=US, O=Internet Security Research Group, CN=ISRG Root X1
15.06.22 11:55:27 (-0500)  basicstation  issued  on        : 2015-06-04 11:04:38
15.06.22 11:55:27 (-0500)  basicstation  expires on        : 2035-06-04 11:04:38
15.06.22 11:55:27 (-0500)  basicstation  signed using      : RSA with SHA-256
15.06.22 11:55:27 (-0500)  basicstation  RSA key size      : 4096 bits
15.06.22 11:55:27 (-0500)  basicstation  basic constraints : CA=true
15.06.22 11:55:27 (-0500)  basicstation  key usage         : Key Cert Sign, CRL Sig2022-06-15 16:55:27.367 [TCE:INFO] Connecting to INFOS: wss://nam1.cloud.thethings.network:8887
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.043 [TCE:INFO] Infos: dca6:32ff:fedf:31f7 muxs-::0 wss://nam1.cloud.thethings.network:8887/traffic/eui-DCA632FFFEDF31F7
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.043 [AIO:DEBU] [4] ws_close reason=1000
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.043 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.043 [AIO:DEBU] [4] WS connection shutdown...
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.044 [AIO:INFO] ./tc.trust:
15.06.22 11:55:28 (-0500)  basicstation  cert. version     : 3
15.06.22 11:55:28 (-0500)  basicstation  serial number     : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00
15.06.22 11:55:28 (-0500)  basicstation  issuer name       : C=US, O=Internet Security Research Group, CN=ISRG Root X1
15.06.22 11:55:28 (-0500)  basicstation  subject name      : C=US, O=Internet Security Research Group, CN=ISRG Root X1
15.06.22 11:55:28 (-0500)  basicstation  issued  on        : 2015-06-04 11:04:38
15.06.22 11:55:28 (-0500)  basicstation  expires on        : 2035-06-04 11:04:38
15.06.22 11:55:28 (-0500)  basicstation  signed using      : RSA with SHA-256
15.06.22 11:55:28 (-0500)  basicstation  RSA key size      : 4096 bits
15.06.22 11:55:28 (-0500)  basicstation  basic constraints : CA=true
15.06.22 11:55:28 (-0500)  basicstation  key usage         : Key Cert Sign, CRL Sig2022-06-15 16:55:28.044 [TCE:VERB] Connecting to MUXS...
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.858 [S00:INFO] Lora gateway library version: Version: 5.0.1;
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.859 [S00:INFO] [LGW lgw1] clksrc=1 lorawan_public=1
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.859 [S00:INFO]  RX/TX RF0:    904.3MHz rssi_offset=-166.0 type=2 tx_notch_freq=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  RX    RF1:    905.0MHz rssi_offset=-166.0 type=2 tx_notch_freq=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [mSF]   0:    903.9MHz rf=0 freq=-400.0 datarate=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [mSF]   1:    904.1MHz rf=0 freq=-200.0 datarate=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [mSF]   2:    904.3MHz rf=0 freq=  +0.0 datarate=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [mSF]   3:    904.5MHz rf=0 freq=+200.0 datarate=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [mSF]   4:    904.7MHz rf=1 freq=-300.0 datarate=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [mSF]   5:    904.9MHz rf=1 freq=-100.0 datarate=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [mSF]   6:    905.1MHz rf=1 freq=+100.0 datarate=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [mSF]   7:    905.3MHz rf=1 freq=+300.0 datarate=0
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.860 [S00:INFO]  [STD]   8:    904.6MHz rf=0 freq=+300.0 datarate=4 bw=1
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.861 [S00:INFO]  channel 9 disabled
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.861 [S00:INFO] SX130x LBT not enabled
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.861 [S00:INFO] Station device: /dev/spidev0.0 (PPS capture disabled)
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.861 [S00:INFO] [lgw_spi_open:101] Setting SPI speed to 2000000
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.861 [S00:INFO] [lgw_spi_open:135] Note: SPI port opened and configured ok
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.773 [TCE:VERB] Connected to MUXS.
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [RAL:INFO] Region plan hwspec 'sx1301/1' mapped to 1 slaves 'sx1301/1'
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [RAL:INFO] Master sending 645 bytes of JSON sx1301conf to slave (0)
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO] Configuring for region: US915 -- 923.0MHz..928.0MHz
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR0  SF10/BW125
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR1  SF9/BW125
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR2  SF8/BW125
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR3  SF7/BW125
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR4  SF8/BW500
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR5  FSK
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR6  FSK
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR7  FSK
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR8  SF12/BW500
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR9  SF11/BW500
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR10 SF10/BW500
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR11 SF9/BW500
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR12 SF8/BW500
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR13 SF7/BW500
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR14 FSK
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   DR15 FSK
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   TX power: 26.0 dBm EIRP
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   JoinEui list: 0 entries
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   NetID filter: FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
15.06.22 11:55:28 (-0500)  basicstation  2022-06-15 16:55:28.831 [S2E:INFO]   Dev/test settings: nocca=1 nodc=1 nodwell=1
15.06.22 11:55:32 (-0500)  basicstation  2022-06-15 16:55:32.183 [S00:INFO] Concentrator started (3s322ms)
15.06.22 11:56:14 (-0500)  basicstation  2022-06-15 16:56:14.169 [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm  q50: +7.6ppm  q80: -8.6ppm  max: -16.2ppm - threshold q90: -11.4ppm
15.06.22 11:56:14 (-0500)  basicstation  2022-06-15 16:56:14.169 [SYN:INFO] Mean MCU drift vs SX130X#0: 0.4ppm
15.06.22 11:56:33 (-0500)  basicstation  2022-06-15 16:56:33.074 [SYN:INFO] Time sync qualities: min=81 q90=167 max=169 (previous q90=2147483647)
15.06.22 11:56:56 (-0500)  basicstation  2022-06-15 16:56:56.181 [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm  q50: +0.5ppm  q80: -7.6ppm  max: +9.0ppm - threshold q90: -8.6ppm
15.06.22 11:56:56 (-0500)  basicstation  2022-06-15 16:56:56.181 [SYN:INFO] Mean MCU drift vs SX130X#0: 0.0ppm
15.06.22 11:57:11 (-0500)  basicstation  2022-06-15 16:57:10.885 [SYN:VERB] Time sync rejected: quality=170 threshold=167
Great!
Enjoy your gateway :grinning:
Hi, I’m setting a basic station using the banana example fleet with Fin v1.0 and Nebra LoRa concentrator (sx1301 based).
For the device variables, I copied the TC_Key from API and rebooted, but still getting error
 basicstation  issuer name       : O=Digital Signature Trust Co., CN=DST Root CA X3
 basicstation  subject name      : O=Digital Signature Trust Co., CN=DST Root CA X3
 basicstation  issued  on        : 2000-09-30 21:12:19
 basicstation  expires on        : 2021-09-30 14:01:15
 basicstation  2022-10-11 04:20:08.815 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
 basicstation  2022-10-11 04:20:08.817 [AIO:ERRO] [-1] WS connect failed: NET - Failed to get an IP address for the given hostname
 basicstation  2022-10-11 04:20:08.817 [AIO:DEBU] [-1] WS connection shutdown...
 basicstation  2022-10-11 04:20:08.817 [TCE:ERRO] TC connect failed - URI: wss://in.cloud.thethings.network:8887
 basicstation  2022-10-11 04:20:08.817 [TCE:INFO] INFOS reconnect backoff 60s (retry 17)
 basicstation  2022-10-11 04:21:08.819 [any:INFO] ./tc.trust:
Thanks :slightly_smiling_face:
Issued fixed, When we select IN865 in balena it’s trying to connect to the wss://in.cloud.thethings.network:8887 but it’s actually not correct on the TTN server side as it’s already listed as “eu1.cloud.thethings.network” even if we select the IN and selected TTN_REGION in device variable as “in” .
So in order to fix the issue, I just changed the TTN_REGION as “eu1:slightly_smiling_face:
Thank you @salmanfarisvp for confirming that it worked once you changed the TTN_REGION :slight_smile:
I have the log saying
[AIO:INFO] tc has no key+cert configured - running server auth only
[AIO:ERRO] [3] WS upgrade failed with HTTP status code: 401
[AIO:DEBU] [3] WS connection shutdown...
[TCE:INFO] INFOS reconnect backoff 10s (retry 1)
i have created every thing with default settings
My TTN gateway have no API keys
the full log is attached
thanks for help
basicstation_fierce-time-22.11.22_06_13_59_(+0200).txt (73.9 KB)
I generated an API key in TTN and use it as TC_key variable in Device variables
now it connects and send gateway status to TTN and disconnect again
basicstation_fierce-time-22.11.22_06_43_06_(+0200).txt (90.6 KB)
@besco1998 did you try to deploy this basicstation? GitHub - xoseperez/basicstation: Basics™ Station Packet Forward protocol using Docker
Is the a list of what codes correspond to which country for TTN_REGION?
I am in the US, so probably shouldn’t put “eu1” correct? Would this affect the expected frequency range?
@tomsepe first of all welcome to the balena community!
indeed if you are in the US you shouldn’t use eu1.
did you check the list of LoRa frequencies here? Frequency Plans | The Things Stack for LoRaWAN
Hi @tomsepe
TTN has 3 different clusters (“eu1”, “nam1” and “au1”). Those are the possible values of the TTN_REGION variable. You should be using the one closer to your location for improved latency, but actually any one of them will work regardless of the frequency band of your devices or gateways.
